Hello, i am a satisfied Xperia X user, but since android 4.4 is becoming legacy for apps, i have decided to buy a used but less than year old xperia 10 nonplus for a nice deal of less than 100 euro. But on the other hand i am afraid that i have made a mistake, as after the buy i have read on some forum about horrific battery life in SFOS. Some user, who have bought a license, claims that his 10 lasts only about 3 hours screen time (i didn’t ask about the 3/4g network used, though), while on android it lasts for about 7 hours. As for Xperia X, the SFOS has doubled the battery life in comparison to Android, so i found this claim strange. So, firstly, i would like to ask a question of the screen on time of yours 10s, is it so horrific or not? Yes, i know, that in comparison to 10 hours of my 4Amper Xiaomi the 2.8A device life is a lot smaller, but is it SO small? Should i trade it and buy an XA2 instead? (The XA2 design is IMHO too outdated compared to 10). As the license is for one user only, i do not want to buy the license and waste 50euro unsatisfied with battery life, not able to sell the license to another user.
And second question - i know there is a free version without Dalvik and support, i have justgl grabbed the link, but have not yet decided to download. What does the lack of support mean in case of the version number? Is it the latest 3.4 without an ability to upgrade OTA, or the version which was actual on the Xperia 10 launch, or something another? Just to ensure, do flatpaks work with it?
Thanks in advance.
free os has no alien dalvik, no microsoft exchange and no t9 as often already stated.
else it is the same, you will just not be able to install those features.
regarding devices:
i had x and i do have x10.
the overall quality of x was great in comparison to x10.
the camera quality is much better with x10 but as the camera broke just recently …
i have had the digitizer issue and due to bending of the device to enable touch again, the case is already broken …
the battery finally: imho experia x was better, then x10 and with 3.4 the battery life even further worsened for me.
i do recharge nowadays 1-2 a day.
personally i would wait for the next device.
Thanks, but could you tell me about screen-on time in hours? Is it three hours or diffenetly better?
And what os version is in free os? Or is it just normal 3.4 that can be updated, only without dalvik and exchange?
The free version is exactly the same as with license, except the features @pawel.spoon mentioned. You can download and flash it for your device and test the battery life yourself for your phone. And if you like it, you can then buy the license, and after a reboot you should be able to install the paid features from the Jolla Store, no need to reflash again.
I had an X and now have an X10, also with an official license.
Battery life is bad indeed. In my opinion it all boils down to the wifi.
Tried with and without 4G, with and without alien dalvik. And in the end it did not change much.
With wifi turned off it is ok and can last for a day or two. With the wifi on it is probably around half a day, like 12+ hours. Screen on time might be 3-4 hours idd.
I don’t really know what the issue is, I should search the forum some more about that, but it does have to do with awful (as in no) wifi power management. So I still hope this can be fixed, because apart from that, it is an improvement in every way compared to my xperia X.
How so? The screen is worse (not much, but still), headphone audio is worse (not much, but still), height is awful (comparing to X), buttons are worse, battery is awful.
Only android 8.1 is better.
Hello - I have also the Sony Xperia X Dual and I have solve the battery problem under 3.4 with folow steps:
- Sony reset Power+Volume up 8s hold (3x vibration)
- I install the patch “tracker path settings” and add some ignorded phaths e.g. the mp3 paths and all other big paths without picures and videos
- I install the app shell ex and add the command “mcetool -sdisabled” (Reset Blockig Device Suspend)
Now all is fine you can check or compare (before and after) this with the app SystemDataScope.Also the app crest let you see wich process loads the cpu very much. I hope its help somebody.
Greetings Ralf
Hi
I own a XA2 Dual SIM with SFOS for nearly two years now. From battery hardware it has 3.2Ah/h so it is a little better than the Xperia 10 Plus with 3Ah/h and the Xperia 10 with 2.87Ah/h. Not long ago I bought a used Xperia 10 plus and installed the trial SFOS.
Since the last update the battery of the XA2 drains much faster than before. With average use it now last a day with one charge. Before the update it was two days.
The Xperia 10 Plus I can not compare before and after updating but it do not last as long as the XA2.
So after all regarding hardware the condition of the Xperia 10 is the worst for a long battery life especially after this not really satisfying update.
In my opinion the best results you get with an XA2 with a battery in a good condition.
mcetool command not found on 3.4
Sorry I forgott this:
devel-su [passwd, hidden writing]
pkcon install mce-tools
see also here:https://together.jolla.com/question/166938/double-tap-on-sailfish-x/
with mcetool you can change many settings…
If you have insalled for the command “mcetool - sdisabled” you need no root.
thanks i thought its part of std os
one hint to add: don’t know if 3.4 is still affected but in the past, automatic brightness adjustment ate a lot of battery too on X10 because of a misbehaving sensor.
It’s best to turn that off.
