Oh thanks for letting me know, I will test next time as regular user
A “friendlier” way to do it is systemctl --user restart pulseaudio (as defaultuser).
I do stop and start pulseaudio, i had better results with that
I’ve encountered this bug 3 times over the last two years of using XIII and ‘pulseaudio -k’ worked both times I was aware of it as an option, I think the more elaborate systemd calls should be used by the system itself if it’s possible to diagnose the situation happening without user actively not hearing anything
Unfortunately I experience it nearly daily, but killing pulseaudio as default user did the trick, thanks again to all of you. That’s a simple and doable workaround for me.
wow, that’s pretty much as reproducible as can be, pls contact jolla support, they will want your logs, with most of us experiencing it once per year you just cannot catch it in logs, almost daily is as good as it gets
but annoying during important phone calls
Yaeh, just like 112 failing when you really need it, but there is no good way to test, unless you want to end up on the fake 112 callers list
Please read @direc85 post, that’s the “right” workaround, and you can even use qCommand to make it an icon in your app drawer for quick access.
that’s just the same as ‘pulseaudio -k’, all he does is execs the same as defaultuser and using more chars
I disagree, ‘pulseaudio -k’ is a kill command, and that is like punching someone on the nose instead of nicely asking him to turn around.
Yeaa… I know the end result is the same, mostly…
Yeah in theory sure, in practice no as it will just restart
there is no magic pulseaudio happening here, whether you systemctl restart pulseaudio or pulseaudio -k end result is the same, it restarts always
And then again… why would you want to send a general to do the work of a private? It’s just not good practice.
Lets just agree to disagree, because my dog will start eating me if I don’t go for that walk.
I’ve no clue, but can guarantee you that pulseaudio -k ends up in the exact same restart state for pulseaudio, that has in its service file restart=always, so in theory if it’s broken (no audio) it should trigger that itself, buf it obviously doesn’t as people report hearing nothing, pls don’t terrorise your dog and give him a good excercise
Bug is still present on my 10III with latest SFOS version (4.6.0.11). Very annoying.
Its never happend when the gps is off.
Starting the gps for using in e.g. Pure Maps the issue with no sound and video in slowmotion will occurre shortly after. In the beginning I used the pulse command, but now I restart the phone to be sure.
either this or add it to the Utilities menu in settings
As mentioned here a manual restart action has been added to Sailfish utilities.
As this is a bug report tracked by Jolla, I strongly suggest fixing the actual issue rather than adding a manual workaround. How could manually restarting audio services prevent missed calls? People who are using Sailfish as a daily driver have probably implemented some automatic service restart, so who needs a manual restart? What we need is a fix!
If it was that easy it would already be done. Sheesh.
I can confirm that this is still happening to me in 4.6.0.13.
Because the different kinds of symptoms and observations are now spread over multiple threads, I’d like to re-iterate the categories of audio (routing) issues I’ve seen to make sure we’re on the same page:
audio routing: sink
- after some time with headphones plugged in, the output suddenly comes through the speakers despite the headphones still being plugged in
- I’ve never seen this mid-play of a song or audio track, only after stopping and resuming playback
- headphone jack plug detection still works, because if you had different volume levels set for headphones and speakers, the volume level still gets toggled when (un)plugging the jack
- alarm, usual case: when headphones are plugged in, the alarm sound is only played through headphones, not through speakers
- all other Sailfish devices play the alarm sound through the speaker as well
