Wifi screen mirroring on Miracast/Airplay projector
Hi, I’d like to mirror my 2026 Jolla phone over Wi-Fi to a projector that supports AirPlay/Miracast so I can watch movies. Does anyone know how I can do this? Thanks a lot!
Try the Imira-app
Hi, thanks! it shows “streaming “, but nothing appears on screen (projector keeps saying “connection in progress”)
It does work with my Xperia 10 II via a Microsoft Wireless Display Adapter. The connection was succesful on the second attempt (let the app try after the initial failure), which took about a minute. That is the time it takes a windows laptop with intel wifi chip to do the same.
Also works the same on an LG tv with webOS. But when not having any audio, there is some weird background noise.
Hi, thank you I just ordered one, I will try ASAP
I tried with Samsung TV, seems to start casting but nothing is visible.
Imira is very experimental and tested so far only with the Microsoft Wireless Display Adapter V2 and LG webOS TVs (Xperia10III and J2). Projectors and Samsung TVs are new territory.
@Alesy2a @Gepardi55: “streaming” only means Wi-Fi Direct is up; the handshake with the TV can still fail. Please:
  1. Make sure you updated to 0.10.4 (Jolla Phone 2026 needs ≥ 0.10.2)
  2. Cast, wait 30 s, stop
  3. devel-su, then cat /tmp/imira-proto.log /tmp/imira-connect.log
  4. Post the output + TV/projector model here or on GitHub (replace MAC addresses with xx)
@xmasjos: Nice that it works on the 10 II! Is the noise there only while nothing is playing?
Hi, thank you for repky, the log from imira is this:
prov_disc xx:xx:xx:xx:xx:xx: OK
connect xx:xx:xx:xx:xx:xx: FAIL
versuch 1 fehlgeschlagen
versuch 2 fehlgeschlagen
versuch 3 fehlgeschlagen
versuch 4 fehlgeschlagen
FresHDEW 5G WiFi Projector with Bluetooth, Native 1080P, 26000L LCD Technology, Home Cinema Outdoor Video Projector with Tripod for iOS/Android/TV Stick
Thx
Here is my logs (Samsung 6 Series (50) TV:
[root@JollaPhone2026 defaultuser]# cat /tmp/imira-proto.log
14:29:05 == warte auf RTSP-Verbindung des Sinks auf Port 7236
[root@JollaPhone2026 defaultuser]# cat /tmp/imira-connect.log
connect xx:xx:xx:xx:xx:xx: OK
@Alesy2a @Gepardi55 I uploaded 0.10.5, please update and test/report. Please enable log:**About → Diagnostics → switch on “Detailed log”, try a cast, then “Create report” and paste the report here. It’s anonymized, but please glance over it before posting.
While casting, use a 2.4 GHz Wi-Fi or disconnect from Wi-Fi – hopping between two channels causes dropouts.
This time I didn’t get Streaming state with version 0.10.5 for some reason but here are logs:
Imira diagnostic report
created: 2026-09-27 18:09:22 UTC
imira: 0.10.5-1
Sailfish OS: 5.2.0.17 (Finlayson)
device: Jolla Jolla Phone
kernel: 6.12.38-4k
wpa_supplicant: wpa_supplicant v2.11
cast interface: p2p0 (driver -), wlan0 driver wlan
udhcpc: yes
phone Wi-Fi: connected on 5180 MHz
settings: mode mirror, resolution 1080, receiver ce:6e:a4:xx:xx:01, detailed log on, survey off
flags in /etc/imira: none
last status: reporting 0 0 -
Anonymized: MAC addresses cut to the vendor part, names of other
devices, network names, serial numbers, UUIDs and public IP addresses
removed. Please look it over before posting it.