… with follow commands you can find more options of mcetool
“mcetool --long-help” or “mcetool -H” (its the same)
“mcetool --help” or "mcetool -h (its the same)
and with this you can see your original settings - its better to copy this from terminal in es txt file, then you can set its back if you have problems:
“mcetool --status”
for the Battery life also follow settings important:
“mcetool --set-cpu-scaling-governor=automatic”
“mcetool -searly”
For Xperia 10 there are 3 main issues that I find weak:
- power consumption (need to load battery at least once in 24h, and my screentime is way less than 3 hours, and it is worse with SF 3.4 than ist was with SF 3.3)
- very slow fix of GPS
- random reboots (was very bad with SF 3.2, improved a lot with SF 3.3 and has worsened a bit with 3.4 when USB tethering seems to be one of culprits)
But nevertheless… from currently available hardware+software combos for me its seems to be the best “daily driver” available.
i did turn it off months ago. lets say my battery is weak
You are right!
I do miss the stereo speakers, and although I like the bigger screen, it is less practical and not as good as the Xperia X’s. Bluetooth works properly though, which wasn’t the case on the X.
But it is mostly the android 8.1 support which makes it the better phone for me. So it is not as black and white as I stated before.
I really can’t complain about X10’s (ds, no sd) battery life: VPN always connected, bt and mobile data always on, wlan always off, nfc off, , amazfish constantly connected over bt). A lot of use. I get 2 whole days with 11 apps running. Airplane mode at night for 6 hours. What really matters is setting email sync to twice a day instead of push. I never had an android device working that long, even with much bigger batteries. X10plus is worse (30% left in the evening with same apps and settings) due to bigger screen and faster soc (ds, with sd)
That does kind of confirm that it mostly has to do with wifi.
Is it possible that there is no power management for the wifi chip, or there is a bug that drains the battery when on wifi?
Can we open a bug report somewhere about that, or is it too vague?
I think it is too vague. As I stated: the plus version is far worse with same settings. Has anyone tried newer android or iphones? They definately do not last any longer than SFOS devices. By constantly sending tracking data they are actually worse.
I really do not think there is anything to comlain, espessially if we compare to other linux phones (Librem 2 hours max, lol)
Hi all,
Another new Xperia 10 plus owner here, also jumping from an Xperia X… I was happy with the X as a phone but being stuck on Android 4 meant no new versions of Firefox, which is the main application I use. It was bought second hand of apparent light use for about 150 quid and unfortunately came with Android 10 but was able to put it back to 9 using Emma before installing SFOS.
Two complaints nothing to do with SFOS… I agree the screen is not good, everything looks blue compared to the X, cold LED backlight likely to blame. As the screen is so long it is difficult to keep it balanced and text on, accuracy is currently much worse than the X.
Vibration does not work well at all… the motor does work in VibrationTest, but haptic feedback is mostly noise rather than vibration and if typing rapidly it seems to just give up totally and go silent. The alarm vibration is horrible and makes a sort of “eeeeee-eeeewww” noise very different to the X.
The only visible hardware improvements over the X are CPU speed, camera performance, and having slightly more screen estate… everything else seems like a downgrade.
Firefox 82.1.3 from the Android Store works but no luck using the APK directly from Mozilla. XPIs wouldn’t open (have to install from Addons) and neither will PDFs open from the Downloads page which is a regular use case for me. Downloads themselves from Firefox don’t work properly… repeated notifications saying
“Downloads
null”
every second or so. The only way to stop it is to close Firefox. When it is reopened, the file will successfully download, until the next attempted download where you need to repeat closing the app and reopening it.
Back to the topic of battery life… my experience is very poor here. I am barely using the phone at all with WiFi and 4G enabled, decent strength signals - maybe 10 mins of browsing, no calls, just a few texts, and it will barely last a day, which as a vague guess is about half the battery life of the X. Adaptive brightness is turned a fair way down, screen is no brighter than what the X was.
There is a fast microSD card installed formatted to ext4 with lots of music on. I know the X had an apparent problem with searching the card which was particularly noticeable in some Android apps, where everything would slow right down… hard to say if the 10+ is doing the same… it is certainly not as bad, but turning off scanning might be beneficial?
I’d like to assist in gathering some data on the problem… unfortunately Battery Log doesn’t appear to work properly on the 10+… it can gather Current and Voltage but Energy sits at 0 mWh and seems to be missing data from the API calls.
With all Android and all other apps stopped and 4G+WiFi on with the screen at a moderate level, Battery log is showing it pulling around 364-460mA with tapping the screen every second or so… this seems like a huge amount of current to be doing nothing. Putting the unit into Flight mode dropped this to 338-442mA.
The X in comparison shows around 124-155mA with WiFi enabled, also tapping to keep the screen awake. It’s no wonder the 10+ battery dies so quickly in comparison!
Anyone else got figures to share? I’d like to understand if this is typical for the 10+ or not, and how much difference some of the suggestions made here will help to dramatically lower power consumption. If it cannot be addressed, I guess I’ll have no choice but to give up and move the phone to LineageOS, which would be a shame. Thanks!