- alarm, special case: I just encountered a situation with headphones not being plugged in, where no alarm sound was played at all
- the output of
LANG=C pactl listis this:
Module #0 Name: module-keepalive Argument: Usage counter: n/a Properties: module.author = "Juho Hämäläinen" module.description = "Keepalive. Send cpu wakeup heartbeat while streams are active." module.version = "14.2.0" Module #1 Name: module-droid-card Argument: rate=48000 hw_volume=false unload_call_exit=true output_voip_rx=false record_voice_16k=true Usage counter: n/a Properties: module.author = "Juho Hämäläinen" module.description = "Droid card" module.version = "14.2.103" Module #2 Name: module-droid-hidl Argument: Usage counter: n/a Properties: module.author = "Juho Hämäläinen" module.description = "Droid AudioSystem passthrough" module.version = "14.2" Module #3 Name: module-meego-parameters Argument: cache=1 directory=/var/lib/nemo-pulseaudio-parameters use_voice=false Usage counter: n/a Properties: module.author = "Pekka Ervasti" module.description = "Meego parameters module" module.version = "14.2.31" Module #4 Name: module-meego-mainvolume Argument: virtual_stream=true unmute_delay=600 Usage counter: n/a Properties: module.author = "Juho Hämäläinen" module.description = "Nokia mainvolume module" module.version = "14.2.31" Module #5 Name: module-stream-restore-nemo Argument: restore_device=no restore_volume=yes restore_muted=no route_table=/etc/pulse/x-maemo-route.table fallback_table=/etc/pulse/x-maemo-stream-restore.table use_voice=false Usage counter: n/a Properties: module.author = "Lennart Poettering" module.description = "Automatically restore the volume/mute/device state of streams" module.version = "14.2.31" Module #6 Name: module-match Argument: table=/etc/pulse/x-maemo-match.table key=application.name Usage counter: n/a Properties: module.author = "Lennart Poettering" module.description = "Playback stream expression matching module" module.version = "14.2+git9" Module #7 Name: module-augment-properties Argument: Usage counter: n/a Properties: module.author = "Lennart Poettering" module.description = "Augment the property sets of streams with additional static information" module.version = "14.2+git9" Module #8 Name: module-null-sink Argument: sink_name=sink.null rate=48000 Usage counter: 0 Properties: module.author = "Lennart Poettering" module.description = "Getaktetes NULL-Ziel" module.version = "14.2+git9" Module #9 Name: module-null-source Argument: source_name=source.null rate=48000 Usage counter: n/a Properties: module.author = "Lennart Poettering & Marc-Andre Lureau" module.description = "Clocked NULL source" module.version = "14.2+git9" Module #10 Name: module-bluetooth-discover Argument: headset=droid Usage counter: n/a Properties: module.author = "João Paulo Rechi Vita" module.description = "Detect available Bluetooth daemon and load the corresponding discovery module" module.version = "14.2+git9" Module #11 Name: module-bluez5-discover Argument: headset=droid Usage counter: n/a Properties: module.author = "João Paulo Rechi Vita" module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers" module.version = "14.2+git9" Module #12 Name: module-policy-enforcement Argument: Usage counter: n/a Properties: module.author = "Janos Kovacs" module.description = "Policy enforcement module" module.version = "14.2.47" policy.sink_route.target = "ihf" policy.sink_route.mode = "ihf" policy.sink_route.hwid = "" policy.source_route.target = "microphone" policy.source_route.mode = "" policy.source_route.hwid = "" x-nemo.voicecall.status = "inactive" x-nemo.media.state = "inactive" x.emergency_call.state = "inactive" Module #13 Name: module-role-ducking Argument: trigger_roles=notification,warning ducking_roles=x-maemo volume=-12dB duck_while_corked=true Usage counter: n/a Properties: module.author = "Flavio Ceolin <flavio.ceolin@profusion.mobi>" module.description = "Apply a ducking effect based on streams roles" module.version = "14.2+git9" Module #14 Name: module-native-protocol-unix Argument: Usage counter: n/a Properties: module.author = "Lennart Poettering" module.description = "Native protocol (UNIX sockets)" module.version = "14.2+git9" Module #15 Name: module-always-sink Argument: Usage counter: n/a Properties: module.author = "Colin Guthrie" module.description = "Hält stets ein Ziel geladen, selbst wenn dies ein Null-Ziel ist" module.version = "14.2+git9" Module #16 Name: module-intended-roles Argument: Usage counter: n/a Properties: module.author = "Lennart Poettering" module.description = "Automatically set device of streams based on intended roles of devices" module.version = "14.2+git9" Module #17 Name: module-suspend-on-idle Argument: timeout=1 Usage counter: n/a Properties: module.author = "Lennart Poettering" module.description = "When a sink/source is idle for too long, suspend it" module.version = "14.2+git9" Module #18 Name: module-console-kit Argument: Usage counter: n/a Properties: module.author = "Lennart Poettering" module.description = "Create a client for each ConsoleKit session of this user" module.version = "14.2+git9" Module #19 Name: module-systemd-login Argument: Usage counter: n/a Properties: module.author = "Lennart Poettering" module.description = "Create a client for each login session of this user" module.version = "14.2+git9" Module #20 Name: module-dbus-protocol Argument: Usage counter: n/a Properties: module.author = "Tanu Kaskinen" module.description = "D-Bus interface" module.version = "14.2+git9" Sink #0 State: SUSPENDED Name: sink.primary_output Description: Droid sink primary output Driver: module-droid-card.c Sample Specification: s16le 2ch 48000Hz Channel Map: front-left,front-right Owner Module: 1 Mute: no Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB balance 0.00 Base Volume: 65536 / 100% / 0.00 dB Monitor Source: sink.primary_output.monitor Latency: 0 usec, configured 0 usec Flags: HARDWARE DECIBEL_VOLUME LATENCY Properties: device.description = "Droid sink primary output" device.class = "sound" device.api = "droid-hal" droid.flags = "" droid.hw_module = "primary" device.icon_name = "audio-card" droid.output.primary = "true" droid.output.low_latency = "true" droid.output.media_latency = "false" droid.output.voip = "true" Ports: output-parking: Parking port (type: Unknown, priority: 50, available) output-earpiece: Output to earpiece (type: Unknown, priority: 200, available) output-speaker: Output to speaker (type: Unknown, priority: 300, available) output-wired_headset: Output to wired headset (type: Unknown, priority: 100, available) output-wired_headphone: Output to wired headphone (type: Unknown, priority: 100, available) output-line: Output to line (type: Unknown, priority: 100, available) output-aux_digital: Output to aux digital (type: Unknown, priority: 100, available) output-proxy: Output to proxy (type: Unknown, priority: 100, available) output-fm: Output to fm (type: Unknown, priority: 100, available) output-bluetooth_sco: Output to bluetooth sco (type: Unknown, priority: 100, available) output-sco_headset: Output to sco headset (type: Unknown, priority: 100, available) output-sco_carkit: Output to sco carkit (type: Unknown, priority: 100, available) Active Port: output-speaker Formats: pcm Sink #1 State: SUSPENDED Name: sink.deep_buffer Description: Droid sink deep_buffer Driver: module-droid-card.c Sample Specification: s16le 2ch 48000Hz Channel Map: front-left,front-right Owner Module: 1 Mute: no Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB balance 0.00 Base Volume: 65536 / 100% / 0.00 dB Monitor Source: sink.deep_buffer.monitor Latency: 0 usec, configured 0 usec Flags: HARDWARE DECIBEL_VOLUME LATENCY Properties: device.description = "Droid sink deep_buffer" device.class = "sound" device.api = "droid-hal" droid.flags = "" droid.hw_module = "primary" device.icon_name = "audio-card" droid.output.media_latency = "true" x-maemo.mode = "ihf" x-maemo.accessory_hwid = "" Formats: pcm Sink #2 State: SUSPENDED Name: sink.null Description: Null-Ausgabe Driver: module-null-sink.c Sample Specification: s16le 2ch 48000Hz Channel Map: front-left,front-right Owner Module: 8 Mute: no Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB balance 0.00 Base Volume: 65536 / 100% / 0.00 dB Monitor Source: sink.null.monitor Latency: 