===== diagnostic scan (receivers nearby) =====
2026-09-27 21:09:03 diagnostic scan on p2p0
p2p status: wpa_state=DISCONNECTED p2p_device_address=02:56:a8:xx:xx:02
peer ce:6e:a4:xx:xx:01 [sink]: pri_dev_type=7-0050F204-1 device_name=[TV] Samsung 6 Series (50) manufacturer=SAMSUNG_ELECTRONICS model_name= model_number= config_methods=0x188 dev_capab=0x21 group_capab=0x0 level=0 listen_freq=2412 interface_addr=00:00:00:00:00:00 member_in_go_dev=00:00:00:00:00:00 oper_freq=0 flags=[REPORTED] wfd_subelems=00000601131c440036
1 peer(s) found
===== connect log =====
prov_disc ce:6e:a4:xx:xx:01: OK
connect ce:6e:a4:xx:xx:01: OK
2026-09-27 21:07:15 === cast start: imira 0.10.5-1, iface p2p0, mode mirror, res 1080, wpa log debug, peer ce:6e:a4:xx:xx:01
2026-09-27 21:07:24 session attempt 1
21:07:24 phone Wi-Fi on 5180 MHz: asking the receiver for the same channel (one radio, no channel hopping)
21:07:24 attempt 1/4: searching for ce:6e:a4:xx:xx:01
21:07:28 attempt 1: sink ce:6e:a4:xx:xx:01 found after 4 s
21:07:28 peer: pri_dev_type=7-0050F204-1 device_name=[TV] Samsung 6 Series (50) manufacturer=SAMSUNG_ELECTRONICS model_name= model_number= config_methods=0x188 dev_capab=0x21 group_capab=0x0 level=0 listen_freq=2412 interface_addr=00:00:00:00:00:00 member_in_go_dev=00:00:00:00:00:00 oper_freq=0 flags=[REPORTED] wfd_subelems=00000601131c440036
21:07:28 prov_disc ce:6e:a4:xx:xx:01 pbc: OK
21:07:30 connect ce:6e:a4:xx:xx:01 pbc go_intent=0 freq=5180: OK
21:07:33 attempt 1: group up after 2 s: p2p-p2p0-0 client ssid=“DIRECT-PX[TV] Samsung 6 Series (” freq=5180 go_dev_addr=ce:6e:a4:xx:xx:01
21:07:33 radio: cast and phone Wi-Fi share 5180 MHz (good)
21:07:33 dhcp: lease 192.168.49.20 - 192.168.49.1 24 864000
21:07:33 address: 192.168.49.20/24, sink 192.168.49.1 (source: dhcp)
wpa: 1790532449.263507: P2P: Failed to send Action frame
wpa: 1790532449.427550: P2P-PROV-DISC-PBC-RESP ce:6e:a4:xx:xx:01
wpa: 1790532451.797264: P2P: GO Negotiation rejected: status 1
wpa: 1790532452.069752: P2P-GO-NEG-SUCCESS role=client freq=5180 ht40=0 peer_dev=ce:6e:a4:xx:xx:01 peer_iface=ce:6e:a4:xx:xx:01 wps_method=PBC
wpa: 1790532452.082155: p2p-p2p0-0: WPS-PBC-ACTIVE
wpa: 1790532452.305314: p2p-p2p0-0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
wpa: 1790532452.310755: p2p-p2p0-0: CTRL-EVENT-EAP-STARTED EAP authentication started
wpa: 1790532452.313296: p2p-p2p0-0: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=1
wpa: 1790532452.313342: p2p-p2p0-0: CTRL-EVENT-EAP-METHOD EAP vendor 14122 method 1 (WSC) selected
wpa: 1790532452.403163: p2p-p2p0-0: WPS-CRED-RECEIVED
wpa: 1790532452.403316: p2p-p2p0-0: WPS-SUCCESS
wpa: 1790532452.403436: P2P-GROUP-FORMATION-SUCCESS
wpa: 1790532452.414799: p2p-p2p0-0: CTRL-EVENT-EAP-FAILURE EAP authentication failed
wpa: 1790532452.417837: nl80211: send_event_marker failed: Source based routing not supported
wpa: 1790532452.417956: p2p-p2p0-0: CTRL-EVENT-DISCONNECTED bssid=ce:6e:a4:xx:xx:01 reason=3 locally_generated=1
wpa: 1790532452.421266: p2p-p2p0-0: CTRL-EVENT-DSCP-POLICY clear_all
wpa: 1790532452.460222: p2p-p2p0-0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
wpa: 1790532452.512258: p2p-p2p0-0: CTRL-EVENT-CONNECTED - Connection to ce:6e:a4:xx:xx:01 completed [id=0 id_str=]
wpa: 1790532452.513000: P2P-GROUP-STARTED p2p-p2p0-0 client ssid=“DIRECT-PX[TV] Samsung 6 Series (” freq=5180 go_dev_addr=ce:6e:a4:xx:xx:01
