@Gepardi55 @Alesy2a 0.10.8 is out: if the sound comes from the phone instead of the TV, tap Audio route on the main page (or the second action on the cover while casting) until the TV plays it, and post a diagnostic report afterwards so I can see which route worked for you.
Hello, unfortunately I’ve noticed that the connection often fails and I have to restart both the phone and the projector to get them working again. Imira says “Wait for receiver” and doesn’t project anything. Here is the resulting log:
Imira diagnostic summary
Sailfish OS: 5.2.0.17 (Finlayson) | device: Jolla Phone | imira: 0.10.7-1
cast interface: p2p0 | sink: xx:xx:xx:xx:xx:xx (hichip)
===== KEY CONNECT & WPA LOGS =====
18:31:05 group up: p2p-p2p0-0 client ssid=“DIRECT-xx-xxxx” freq=2412 go_dev_addr=xx:xx:xx:xx:xx:xx
18:31:07 dhcp: lease xx.xx.xx.xx - sink xx.xx.xx.xx
18:31:07 net: route to sink: xx.xx.xx.xx via xx.xx.xx.xx dev wlan0 src xx.xx.xx.xx uid 0
wpa: P2P-GO-NEG-SUCCESS role=client freq=2412
wpa: WPS-SUCCESS / P2P-GROUP-FORMATION-SUCCESS
wpa: p2p-p2p0-0: CTRL-EVENT-EAP-FAILURE EAP authentication failed
wpa: nl80211: send_event_marker failed: Source based routing not supported
wpa: p2p-p2p0-0: CTRL-EVENT-DISCONNECTED bssid=xx:xx:xx:xx:xx:xx reason=3 locally_generated=1
wpa: p2p-p2p0-0: CTRL-EVENT-CONNECTED - Connection to xx:xx:xx:xx:xx:xx completed
===== RTSP HANDSHAKE FAILURE =====
18:31:09 == waiting for the sink’s RTSP connection on port 7236 (local xx.xx.xx.xx, sink xx.xx.xx.xx)
18:31:23 no RTSP connection from the sink after 15 s
18:31:23 net: neighbours on p2p-p2p0-0: xx.xx.xx.xx FAILED
18:31:33 session attempt 1 ended after 25 s, 0 frames sent
Here is an updated diagnostic log (Imira 0.10.8-1). I noticed that one connection attempt actually succeeded at 18:48 and streamed 400 frames at 720p, proving that video encoding works on this device. However, most attempts still fail to establish the RTSP connection due to routing issues (wlan0 vs p2p0) and EAP/WPS disconnects right after P2P group formation. Here is the condensed log:
Imira diagnostic report summary
Sailfish OS: 5.2.0.17 | Jolla Phone (mt6858) | Imira: 0.10.8-1
Receiver: xx:xx:xx:xx:xx:xx (hichip)
===== SUCCESSFUL SESSION ATTEMPT (18:48) =====
18:48:48 group up: p2p-p2p0-1 client freq=2412 [PERSISTENT]
18:48:51 dhcp lease xx.xx.xx.xx - sink xx.xx.xx.xx
18:48:53 == sink connected from xx.xx.xx.xx:34406 after 0.2 s
18:48:53 >>> OPTIONS / GET_PARAMETER / SET_PARAMETER / SETUP / PLAY → OK
18:48:53 == starting RTP stream → xx.xx.xx.xx:42030
imira-castd: streaming 1280x720@30 → xx.xx.xx.xx:42030
18:49:15 session attempt ended after 22 s, 400 frames sent
===== RECURRING FAILURE PATTERN (18:29, 18:30, 18:47, 18:49, 18:51, 18:52, 18:53) =====
- net: route to sink: xx.xx.xx.xx via xx.xx.xx.xx dev wlan0 src xx.xx.xx.xx uid 0
- wpa: CTRL-EVENT-EAP-FAILURE EAP authentication failed
- wpa: CTRL-EVENT-DISCONNECTED bssid=xx:xx:xx:xx:xx:xx reason=3 locally_generated=1
- no RTSP connection from the sink after 15 s
- net: neighbours on p2p-p2p0-x: FAILED
Automatic audio route worked and now streaming sound is coming from TV. Thank You very much!!!
@Alesy2a Thanks, the 18:48 session is great news – video works on your projector. For the failed attempts I need the unedited report, please: the lines starting with dhcp: lease and net: p2p-p2p0-… matter, and the private addresses in them (192.168.x.x / 10.x.x.x) are safe to post – the report already removes everything personal. It looks like the route to the projector goes via your home Wi-Fi instead of the direct link; the raw lines will tell me why. And did the sound come from the projector in that 18:48 session, or did you need the Audio route button?
