tn71
5 February 2021 09:29
1
BUILD ID = OS VERSION (Settings > About product): 4.0.1.45
HARDWARE (Jolla1, Tablet, XA2,…): XA2 Single Sim
UI LANGUAGE: English
Similar issue to this post Android Support/Alien Dalvik no longer working [3.4.0.22]
After updating to 4.0.1.45, Android Support stopped working. All buttons greyed out.
Did you try this:
devel-su
systemctl stop aliendalvik
rm -rf /home/.android/data/system/package_cache/1/Alien*
systemctl start aliendalvik
exit
That was proposed as solution for 3.4 by @jovirkku , for me it worked.
Try waiting a while. The upgrade to Android 9 is probably requiring applications upgrade by ART (i. e. recompilation).
Tried that but it does not help at least in my case.
journalctl -xe
https://pastebin.com/d6KNJUD7
Edit:
Finally figured out what was the problem. I had theme pack support installed (not in use) which caused aliendalvik to fail.
devel-su
pkcon remove harbour-themepacksupport
fixed my issue
I found issue by looking systemctl status aliendalvik output which showed failed ExexStartPost script Process: 22161 ExecStartPost=/usr/share/harbour-themepacksupport/service/apkicons.sh (code=exited, status=2)
I removed busybox-symlinks-bash and made sure gnu-bash is installed.
The aliendalvik systemd startup script pukes on some bashism when ash is used…
Peakki
5 February 2021 13:44
6
I had this same problem and your solution worked for me! Thank you!
tn71
5 February 2021 20:52
7
Yes, multiple times. I tried everything in that thread.
tn71
5 February 2021 21:05
8
That was it. That solved it immediately. Thank you!
Had same issue with Alien Dalvil not starting after upgrade to 4.0.1.45 and
fixed it for me thanks!