2026-09-27 21:07:33 net: p2p-p2p0-0 192.168.49.20/24
2026-09-27 21:07:33 net: route to sink: 192.168.49.1 dev p2p-p2p0-0 src 192.168.49.20 uid 0
2026-09-27 21:07:33 net: sink 192.168.49.1 answers ping
2026-09-27 21:07:46 === cast start: imira 0.10.5-1, iface p2p0, mode mirror, res 1080, wpa log debug, peer ce:6e:a4:xx:xx:01
2026-09-27 21:07:55 session attempt 1
21:07:55 phone Wi-Fi on 5180 MHz: asking the receiver for the same channel (one radio, no channel hopping)
21:07:55 attempt 1/4: searching for ce:6e:a4:xx:xx:01
21:07:59 attempt 1: sink ce:6e:a4:xx:xx:01 found after 4 s
21:07:59 peer: pri_dev_type=7-0050F204-1 device_name=[TV] Samsung 6 Series (50) manufacturer=SAMSUNG_ELECTRONICS model_name= model_number= config_methods=0x188 dev_capab=0x21 group_capab=0x0 level=0 listen_freq=2412 interface_addr=00:00:00:00:00:00 member_in_go_dev=00:00:00:00:00:00 oper_freq=0 flags=[REPORTED] wfd_subelems=00000601131c440036
21:07:59 prov_disc ce:6e:a4:xx:xx:01 pbc: OK
21:08:01 connect ce:6e:a4:xx:xx:01 pbc go_intent=0 freq=5180: OK
21:08:03 attempt 1: group up after 2 s: p2p-p2p0-0 client ssid=“DIRECT-Fb[TV] Samsung 6 Series (” freq=5180 go_dev_addr=ce:6e:a4:xx:xx:01
21:08:03 radio: cast and phone Wi-Fi share 5180 MHz (good)
21:08:03 dhcp: lease 192.168.49.20 - 192.168.49.1 24 864000
21:08:03 address: 192.168.49.20/24, sink 192.168.49.1 (source: dhcp)
wpa: 1790532479.587977: P2P-PROV-DISC-PBC-RESP ce:6e:a4:xx:xx:01
wpa: 1790532479.770248: P2P: Scan request schedule failed
wpa: 1790532481.581115: P2P: GO Negotiation rejected: status 1
wpa: 1790532481.850468: P2P-GO-NEG-SUCCESS role=client freq=5180 ht40=0 peer_dev=ce:6e:a4:xx:xx:01 peer_iface=ce:6e:a4:xx:xx:01 wps_method=PBC
wpa: 1790532481.863187: p2p-p2p0-0: WPS-PBC-ACTIVE
wpa: 1790532482.088450: p2p-p2p0-0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
wpa: 1790532482.092912: p2p-p2p0-0: CTRL-EVENT-EAP-STARTED EAP authentication started
wpa: 1790532482.095532: p2p-p2p0-0: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=1
wpa: 1790532482.095577: p2p-p2p0-0: CTRL-EVENT-EAP-METHOD EAP vendor 14122 method 1 (WSC) selected
wpa: 1790532482.208640: p2p-p2p0-0: WPS-CRED-RECEIVED
wpa: 1790532482.208747: p2p-p2p0-0: WPS-SUCCESS
wpa: 1790532482.208910: P2P-GROUP-FORMATION-SUCCESS
wpa: 1790532482.220237: p2p-p2p0-0: CTRL-EVENT-EAP-FAILURE EAP authentication failed
wpa: 1790532482.223064: nl80211: send_event_marker failed: Source based routing not supported
wpa: 1790532482.223222: p2p-p2p0-0: CTRL-EVENT-DISCONNECTED bssid=ce:6e:a4:xx:xx:01 reason=3 locally_generated=1
wpa: 1790532482.225179: p2p-p2p0-0: CTRL-EVENT-DSCP-POLICY clear_all
wpa: 1790532482.268173: p2p-p2p0-0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
wpa: 1790532482.321102: p2p-p2p0-0: CTRL-EVENT-CONNECTED - Connection to ce:6e:a4:xx:xx:01 completed [id=0 id_str=]
wpa: 1790532482.323175: P2P-GROUP-STARTED p2p-p2p0-0 client ssid="DIRECT-Fb[TV] Samsung 6 Series (" freq=5180 go_dev_addr=ce:6e:a4:xx:xx:01
2026-09-27 21:08:03 net: p2p-p2p0-0 192.168.49.20/24
2026-09-27 21:08:03 net: route to sink: 192.168.49.1 dev p2p-p2p0-0 src 192.168.49.20 uid 0
2026-09-27 21:08:03 net: sink 192.168.49.1 answers ping
2026-09-27 21:08:19 === cast start: imira 0.10.5-1, iface p2p0, mode mirror, res 1080, wpa log debug, peer ce:6e:a4:xx:xx:01
2026-09-27 21:08:27 session attempt 1