Hi, unfortunately all other session attempts failed, there is the report:
Sailfish OS: 5.2.0.17 (Finlayson) | Jolla Phone (mt6858) | Imira: 0.10.8-1
Receiver: 36:a6:ef:xx:xx:01 (hichip)
18:48:48 group up: p2p-p2p0-1 client ssid=“DIRECT-ds-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT]
18:48:51 dhcp: lease 192.168.49.10 - 24 864000
18:48:53 == sink connected from 192.168.49.1:34406 after 0.2 s
18:48:53 == starting RTP stream → 192.168.49.1:42030
imira-castd: audio capture from imira_cast.monitor
imira-castd: streaming 1280x720@30 → 192.168.49.1:42030
18:49:15 session attempt 2 ended after 22 s, 400 frames sent
- net: route to sink: via 192.168.43.1 dev wlan0 src 192.168.43.178 uid 0
- wpa: CTRL-EVENT-DISCONNECTED bssid=36:a6:ef:xx:xx:01 reason=3 locally_generated=1
- net: neighbours on p2p-p2p0-x: FAILED / empty
I will try again, so I can tell you if the audio works. Thanks again
After restarting both the Jolla Phone and the projector, it connected on the first try, but the audio isn’t working. Personally, that’s not an issue for me as I don’t even use audio on Android.
@Alesy2a You’ve posted a shortened, rewritten summary instead of the report again. I can’t work with that. The report is built so that it can be posted as is: personal data is already removed, and every line is there for a reason. Your summary drops exactly the values I need and mixes lines from different attempts, so I can’t tell what belongs together.
Sound not reaching the projector is a bug I want fixed, whether you use audio or not, and the audio log in the report is what shows why. Cast with some music playing, tap Audio route through all settings, and please paste the complete report file, unchanged, between two lines of ```.
Gepardi55 managed it, and that’s how the Samsung got fixed.
Sorry they are quite long, and the platform doesnt allow me to upload txt file or more then 50000 characters
Imira diagnostic report created: 2026-09-29 17:43:39 UTC imira: 0.10.8-1 Sailfish OS: 5.2.0.17 (Finlayson) device: Jolla Jolla Phone kernel: 6.12.38-4k wpa_supplicant: wpa_supplicant v2.11 cast interface: p2p0 (driver -), wlan0 driver wlan udhcpc: yes phone Wi-Fi: connected on 2412 MHz audio route: auto (running: -) settings: mode mirror, resolution 720, receiver 36:a6:ef:xx:xx:01, detailed log off, survey off flags in /etc/imira: none last status: reporting 0 6 p2p0 Anonymized: MAC addresses cut to the vendor part, names of other devices, network names, serial numbers, UUIDs and public IP addresses removed. Please look it over before posting it. ===== diagnostic scan (receivers nearby) ===== 2026-09-29 19:43:21 diagnostic scan on p2p0 p2p status: wpa_state=DISCONNECTED p2p_device_address=02:56:a8:xx:xx:02 peer 36:a6:ef:xx:xx:01 [sink]: pri_dev_type=10-0050F204-5 device_name= manufacturer=hichip model_name= model_number= config_methods=0x188 dev_capab=0x21 group_capab=0x0 level=0 listen_freq=2437 interface_addr=00:00:00:00:00:00 member_in_go_dev=00:00:00:00:00:00 oper_freq=0 flags=[REPORTED] wfd_subelems=0000060151022a012c01000600000000000006000700000000000000 1 peer(s) found ===== connect log ===== (… 62 earlier lines omitted) wpa: 1790699460.845165: p2p-p2p0-0: WPS-PBC-ACTIVE wpa: 1790699461.951543: p2p-p2p0-0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790699462.264870: p2p-p2p0-0: CTRL-EVENT-EAP-STARTED EAP authentication started wpa: 1790699462.268376: