Xperia XA2+ Not charging properly
Howdy, I had an issue pop up last night and just wondering if anyones experienced something similar?
I noticed when I plugged my phone in although it appeared to be charging as normal it wouldnt actually build charge and just stay at the same percent or even drop over time. Ive tried a few different cords and adaptors and heaps of different power outlets but nothing seems to work. Although the one thing that seemed to actually charge it up a bit was the charger/ac adaptor for my nintendo switch, have no idea why that one out of everything worked.
I just also noticed a brief notification that said “not enough power to charge.” Dont get why all of a sudden itd think all my cords and adaptors dont have enough power?
If anyones had a similar issue would love to hear how you fixed it! Thanks in advance.
Did you check the hints given in those topics:
https://forum.sailfishos.org/search?context=topic&context_id=9402&q=not charging&skip_context=true
? Especially this?
Cheers! Ill give cleaning it a try just doesnt seem like thats what causing it though. I just noticed today that a cord the didnt work in a wall adaptor for some reason worked in my car.
most threads on this issue always just suggested a hardware problem, but that is definitely not the case. I just had the same problem after using this phone for about a month on android/lineageos, and 1 day of using it on SFOS.
I thought I’d charge it up over night, it just stopped at 47%. unplugged and plugged it in again in the morning, than it would charge up to ~74% before I had to unplug an leave for work.
Plugged it in again this morning at 3% and it just ran empty and refused to charge ever since.
I booted the phone into fastebootmode, now it’s charging as it should. So no, not a hardware issue.
I’m guessing you didn’t get the “not enough power to charge” notification, in which case it might be a different problem.
I had this problem and it was a USB cable that became faulty.
There’s another problem which I think is a loose USB port. If the charging becomes interrupted enough times through a loose connection at your XA2, it decides not to charge. For reasons I don’t quite understand, running SystemDataScope along with CollectD usually fixes it.
This problem happens so much that I have to check my phone is charging if I need it.
To be fair, this could be a problem specific to Sailfish.
I started getting this as a software problem on the XA2, not sure when.
The way to fix it is to remove the charging cable and use the Utilities app to reset the Home Screen. I guess we could also work through the list of threads and find the offender.
For anyone looking at this post still now looking for an answer it seemed more just to do with the cables I was using. Fast chargers work fine and chargers from my switch/laptop seem to be fine which leads me to believe the phone simply just needs the higher current output from the cords that cheaper ones just do not have!
