[defaultuser@Xperia10III ~]$ devel-su journalctl -u bluetooth
Password:
-- Logs begin at Sat 2022-06-18 10:57:21 CEST, end at Sat 2022-06-18 11:00:54 CE
ST. --
-- No entries --
After a failed try:
Password:
-- Logs begin at Sat 2022-06-18 10:57:21 CEST, end at Sat 2022-06-18 11:01:51 CE
ST. --
Jun 18 11:01:42 Xperia10III bluetoothd[4059]: bluetoothd[4059]: src/device.c:loa
d_gatt_db() No cache for 00:09:A7:34:03:AB
Jun 18 11:01:42 Xperia10III bluetoothd[4059]: src/device
.c:load_gatt_db() No cache for 00:09:A7:34:03:AB
Now I enabled in Settings > Systems > NFC > Buetooth Secure Simple Pairing (which was diabled by default)
Now the pairing worked at once.
Further test:
NFC disabled completely, disabled Bluetooth for short, enabled Bluetooth again
→ next pairing works (even with disabled NFC)
(Perhaps this enabling “Buetooth Secure Simple Pairing” helps in a car, too.
EDIT: It doesn’t improve the connection in my car.)
No, In my case it was like the following:
Only for the very first Bluetooth-connection of my headphone with a brand new SailfishOS on a Xperia 10 III it was necessary to enable NFC (both options) to establish the connection.
Every further connection now works with NFC disabled.
(EDIT: The same behaviour observed with a “Bose AE2” headphone.)