0 usec, configured 0 usec Flags: DECIBEL_VOLUME LATENCY SET_FORMATS Properties: device.description = "Null-Ausgabe" device.class = "abstract" device.icon_name = "audio-card" Formats: pcm Source #0 State: SUSPENDED Name: sink.primary_output.monitor Description: Monitor of Droid sink primary output Driver: module-droid-card.c Sample Specification: s16le 2ch 48000Hz Channel Map: front-left,front-right Owner Module: 1 Mute: no Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB balance 0.00 Base Volume: 65536 / 100% / 0.00 dB Monitor of Sink: sink.primary_output Latency: 0 usec, configured 0 usec Flags: DECIBEL_VOLUME LATENCY Properties: device.description = "Monitor of Droid sink primary output" device.class = "monitor" droid.hw_module = "primary" device.icon_name = "audio-card" Formats: pcm Source #1 State: SUSPENDED Name: sink.deep_buffer.monitor Description: Monitor of Droid sink deep_buffer Driver: module-droid-card.c Sample Specification: s16le 2ch 48000Hz Channel Map: front-left,front-right Owner Module: 1 Mute: no Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB balance 0.00 Base Volume: 65536 / 100% / 0.00 dB Monitor of Sink: sink.deep_buffer Latency: 0 usec, configured 0 usec Flags: DECIBEL_VOLUME LATENCY Properties: device.description = "Monitor of Droid sink deep_buffer" device.class = "monitor" droid.hw_module = "primary" device.icon_name = "audio-card" Formats: pcm Source #2 State: SUSPENDED Name: source.primary_input Description: Droid source primary input Driver: module-droid-card.c Sample Specification: s16le 2ch 48000Hz Channel Map: front-left,front-right Owner Module: 1 Mute: no Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB balance 0.00 Base Volume: 65536 / 100% / 0.00 dB Monitor of Sink: n/a Latency: 0 usec, configured 0 usec Flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME Properties: device.description = "Droid source primary input" device.class = "sound" device.api = "droid-hal" droid.input.external = "true" droid.input.builtin = "true" droid.hw_module = "primary" device.icon_name = "audio-card" Ports: input-parking: Parking port (type: Unknown, priority: 50, available) input-builtin_mic: Input from builtin mic (type: Unknown, priority: 200, available) input-back_mic: Input from back mic (type: Unknown, priority: 200, available) input-wired_headset: Input from wired headset (type: Unknown, priority: 100, available) input-bluetooth_sco_headset: Input from bluetooth sco headset (type: Unknown, priority: 100, available) input-fm_tuner: Input from fm tuner (type: Unknown, priority: 100, available) input-voice_call: Input from voice call (type: Unknown, priority: 200, available) Active Port: input-builtin_mic Formats: pcm Source #3 State: SUSPENDED Name: sink.null.monitor Description: Monitor of Null-Ausgabe Driver: module-null-sink.c Sample Specification: s16le 2ch 48000Hz Channel Map: front-left,front-right Owner Module: 8 Mute: no Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB balance 0.00 Base Volume: 65536 / 100% / 0.00 dB Monitor of Sink: sink.null Latency: 0 usec, configured 0 usec Flags: DECIBEL_VOLUME LATENCY Properties: device.description = "Monitor of Null-Ausgabe" device.class = "monitor" device.icon_name = "audio-input-microphone" Formats: pcm Source #4 State: SUSPENDED Name: source.null Description: Null Input Driver: module-null-source.c Sample Specification: s16le 2ch 48000Hz Channel Map: front-left,front-right Owner Module: 9 Mute: no Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB balance 0.00 Base Volume: 65536 / 100% / 0.00 dB Monitor of Sink: n/a Latency: 0 usec, configured 0 usec Flags: DECIBEL_VOLUME LATENCY Properties: device.description = "Null Input" device.class = "abstract" device.icon_name = "audio-input-microphone" Formats: pcm Client #1 Driver: module-systemd-login.c Owner Module: 19 Properties: application.name = "Login Session 1" systemd-login.session = "1" Client #2 Driver: module-dbus-protocol.c Owner Module: 20 Properties: application.name = "D-Bus client" Client #3 Driver: module-dbus-protocol.c Owner Module: 20 Properties: application.name = "D-Bus client" Client #4 