Hi @zuyev, I’m trying to flash an xz2 6GB version but I’m getting this:
“Found H8296, baseband:1313-0868_52.1.A.3.49, bootloader:1310-7079_X_Boot_SDM845_LA2.0.1_Q_207
Found 0 devices:
Incorrect number of devices connected. Make sure there is exactly one device connected in fastboot mode”…any hints? TIA
Edit: I checked the flash.sh and sure enough it references H8266, so I changed that to H8296 but now I have 'md5sum does not match", can I take out the md5sum check altogether?
Edit 2: I didn’t fully understand the syntax but took out the md5sum section and the script ran ok. I flashed sf4.5, got the flashing sony logo, otherwise everything is great! Thanks zuyev for this tip. This device can be bought new for about 180€
When i flashed my xz2 compact, the installation-script (on windows) doesn’t find my device because it was other reported as from the script expected.
As a workaround i just perform the flash commands for the partitions from the script one-by-one by hand in the console and it worked for me.
