I have followed the instructions and successfully unlocked the booloader.
When I try to flash Sailfish X I receive an error (anonymised below).
sudo bash ./flash.sh
[sudo] password for :
Detected Linux
Searching device to flash…
Found XQ-AU51, serial:QV724**, baseband:, bootloader:
Found matching device with serial QV724*****
Fastboot command: fastboot -s QV724*****
You can try the getvar commands manually, if they only work intermittently, you are indeed hitting that issue. Try a port under another USB controller, preferably USB2, or a hub.
It just reads a variable from the bootloader config. I assume secure means locked.
I have flashed several phones on my desktop, but none of the ports coming off the (X570) motherboard work.
If i use my Asmedia ASM1142-based add-in card it works just fine.
I use Linux Mint, but others here definitely use Arch-based distros and have it working too.
You have a sample size of one, and no A/B testing… come on!
I’m reviving an ancient thread here. But it was the first I found. Ran into the same problem as OP. Using an USB hub solved the problem. Must be something to do with the USB-type.
Seems like this thread revives itself from time to time. Have stumbled into the exact same problem. Also am running Manjaro and also trying to flash to an Xperia 10 II. Can anyone confirm a successful flash from Manjaro? Or is it the USB-interface type? I don’t have Windows around, so I’ll try different computers …