Driver: module-dbus-protocol.c Owner Module: 20 Properties: application.name = "D-Bus client" Client #5 Driver: protocol-native.c Owner Module: 14 Properties: application.name = "jolla keyboard" native-protocol.peer = "UNIX socket client" native-protocol.version = "34" policy.application.id = "242c" application.process.id = "3862" application.process.user = "defaultuser" application.process.host = "Xperia10III" application.process.binary = "booster-qt5" application.language = "de_DE.utf8" application.process.machine_id = "47277e2ae09045288c01e6c40865e95f" application.process.arg0 = "/usr/bin/maliit-server" Client #6 Driver: protocol-native.c Owner Module: 14 Properties: application.name = "QtPulseAudio:25" native-protocol.peer = "UNIX socket client" native-protocol.version = "34" policy.application.id = "26cf" application.process.id = "25" application.process.user = "defaultuser" application.process.host = "Xperia10III" application.process.binary = "voicecall-ui" application.language = "de_DE.utf8" application.process.machine_id = "Xperia10III" application.icon_name = "icon-launcher-phone" application.process.arg0 = "" Client #7 Driver: protocol-native.c Owner Module: 14 Properties: application.name = "ngf-tonegen-plugin" native-protocol.peer = "UNIX socket client" native-protocol.version = "34" policy.application.id = "238e" application.process.id = "3278" application.process.user = "defaultuser" application.process.host = "Xperia10III" application.process.binary = "ngfd" application.language = "C" application.process.machine_id = "47277e2ae09045288c01e6c40865e95f" application.process.arg0 = "/usr/bin/ngfd" Client #8 Driver: protocol-native.c Owner Module: 14 Properties: application.name = "AlienAudioService" native-protocol.peer = "UNIX socket client" native-protocol.version = "34" policy.application.id = "277d" application.process.id = "5270" application.process.user = "defaultuser" application.process.host = "Xperia10III" application.process.binary = "alienaudioservice" application.language = "C" application.process.machine_id = "47277e2ae09045288c01e6c40865e95f" application.process.arg0 = "/usr/bin/alienaudioservice" Client #9 Driver: module-dbus-protocol.c Owner Module: 20 Properties: application.name = "D-Bus client" Client #10 Driver: protocol-native.c Owner Module: 14 Properties: application.name = "libcanberra" native-protocol.peer = "UNIX socket client" native-protocol.version = "34" application.version = "0.30" application.id = "org.freedesktop.libcanberra" policy.application.id = "238e" application.process.id = "3278" application.process.user = "defaultuser" application.process.host = "Xperia10III" application.process.binary = "ngfd" application.language = "C" application.process.machine_id = "47277e2ae09045288c01e6c40865e95f" application.process.arg0 = "/usr/bin/ngfd" Client #27 Driver: protocol-native.c Owner Module: 14 Properties: application.name = "pactl" native-protocol.peer = "UNIX socket client" native-protocol.version = "34" policy.application.id = "6ba165" application.process.id = "27062" application.process.user = "defaultuser" application.process.host = "Xperia10III" application.process.binary = "pactl" application.language = "C" application.process.machine_id = "47277e2ae09045288c01e6c40865e95f" application.process.arg0 = "pactl" Sample #0 Name: pulldown_highlight Sample Specification: s16le 1ch 48000Hz Channel Map: mono Volume: (invalid) balance 0.00 Duration: 0.0s Size: 2.1 KiB Lazy: no Filename: n/a Properties: media.role = "event" event.id = "pulldown_highlight" media.name = "pulldown_highlight" media.filename = "/usr/share/sounds/jolla-ambient/stereo/pulldown_highlight.wav" application.name = "libcanberra" native-protocol.peer = "UNIX socket client" native-protocol.version = "34" application.version = "0.30" application.id = "org.freedesktop.libcanberra" policy.application.id = "238e" application.process.id = "3278" application.process.user = "defaultuser" application.process.host = "Xperia10III" application.process.binary = "ngfd" application.language = "C" application.process.machine_id = "47277e2ae09045288c01e6c40865e95f" application.process.arg0 = "/usr/bin/ngfd" Sample #1 Name: keyboard_0 Sample Specification: s16le 1ch 48000Hz Channel Map: mono Volume: (invalid) balance 0.00 Duration: 0.0s Size: 2.0 KiB Lazy: no Filename: n/a Properties: media.role = "event" media.name = "keyboard_0" application.name = "jolla keyboard" native-protocol.peer = "UNIX socket client" native-protocol.version = "34" policy.application.id = "242c" application.process.id = "3862" application.process.user = "defaultuser" application.process.host = "Xperia10III" application.process.binary = "booster-qt5" application.language = "de_DE.utf8" application.process.machine_id = "47277e2ae09045288c01e6c40865e95f" application.process.arg0 = "/usr/bin/maliit-server" Sample #2 Name: keyboard_1 Sample Specification: s16le 1ch 48000Hz Channel Map: mono Volume: (invalid) balance 0.00 Duration: 0.0s Size: 2.0 KiB Lazy: no Filename: n/a Properties: media.role = "event" media.name = "keyboard_1" application.name = "jolla keyboard" native-protocol.peer = "UNIX socket client" native-protocol.version = "34" policy.application.id = "242c" application.process.id = "3862" application.process.user = "defaultuser" application.process.host = "Xperia10III" application.process.binary = "booster-qt5" application.language = "de_DE.utf8" application.process.machine_id = "47277e2ae09045288c01e6c40865e95f" application.process.arg0 = "/usr/bin/maliit-server" Sample #3 Name: camera_shutter Sample Specification: s16le 1ch 48000Hz Channel Map: mono Volume: (invalid) balance 0.00 Duration: 0.4s Size: 41.4 KiB Lazy: no Filename: n/a Properties: media.role = "event" event.id = "camera_shutter" media.name = "camera_shutter" media.filename = "/usr/share/sounds/jolla-ambient/stereo/camera_shutter.wav" application.name = "libcanberra" native-protocol.peer = "UNIX socket client" native-protocol.version = "34" application.version = "0.30" application.id = "org.freedesktop.libcanberra" policy.application.id = "238e" application.process.id = "3278" application.process.user = "defaultuser" application.process.host = "Xperia10III" application.process.binary = "ngfd" application.language = "C" application.process.machine_id = "47277e2ae09045288c01e6c40865e95f" application.process.arg0 = "/usr/bin/ngfd" Sample #4 Name: start_charging Sample Specification: s16le 1ch 48000Hz Channel Map: mono Volume: (invalid) balance 0.00 Duration: 1.1s Size: 107.7 KiB Lazy: no Filename: n/a Properties: media.role = "event" event.id = "start_charging" media.name = "start_charging" media.filename = "/usr/share/sounds/jolla-ambient/stereo/start_charging.wav" application.name = "libcanberra" native-protocol.peer = "UNIX socket client" native-protocol.version = "34" application.version = "0.30" application.id = "org.freedesktop.libcanberra" policy.application.id = "238e" application.process.id = "3278" application.process.user = "defaultuser" application.process.host = "Xperia10III" application.process.binary = "ngfd" application.language = "C" application.process.machine_id = "47277e2ae09045288c01e6c40865e95f" application.process.arg0 = "/usr/bin/ngfd" Sample #5 Name: close_app Sample Specification: s16le 1ch 48000Hz Channel Map: mono Volume: (invalid) balance 0.00 Duration: 2.0s Size: 188.3 KiB Lazy: no Filename: n/a Properties: media.role = "event" event.id = "close_app" media.name = "close_app" media.filename = "/usr/share/sounds/jolla-ambient/stereo/close_app.wav" application.name = "libcanberra" native-protocol.peer = "UNIX socket client" native-protocol.version = "34" application.version = "0.30" application.id = "org.freedesktop.libcanberra" policy.application.id = "238e" application.process.id = "3278" application.process.user = "defaultuser" application.process.host = "Xperia10III" application.process.binary = "ngfd" application.language = "C" application.process.machine_id = "47277e2ae09045288c01e6c40865e95f" application.process.arg0 = "/usr/bin/ngfd" Card #0 Name: droid_card.primary Driver: module-droid-card.c Owner Module: 1 Properties: droid.hw_module = "primary" device.icon_name = "audio-card" Profiles: default: Default profile (sinks: 10, sources: 5, priority: 