21:08:27 phone Wi-Fi on 5180 MHz: asking the receiver for the same channel (one radio, no channel hopping)
21:08:27 attempt 1/4: searching for ce:6e:a4:xx:xx:01
21:08:33 attempt 1: sink ce:6e:a4:xx:xx:01 found after 6 s
21:08:33 peer: pri_dev_type=7-0050F204-1 device_name=[TV] Samsung 6 Series (50) manufacturer=SAMSUNG_ELECTRONICS model_name= model_number= config_methods=0x188 dev_capab=0x21 group_capab=0x0 level=0 listen_freq=2412 interface_addr=00:00:00:00:00:00 member_in_go_dev=00:00:00:00:00:00 oper_freq=0 flags=[REPORTED] wfd_subelems=00000601131c440036
21:08:33 prov_disc ce:6e:a4:xx:xx:01 pbc: OK
21:08:35 connect ce:6e:a4:xx:xx:01 pbc go_intent=0 freq=5180: OK
21:08:38 attempt 1: group up after 2 s: p2p-p2p0-0 client ssid=“DIRECT-Fk[TV] Samsung 6 Series (” freq=5180 go_dev_addr=ce:6e:a4:xx:xx:01
21:08:38 radio: cast and phone Wi-Fi share 5180 MHz (good)
21:08:38 dhcp: lease 192.168.49.20 - 192.168.49.1 24 864000
21:08:38 address: 192.168.49.20/24, sink 192.168.49.1 (source: dhcp)
wpa: 1790532514.116552: P2P-PROV-DISC-PBC-RESP ce:6e:a4:xx:xx:01
wpa: 1790532514.300481: P2P: Scan request schedule failed
wpa: 1790532516.140645: P2P: GO Negotiation rejected: status 1
wpa: 1790532516.380677: P2P-GO-NEG-SUCCESS role=client freq=5180 ht40=0 peer_dev=ce:6e:a4:xx:xx:01 peer_iface=ce:6e:a4:xx:xx:01 wps_method=PBC
wpa: 1790532516.393727: p2p-p2p0-0: WPS-PBC-ACTIVE
wpa: 1790532516.624507: p2p-p2p0-0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
wpa: 1790532516.636360: p2p-p2p0-0: CTRL-EVENT-EAP-STARTED EAP authentication started
wpa: 1790532516.641023: p2p-p2p0-0: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=1
wpa: 1790532516.641110: p2p-p2p0-0: CTRL-EVENT-EAP-METHOD EAP vendor 14122 method 1 (WSC) selected
wpa: 1790532516.767663: p2p-p2p0-0: WPS-CRED-RECEIVED
wpa: 1790532516.767768: p2p-p2p0-0: WPS-SUCCESS
wpa: 1790532516.767932: P2P-GROUP-FORMATION-SUCCESS
wpa: 1790532516.781946: p2p-p2p0-0: CTRL-EVENT-EAP-FAILURE EAP authentication failed
wpa: 1790532516.785008: nl80211: send_event_marker failed: Source based routing not supported
wpa: 1790532516.785167: p2p-p2p0-0: CTRL-EVENT-DISCONNECTED bssid=ce:6e:a4:xx:xx:01 reason=3 locally_generated=1
wpa: 1790532516.787452: p2p-p2p0-0: CTRL-EVENT-DSCP-POLICY clear_all
wpa: 1790532516.830166: p2p-p2p0-0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
wpa: 1790532516.886162: p2p-p2p0-0: CTRL-EVENT-CONNECTED - Connection to ce:6e:a4:xx:xx:01 completed [id=0 id_str=]
wpa: 1790532516.888106: P2P-GROUP-STARTED p2p-p2p0-0 client ssid=“DIRECT-Fk[TV] Samsung 6 Series (” freq=5180 go_dev_addr=ce:6e:a4:xx:xx:01
2026-09-27 21:08:38 net: p2p-p2p0-0 192.168.49.20/24
2026-09-27 21:08:38 net: route to sink: 192.168.49.1 dev p2p-p2p0-0 src 192.168.49.20 uid 0
2026-09-27 21:08:38 net: sink 192.168.49.1 answers ping
===== RTSP handshake, current attempt =====
(empty)
===== RTSP handshake, earlier attempts =====
===== wpa_supplicant log (latest run) =====
(1345 of 2129 lines kept)
1790532545.051578: Initializing interface ‘p2p0’ conf ‘/etc/imira/wpa.conf’ driver ‘nl80211’ ctrl_interface ‘N/A’ bridge ‘N/A’
1790532545.053213: nl80211: Using driver-based off-channel TX
1790532545.053221: nl80211: TDLS channel switch
1790532545.053415: nl80211: Use separate P2P group interface (driver advertised support)
1790532545.053418: nl80211: Enable multi-channel concurrent (driver advertised support)
