Xperia Tama port: 4.5.0.16/4.5.0.18/4.5.0.19/4.5.0.21/4.5.0.24 release
have you tried just to shut it down and boot again?
Serval times. The flash with the 4.4 version ends up with the encryption assistant but an unusable touchscreen.
That’s progress. As for unstable screen on boot - yes, that can happen. Happens on my devices as well once in a while. Sometimes have to reboot because of that
It is “normal” for the XZ3 that from time to time after boot, screen is completely disturbed by some pixelated image and I also once had problems with the encryption window and decided to skip the entire encryption.
Did the update to 4.5.0.24 on my xz2c finally and it went fine.
I have a XZ2c too. At these devices, all went fine.
