So, back in the old jolla 1 days, contrary to android, gps just started automatically after an app requested it, and then closed itself when none was requiring it, while on android when you turn it on it’s always on
Now the question is, if i enable gps (via the quick settings menu, for example), will it just start itself when (example) Pure maps request it or will it stay on like android? (althought i guess not, cause the icon is only present when a map app is open)
And least but not last, will it drain more battery (in the first case)?