1790532545.053425: nl80211: interface p2p0 in phy phy0
1790532545.053485: nl80211: Set mode ifindex 37 iftype 2 (STATION)
1790532545.055360: Add interface p2p0 to a new radio phy0
1790532545.058215: p2p0: Own MAC address: 02:56:a8:xx:xx:02
1790532545.058355: wpa_driver_nl80211_set_key: ifindex=37 (p2p0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0 key_flag=0x10 link_id=-1
1790532545.058508: wpa_driver_nl80211_set_key: ifindex=37 (p2p0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0 key_flag=0x10 link_id=-1
1790532545.058567: wpa_driver_nl80211_set_key: ifindex=37 (p2p0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0 key_flag=0x10 link_id=-1
1790532545.058611: wpa_driver_nl80211_set_key: ifindex=37 (p2p0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0 key_flag=0x10 link_id=-1
1790532545.058650: wpa_driver_nl80211_set_key: ifindex=37 (p2p0) alg=0 addr=(nil) key_idx=4 set_tx=0 seq_len=0 key_len=0 key_flag=0x10 link_id=-1
1790532545.058690: wpa_driver_nl80211_set_key: ifindex=37 (p2p0) alg=0 addr=(nil) key_idx=5 set_tx=0 seq_len=0 key_len=0 key_flag=0x10 link_id=-1
1790532545.058719: p2p0: RSN: flushing PMKID list in the driver
1790532545.058746: p2p0: State: DISCONNECTED → INACTIVE
1790532545.059024: TDLS: Driver supports TDLS channel switching
1790532545.059140: p2p0: WPS: UUID based on MAC address:
1790532545.062667: EAPOL: SUPP_PAE entering state DISCONNECTED
1790532545.062674: EAPOL: Supplicant port status: Unauthorized
1790532545.062683: EAPOL: KEY_RX entering state NO_KEY_RECEIVE
1790532545.062686: EAPOL: SUPP_BE entering state INITIALIZE
1790532545.062954: P2P: Add operating class 81
1790532545.062976: P2P: Add operating class 115
1790532545.062983: P2P: Add operating class 116
1790532545.062989: P2P: Add operating class 117
1790532545.062994: P2P: Add operating class 124
1790532545.063000: P2P: Add operating class 125
1790532545.063006: P2P: Add operating class 126
1790532545.063011: P2P: Add operating class 127
1790532545.063018: P2P: Add operating class 128
1790532545.063032: P2P: Add operating class 129
1790532545.063042: P2P: Add operating class 130
1790532545.063144: P2P: Own listen channel: 81:6
1790532545.063189: P2P: Random operating channel: 81:6
1790532545.063268: P2P: initialized
1790532545.063315: P2P: channels: 81:1,2,3,4,5,6,7,8,9,10,11,12,13 115:36,40,44,48 116:36,44 117:40,48 124:149,153,157,161 125:149,153,157,161,165 126:149,157 127:153,161 128:36,40,44,48,149,153,157,161 129:100,104,108,112,116,120,124,128 130:36,40,44,48,52,56,60,64,100,104,108,112,116,120,124,128,132,136,140,144,149,153,157,161,165
1790532545.063341: P2P: cli_channels:
1790532545.063378: MBO: Update non-preferred channels, non_pref_chan=N/A
1790532545.063394: p2p0: Added interface p2p0
1790532545.063401: p2p0: State: INACTIVE → DISCONNECTED
1790532545.063406: nl80211: Set p2p0 operstate 0->0 (DORMANT)
1790532545.063457: p2p0: Determining shared radio frequencies (max len 4)
1790532545.063464: p2p0: Shared frequencies (len=0): completed iteration
1790532545.063470: P2P: Add operating class 81
1790532545.063478: P2P: Add operating class 115
1790532545.063483: P2P: Add operating class 116
1790532545.063487: P2P: Add operating class 117
1790532545.063492: P2P: Add operating class 124
1790532545.063496: P2P: Add operating class 125
1790532545.063501: P2P: Add operating class 126
