BUILD ID = OS VERSION (Settings > About product): 4.0.1.15
HARDWARE (Jolla1, Tablet, XA2,…): Xperia 10 Plus
UI LANGUAGE: Spanish
DESCRIPTION AND ADDITIONAL INFORMATION:
When I updated to early access, aliendalvik doen’t work but I solved it with the solution of this post [4.0.1.45] - Alien Dalvik Not Starting sudo pkcon remove harbour-themepacksupport and aliendalvik starts fine.
This morning, it’s works fine, but later aliendalvik doesn’t start again
This is the partial output of sudo journalctl -xe https://bin.disroot.org/?100dee8aaa34e488#C7rBpNpnjxrnSsM7RiLsE7tRUVQzYDM6Lyjhd8HKs89U
The output of sudo systemctl status aliendalvik.service
I think that the problem is this line
aliendalvik.service: Executable /usr/bin/start-aliendalvik-preinit.sh missing, skipping: No such file or directory
- Start aliendalvik
Aliendalvik starts
Failed to start aliendalvik
but thanks!!
