Wrong drop shadow on battery saving icon
BUILD ID = OS VERSION (Settings > About product): 4.1.024
HARDWARE (XA2, Xperia 10…): Xperia X
UI LANGUAGE: German
In battery saving mode, the leaf icon has a square drop shadow, while for all other icons the drop shadow follows the icon shape outline.
(Admittedly it is a trivial issue, but since my battery is getting old I see this a lot, and it kind of annoys me every time.)
none
  1. Enable battery saving mode in Settings
  2. Observe system status icon in Home or Lock Screen
Leaf icon should have a drop shadow following the leaf shape outline.
Leaf icon has a square drop shadow.
Screenshot of square drop shadow on leaf icon, in comparison to outline drop shadow of alarm bell icon.
sfos_energy_saving
Yes, same here,
XA2 Dial 4.5.0.16.
Screenshot_20230222_001_edit
It’s how it’s meant to be. This question was also posted back in the days of TJC. Don’t expect to see it changed.
As you find it so annoying, why don’t you extract the icon, edit it and put it back.
It’s my fault. I ask him if he see the icon to report as I didn’t know the official answer. So now it can be marked as closed.
If that is how its supposed to be, I am good with it. Yes, can be closed.
I’m assuming you know how to backup your original and copy the new to a directory.
The original icon is found in;
/usr/share/themes/sailfish-default/meegotouch/z1.75/icons
named;
revised powersave icon from my dropbox
Thanks for the revised icon, much appreciated!