1790532545.063505: P2P: Add operating class 127
1790532545.063510: P2P: Add operating class 128
1790532545.063521: P2P: Add operating class 129
1790532545.063529: P2P: Add operating class 130
1790532545.063539: P2P: Update channel list
1790532545.063556: P2P: channels: 81:1,2,3,4,5,6,7,8,9,10,11,12,13 115:36,40,44,48 116:36,44 117:40,48 124:149,153,157,161 125:149,153,157,161,165 126:149,157 127:153,161 128:36,40,44,48,149,153,157,161 129:100,104,108,112,116,120,124,128 130:36,40,44,48,52,56,60,64,100,104,108,112,116,120,124,128,132,136,140,144,149,153,157,161,165
1790532545.063561: P2P: cli_channels:
1790532545.063627: RTM_NEWLINK: ifi_index=37 ifname=p2p0 operstate=2 linkmode=1 ifi_family=0 ifi_flags=0x1003 ([UP])
1790532546.064033: EAPOL: disable timer tick
1790532547.060014: p2p0: Control interface command ‘SET wifi_display 1’
1790532547.060066: WFD: Wi-Fi Display enabled
1790532547.060072: WFD: Update WFD IE
1790532547.067039: p2p0: Control interface command ‘WFD_SUBELEM_SET 0 000600101c440032’
1790532547.067082: WFD: Set subelement 0
1790532547.067090: WFD: Update WFD IE
1790532547.073307: EAPOL: EAP Session-Id not available
1790532547.083908: p2p0: Control interface command ‘P2P_FIND’
1790532547.083950: P2P: Starting find (type=0)
1790532547.083961: P2P: Clear timeout (state=IDLE)
1790532547.083973: P2P: State IDLE → SEARCH
1790532547.084007: WPS: * Version (hardcoded 0x10)
1790532547.084013: WPS: * Request Type
1790532547.084017: WPS: * Config Methods (280)
1790532547.084021: WPS: * UUID-E
1790532547.084025: WPS: * Primary Device Type
1790532547.084030: WPS: * RF Bands (3)
1790532547.084034: WPS: * Association State
1790532547.084037: WPS: * Configuration Error (0)
1790532547.084041: WPS: * Device Password ID (0)
1790532547.084045: WPS: * Manufacturer
1790532547.084049: WPS: * Model Name
1790532547.084052: WPS: * Model Number
1790532547.084056: WPS: * Device Name
1790532547.084060: WPS: * Version2 (0x20)
1790532547.084064: WPS: * Request to Enroll (1)
1790532547.084073: P2P: * P2P IE header
1790532547.084077: P2P: * Capability dev=25 group=00
1790532547.084082: P2P: * Listen Channel: Regulatory Class 81 Channel 6
1790532547.084101: p2p0: First radio work item in the queue - schedule start immediately
1790532547.084960: nl80211: P2P probe - mask SuppRates
1790532547.086191: nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for p2p0
1790532547.086217: p2p0: Event SCAN_STARTED (47) received
1790532551.152953: nl80211: Drv Event 34 (NL80211_CMD_NEW_SCAN_RESULTS) received for p2p0
1790532551.153090: p2p0: Event SCAN_RESULTS (3) received
1790532551.154002: P2P: Parsing WPS IE
1790532551.154015: P2P: Config Methods (WPS): 0x0
1790532551.154022: P2P: Primary Device Type (WPS): 6-0050F204-1
1790532551.154136: P2P: Parsing WPS IE
1790532551.154161: P2P: Parsing WPS IE
1790532551.154181: P2P: Parsing WPS IE
1790532551.154188: P2P: Config Methods (WPS): 0x4388
1790532551.154195: P2P: Primary Device Type (WPS): 7-0050F204-1
1790532551.154202: P2P: Parsing P2P IE
1790532551.154208: P2P: Attribute 2 length 2
1790532551.154215: P2P: * Device Capability 21 Group Capability 00
1790532551.154221: P2P: Attribute 13 length 47
1790532551.154230: P2P: * Device Info: addr ce:6e:a4:xx:xx:01 primary device type 7-0050F204-1 device name ‘[TV] Samsung 6 Series (50)’ config methods 0x188