100, available: yes) voicecall: Call mode (sinks: 0, sources: 0, priority: 0, available: yes) voicecall-record: Call mode record (sinks: 0, sources: 0, priority: 0, available: yes) communication: Communication mode (sinks: 0, sources: 0, priority: 0, available: yes) ringtone: Ringtone mode (sinks: 0, sources: 0, priority: 0, available: yes) off: Off (sinks: 0, sources: 0, priority: 0, available: yes) Active Profile: default Ports: output-parking: Parking port (type: Unknown, priority: 50, latency offset: 0 usec, available) Part of profile(s): default output-earpiece: Output to earpiece (type: Unknown, priority: 200, latency offset: 0 usec, available) Part of profile(s): default output-speaker: Output to speaker (type: Unknown, priority: 300, latency offset: 0 usec, available) Part of profile(s): default output-wired_headset: Output to wired headset (type: Unknown, priority: 100, latency offset: 0 usec, available) Part of profile(s): default output-wired_headphone: Output to wired headphone (type: Unknown, priority: 100, latency offset: 0 usec, available) Part of profile(s): default output-line: Output to line (type: Unknown, priority: 100, latency offset: 0 usec, available) Part of profile(s): default output-aux_digital: Output to aux digital (type: Unknown, priority: 100, latency offset: 0 usec, available) Part of profile(s): default output-proxy: Output to proxy (type: Unknown, priority: 100, latency offset: 0 usec, available) Part of profile(s): default output-fm: Output to fm (type: Unknown, priority: 100, latency offset: 0 usec, available) Part of profile(s): default output-bluetooth_sco: Output to bluetooth sco (type: Unknown, priority: 100, latency offset: 0 usec, available) Part of profile(s): default output-sco_headset: Output to sco headset (type: Unknown, priority: 100, latency offset: 0 usec, available) Part of profile(s): default output-sco_carkit: Output to sco carkit (type: Unknown, priority: 100, latency offset: 0 usec, available) Part of profile(s): default input-parking: Parking port (type: Unknown, priority: 50, latency offset: 0 usec, available) Part of profile(s): default input-voice_call: Input from voice call (type: Unknown, priority: 200, latency offset: 0 usec, available) Part of profile(s): default input-builtin_mic: Input from builtin mic (type: Unknown, priority: 200, latency offset: 0 usec, available) Part of profile(s): default input-back_mic: Input from back mic (type: Unknown, priority: 200, latency offset: 0 usec, available) Part of profile(s): default input-wired_headset: Input from wired headset (type: Unknown, priority: 100, latency offset: 0 usec, available) Part of profile(s): default input-bluetooth_sco_headset: Input from bluetooth sco headset (type: Unknown, priority: 100, latency offset: 0 usec, available) Part of profile(s): default input-fm_tuner: Input from fm tuner (type: Unknown, priority: 100, latency offset: 0 usec, available) Part of profile(s): default- this might be due to the alarm sink being configured to the headphone jack? I haven’t tried plugging in my headphones at that time to check.
- the output of
audio routing: source
- internal microphone not used in calls when headphones are attached
- have headphones plugged in, just plain headphones with a TTS plug and without a mic of their own
- get an incoming call and answer it
- sometimes (not always) it happens that you hear the other side well, but they cannot hear you.
- unplugging the headphone jack resolves the situation by activating the internal mic again
audio broken
- after a while, starting/ resuming audio tracks won’t output any audio, neither via headphones nor speaker. The audio progress bar stays stuck
- I’ve only encountered this with headphones plugged in
- situation is recognisable by slight clicking noises in the headphones instead of the audio that is supposed to be played
- situation not resolved by just unplugging the headphones
The restart pulseaudio Sailfish Utils trigger is not that great of a workaround as it requires all audio-emitting apps to be restarted again. But it is able to (temporarily) resolve all the situations I’ve described.