1790532551.154250: P2P: Update peer ce:6e:a4:xx:xx:01 config_methods 0x0 → 0x188
1790532551.154266: P2P: Peer found with Listen frequency 2412 MHz (rx_time=465522.153559)
1790532551.154487: P2P: State SEARCH → SEARCH
1790532551.154502: P2P: Starting short listen state (state=SEARCH)
1790532551.154734: WPS: * Version (hardcoded 0x10)
1790532551.154747: WPS: * UUID-E
1790532551.154757: WPS: * Version2 (0x20)
1790532551.154765: P2P: * P2P IE header
1790532551.154771: P2P: * Capability dev=25 group=00
1790532551.154779: P2P: * Device Info
1790532551.154791: p2p0: Add radio work ‘p2p-listen’@0xfb11e10
1790532551.154807: p2p0: First radio work item in the queue - schedule start immediately
1790532551.154876: p2p0: Starting radio work ‘p2p-listen’@0xfb11e10 after 0.000066 second wait
1790532551.155563: nl80211: Remain-on-channel cookie 0x3e for freq=2437 MHz duration=204
1790532551.296769: nl80211: Drv Event 55 (NL80211_CMD_REMAIN_ON_CHANNEL) received for p2p0
1790532551.296844: nl80211: Remain-on-channel event (cancel=0 freq=2437 channel_type=0 duration=204 cookie=0x3e (match))
1790532551.296865: p2p0: Event REMAIN_ON_CHANNEL (19) received
1790532551.296897: Off-channel: Send Action callback (without_roc=0 pending_action_tx=(nil) pending_action_tx_done=0)
1790532551.296905: P2P: remain-on-channel callback (off_channel_freq=2437 pending_listen_freq=2437 roc_waiting_drv_freq=0 freq=2437 duration=204)
1790532551.296918: P2P: Starting Listen timeout(0,204800) on freq=2437 based on callback
1790532551.296930: P2P: Set timeout (state=SEARCH): 0.224800 sec
1790532551.502709: nl80211: Drv Event 56 (NL80211_CMD_CANCEL_REMAIN_ON_CHANNEL) received for p2p0
1790532551.502785: nl80211: Remain-on-channel event (cancel=1 freq=2437 channel_type=0 duration=0 cookie=0x3e (match))
1790532551.502805: p2p0: Event CANCEL_REMAIN_ON_CHANNEL (20) received
1790532551.502838: P2P: Cancel remain-on-channel callback (p2p_long_listen=0 ms pending_action_tx=(nil))
1790532551.502850: p2p0: Radio work ‘p2p-listen’@0xfb11e10 done in 0.347976 seconds
1790532551.502859: p2p0: radio_work_free(‘p2p-listen’@0xfb11e10): num_active_works → 0
1790532551.502871: P2P: Driver ended Listen state (freq=2437)
1790532551.502879: P2P: Skip stop_listen since not in listen_only state.
1790532551.502957: DPP: Remain on channel cancel for 2437 MHz
1790532551.521918: P2P: Timeout (state=SEARCH)
1790532551.522201: P2P: Starting search
1790532551.522226: WPS: * Version (hardcoded 0x10)
1790532551.522231: WPS: * Request Type
1790532551.522235: WPS: * Config Methods (280)
1790532551.522239: WPS: * UUID-E
1790532551.522243: WPS: * Primary Device Type
1790532551.522247: WPS: * RF Bands (3)
1790532551.522251: WPS: * Association State
1790532551.522256: WPS: * Configuration Error (0)
1790532551.522260: WPS: * Device Password ID (0)
1790532551.522264: WPS: * Manufacturer
1790532551.522398: WPS: * Model Name
1790532551.522407: WPS: * Model Number
1790532551.522411: WPS: * Device Name
1790532551.522416: WPS: * Version2 (0x20)
1790532551.522421: WPS: * Request to Enroll (1)
1790532551.522440: P2P: * P2P IE header
1790532551.522454: P2P: * Capability dev=25 group=00
@Gepardi55 Thanks, that report is very helpful! Good news first: the Wi-Fi part now works with your Samsung — the connection is up after 2 s, the TV hands out an address via DHCP (that was the missing piece before) and answers ping.
What’s strange: right after that, the Imira service on the phone stops without leaving a trace in its own log, and nothing reaches the RTSP stage. To see why, please:
  1. Start a cast and wait ~20 s (don’t press stop).
  2. In a terminal: devel-su, then journalctl -u imira --no-pager -n 80
  3. Post the output (replace MAC addresses with xx if any show up).
Also: What did the app show during those ~15 s (“Waiting for receiver”, an error, back to idle)? Did you press stop or close the app in between? And did the TV show anything, e.g. a “connecting” screen?
Samsung TVs ask for permission the first time a new device connects. Please check on the TV: Settings → General → External Device Manager → Device Connect Manager. Is there an “Allow” prompt on the TV when you start casting? Is the phone listed under Device List, maybe as “Denied”? For a test you can also set Access Notification to Off (as far as i know).
@JimKnopfIoT Here is logs:
root@JollaPhone2026 defaultuser]# journalctl -u imira --no-pager -n 80
– Logs begin at Mon 2026-09-28 20:49:08 EEST, end at Mon 2026-09-28 20:51:14 EEST. –
syys 28 20:49:56 JollaPhone2026 systemd[1]: Started imira Miracast session service.
syys 28 20:50:22 JollaPhone2026 imira-session.sh[52611]: /usr/libexec/imira/imira-session.sh: line 403: SECONDS: parameter not set
syys 28 20:50:22 JollaPhone2026 systemd[1]: imira.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
syys 28 20:50:22 JollaPhone2026 systemd[1]: imira.service: Failed with result ‘exit-code’.
syys 28 20:50:27 JollaPhone2026 systemd[1]: imira.service: Service hold-off time over, scheduling restart.
syys 28 20:50:27 JollaPhone2026 systemd[1]: imira.service: Scheduled restart job, restart counter is at 1.
syys 28 20:50:27 JollaPhone2026 systemd[1]: Stopped imira Miracast session service.
syys 28 20:50:27 JollaPhone2026 systemd[1]: Started imira Miracast session service.
@Gepardi55 Thank you for the log. Hopefully 0.10.6 will fix it. Please try the new version and report.
Hi, sorry for the delay here is my report:
created: 2026-09-28 19:00:02 UTC
imira: 0.10.6-1
kernel: 6.12.38-4k
udhcpc: yes
phone Wi-Fi: not connected
settings: mode mirror, resolution 720, receiver 36:a6:ef:xx:xx:01, detailed log on, survey on
last status: reporting 0 1 p2p0
===== diagnostic scan =====
1 peer(s) found (peer 36:a6:ef:xx:xx:01 [sink])
2026-09-28 20:52:52 === cast start: imira 0.10.6-1, iface p2p0, mode mirror, res 720, peer 36:a6:ef:xx:xx:01
20:53:10 attempt 1: sink 36:a6:ef:xx:xx:01 found
20:53:12 connect 36:a6:ef:xx:xx:01 pbc go_intent=0 freq=auto: FAIL
20:53:36 attempt 1 failed
wpa: Failed to create interface p2p-p2p0-0: -22 (Invalid argument)
wpa: P2P: Failed to create new group interface
wpa: P2P: Failed to allocate a new interface for the group
===== wpa_supplicant initialization =====
@Alesy2a Thanks, your report showed the cause: leftover network interfaces blocked the connection. 0.10.7 clears them before every cast, so please update and try again (and post a new diagnostic report if it still fails).
Wau!! 0.10.7 works with Samsung TV. Video is very good. Audio comes from phone but I assume that’s purpose (?) or did you plan that audio is passed thru also?
Perfect, now it works! Thank you so much! The audio isn’t working for me either, but I connect to the soundbar because the projector’s audio is terrible.
Audio should work on the TV only (thats how it’s working here on LG TV).
So new logs are required to fix this for Samsung TVs.
Sure. Just tell me the log options you would need for audio.