p2p-p2p0-0: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=1 wpa: 1790699462.268433: p2p-p2p0-0: CTRL-EVENT-EAP-METHOD EAP vendor 14122 method 1 (WSC) selected wpa: 1790699462.672672: p2p-p2p0-0: WPS-CRED-RECEIVED wpa: 1790699462.672867: p2p-p2p0-0: WPS-SUCCESS wpa: 1790699462.673070: P2P-GROUP-FORMATION-SUCCESS wpa: 1790699463.374078: p2p-p2p0-0: CTRL-EVENT-EAP-FAILURE EAP authentication failed wpa: 1790699463.377637: nl80211: send_event_marker failed: Source based routing not supported wpa: 1790699463.377969: p2p-p2p0-0: CTRL-EVENT-DISCONNECTED bssid=36:a6:ef:xx:xx:01 reason=3 locally_generated=1 wpa: 1790699463.381077: p2p-p2p0-0: CTRL-EVENT-DSCP-POLICY clear_all wpa: 1790699463.711125: p2p-p2p0-0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790699464.109614: p2p-p2p0-0: CTRL-EVENT-CONNECTED - Connection to 36:a6:ef:xx:xx:01 completed [id=0 id_str=] wpa: 1790699464.110321: P2P-GROUP-STARTED p2p-p2p0-0 client ssid=“DIRECT-5J-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 2026-09-29 18:31:07 net: p2p-p2p0-0 192.168.49.10/24 2026-09-29 18:31:07 net: route to sink: via 192.168.43.1 dev wlan0 src 192.168.43.178 uid 0 2026-09-29 18:31:09 net: sink does not answer ping (may just block ICMP) 2026-09-29 18:31:23 no RTSP connection from the sink after 15 s 2026-09-29 18:31:23 net: neighbours on p2p-p2p0-0: 192.168.49.1 FAILED ; 2026-09-29 18:31:33 session attempt 1 ended after 25 s, 0 frames sent 2026-09-29 18:31:40 === cast stopped 2026-09-29 18:47:07 === cast start: imira 0.10.8-1, iface p2p0, mode mirror, res 720, wpa log normal, peer 36:a6:ef:xx:xx:01 2026-09-29 18:47:15 session attempt 1 18:47:15 phone Wi-Fi on 2412 MHz: asking the receiver for the same channel (one radio, no channel hopping) 18:47:15 attempt 1/4: searching for 36:a6:ef:xx:xx:01 18:47:19 attempt 1: sink 36:a6:ef:xx:xx:01 found after 4 s 18:47:19 peer: pri_dev_type=10-0050F204-5 device_name= manufacturer=hichip model_name= model_number= config_methods=0x188 dev_capab=0x21 group_capab=0x0 level=0 listen_freq=2437 interface_addr=00:00:00:00:00:00 member_in_go_dev=00:00:00:00:00:00 oper_freq=0 flags=[REPORTED] wfd_subelems=0000060151022a012c01000600000000000006000700000000000000 18:47:19 prov_disc 36:a6:ef:xx:xx:01 pbc: OK 18:47:21 connect 36:a6:ef:xx:xx:01 pbc go_intent=0 freq=2412: OK 18:47:27 attempt 1: group up after 6 s: p2p-p2p0-0 client ssid=“DIRECT-DL-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 18:47:27 radio: cast and phone Wi-Fi share 2412 MHz (good) 18:47:29 dhcp: lease 192.168.49.10 - 24 864000 18:47:29 address: 192.168.49.10/24, sink (source: dhcp) wpa: 1790700439.719404: P2P-PROV-DISC-PBC-RESP 36:a6:ef:xx:xx:01 wpa: 1790700442.669962: P2P-GO-NEG-SUCCESS role=client freq=2412 ht40=0 peer_dev=36:a6:ef:xx:xx:01 peer_iface=36:a6:ef:xx:xx:01 wps_method=PBC wpa: 1790700442.682204: p2p-p2p0-0: WPS-PBC-ACTIVE wpa: 1790700443.789610: p2p-p2p0-0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790700444.202578: p2p-p2p0-0: CTRL-EVENT-EAP-STARTED EAP authentication started wpa: 1790700444.205795: p2p-p2p0-0: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=1 wpa: 1790700444.205888: p2p-p2p0-0: CTRL-EVENT-EAP-METHOD EAP vendor 14122 method 1 (WSC) selected wpa: 1790700444.862433: p2p-p2p0-0: WPS-CRED-RECEIVED wpa: 1790700444.862520: p2p-p2p0-0: WPS-SUCCESS wpa: 1790700444.862574: P2P-GROUP-FORMATION-SUCCESS wpa: 1790700445.596527: p2p-p2p0-0: CTRL-EVENT-EAP-FAILURE EAP authentication failed wpa: 1790700445.599967: nl80211: send_event_marker failed: Source based routing not supported wpa: 1790700445.600198: p2p-p2p0-0: CTRL-EVENT-DISCONNECTED bssid=36:a6:ef:xx:xx:01 reason=3 locally_generated=1 wpa: 1790700445.603112: p2p-p2p0-0: CTRL-EVENT-DSCP-POLICY clear_all wpa: 1790700446.029316: p2p-p2p0-0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790700446.383275: p2p-p2p0-0: CTRL-EVENT-CONNECTED - Connection to 36:a6:ef:xx:xx:01 completed [id=0 id_str=] wpa: 1790700446.383864: P2P-GROUP-STARTED p2p-p2p0-0 client ssid=“DIRECT-DL-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 2026-09-29 18:47:29 net: p2p-p2p0-0 192.168.49.10/24 2026-09-29 18:47:29 net: route to sink: via 192.168.43.1 dev wlan0 src 192.168.43.178 uid 0 2026-09-29 18:47:31 net: sink does not answer ping (may just block ICMP) 2026-09-29 18:47:47 no RTSP connection from the sink after 15 s 2026-09-29 18:47:47 net: neighbours on p2p-p2p0-0: 192.168.49.1 FAILED ; 2026-09-29 18:48:32 session attempt 1 ended after 61 s, 0 frames sent 2026-09-29 18:48:38 session attempt 2 18:48:38 phone Wi-Fi on 2412 MHz: asking the receiver for the same channel (one radio, no channel hopping) 18:48:38 attempt 1/4: searching for 36:a6:ef:xx:xx:01 18:48:40 attempt 1: sink 36:a6:ef:xx:xx:01 found after 2 s 18:48:40 peer: pri_dev_type=10-0050F204-5 device_name= manufacturer=hichip model_name= model_number= config_methods=0x188 dev_capab=0x21 group_capab=0x0 level=0 listen_freq=2437 interface_addr=00:00:00:00:00:00 member_in_go_dev=00:00:00:00:00:00 oper_freq=2412 flags=[FORCE_FREQ] wfd_subelems=0000060151022a012c01000600000000000006000700000000000000 18:48:40 prov_disc 36:a6:ef:xx:xx:01 pbc: OK 18:48:42 connect 36:a6:ef:xx:xx:01 pbc go_intent=0 freq=2412: OK 18:48:48 attempt 1: group up after 6 s: p2p-p2p0-1 client ssid=“DIRECT-ds-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 18:48:49 radio: cast and phone Wi-Fi share 2412 MHz (good) 18:48:51 dhcp: lease 192.168.49.10 - 24 864000 18:48:51 address: 192.168.49.10/24, sink (source: dhcp) wpa: 1790700524.082931: P2P-GO-NEG-SUCCESS role=client freq=2412 ht40=0 peer_dev=36:a6:ef:xx:xx:01 peer_iface=36:a6:ef:xx:xx:01 wps_method=PBC wpa: 1790700524.095705: p2p-p2p0-1: WPS-PBC-ACTIVE wpa: 1790700526.240237: p2p-p2p0-1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790700526.573384: p2p-p2p0-1: CTRL-EVENT-EAP-STARTED EAP authentication started wpa: 1790700526.577619: p2p-p2p0-1: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=1 wpa: 1790700526.577702: p2p-p2p0-1: CTRL-EVENT-EAP-METHOD EAP vendor 14122 method 1 (WSC) selected wpa: 1790700526.967841: p2p-p2p0-1: WPS-CRED-RECEIVED wpa: 1790700526.967910: p2p-p2p0-1: WPS-SUCCESS wpa: 1790700526.967962: P2P-GROUP-FORMATION-SUCCESS wpa: 1790700527.671840: p2p-p2p0-1: CTRL-EVENT-EAP-FAILURE EAP authentication failed wpa: 1790700527.675011: nl80211: send_event_marker failed: Source based routing not supported wpa: 1790700527.675162: p2p-p2p0-1: CTRL-EVENT-DISCONNECTED bssid=36:a6:ef:xx:xx:01 reason=3 locally_generated=1 wpa: 1790700527.676973: p2p-p2p0-1: CTRL-EVENT-DSCP-POLICY clear_all wpa: 1790700528.445391: p2p-p2p0-1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790700528.830076: p2p-p2p0-1: CTRL-EVENT-CONNECTED - Connection to 36:a6:ef:xx:xx:01 completed [id=0 id_str=] wpa: 1790700528.831216: P2P-GROUP-STARTED p2p-p2p0-1 client ssid=“DIRECT-ds-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 2026-09-29 18:48:51 net: p2p-p2p0-1 192.168.49.10/24 2026-09-29 18:48:51 net: route to sink: via 192.168.43.1 dev wlan0 src 192.168.43.178 uid 0 2026-09-29 18:48:53 net: sink does not answer ping (may just block ICMP) 2026-09-29 18:49:15 session attempt 2 ended after 22 s, 400 frames sent 2026-09-29 18:49:21 silence sink left behind by castd, streams moved home 2026-09-29 18:49:21 === cast stopped 2026-09-29 18:49:31 === cast start: imira 0.10.8-1, iface p2p0, mode mirror, res 720, wpa log normal, peer 36:a6:ef:xx:xx:01 2026-09-29 18:49:38 session attempt 1 18:49:38 phone Wi-Fi on 2412 MHz: asking the receiver for the same channel (one radio, no channel hopping) 18:49:38 attempt 1/4: searching for 36:a6:ef:xx:xx:01 18:49:44 attempt 1: sink 36:a6:ef:xx:xx:01 found after 6 s 18:49:44 peer: pri_dev_type=10-0050F204-5 device_name= manufacturer=hichip model_name= model_number= config_methods=0x188 dev_capab=0x21 group_capab=0x0 level=0 listen_freq=2437 interface_addr=00:00:00:00:00:00 member_in_go_dev=00:00:00:00:00:00 oper_freq=0 flags=[REPORTED] wfd_subelems=0000060151022a012c01000600000000000006000700000000000000 18:49:44 prov_disc 36:a6:ef:xx:xx:01 pbc: OK 18:49:46 connect 36:a6:ef:xx:xx:01 pbc go_intent=0 freq=2412: OK 18:49:53 attempt 1: group up after 6 s: p2p-p2p0-0 client ssid=“DIRECT-vK-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 18:49:53 radio: cast and phone Wi-Fi share 2412 MHz (good) 18:49:55 dhcp: lease 192.168.49.10 - 24 864000 18:49:55 address: 192.168.49.10/24, sink (source: dhcp) wpa: 1790700585.084927: P2P-PROV-DISC-PBC-RESP 36:a6:ef:xx:xx:01 wpa: 1790700587.259413: P2P-GO-NEG-SUCCESS role=client freq=2412 ht40=0 peer_dev=36:a6:ef:xx:xx:01 peer_iface=36:a6:ef:xx:xx:01 wps_method=PBC wpa: 1790700587.271567: p2p-p2p0-0: WPS-PBC-ACTIVE wpa: 1790700588.369847: p2p-p2p0-0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790700588.740995: p2p-p2p0-0: CTRL-EVENT-EAP-STARTED EAP authentication started wpa: 1790700588.745424: p2p-p2p0-0: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=1 wpa: 1790700588.745535: p2p-p2p0-0: CTRL-EVENT-EAP-METHOD EAP vendor 14122 method 1 (WSC) selected wpa: 1790700589.171087: p2p-p2p0-0: WPS-CRED-RECEIVED wpa: 1790700589.171156: p2p-p2p0-0: WPS-SUCCESS wpa: 1790700589.171212: P2P-GROUP-FORMATION-SUCCESS wpa: 1790700589.894593: p2p-p2p0-0: CTRL-EVENT-EAP-FAILURE EAP authentication failed wpa: 1790700589.897701: nl80211: send_event_marker failed: Source based routing not supported wpa: 1790700589.897825: p2p-p2p0-0: CTRL-EVENT-DISCONNECTED bssid=36:a6:ef:xx:xx:01 reason=3 locally_generated=1 wpa: 1790700589.899152: p2p-p2p0-0: CTRL-EVENT-DSCP-POLICY clear_all wpa: 1790700590.307405: p2p-p2p0-0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790700591.331597: p2p-p2p0-0: CTRL-EVENT-CONNECTED - Connection to 36:a6:ef:xx:xx:01 completed [id=0 id_str=] wpa: 1790700591.332494: P2P-GROUP-STARTED p2p-p2p0-0 client ssid=“DIRECT-vK-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 2026-09-29 18:49:55 net: p2p-p2p0-0 192.168.49.10/24 2026-09-29 18:49:55 net: route to sink: via 192.168.43.1 dev wlan0 src 192.168.43.178 uid 0 2026-09-29 18:49:57 net: sink does not answer ping (may just block ICMP) 2026-09-29 18:50:13 no RTSP connection from the sink after 15 s 2026-09-29 18:50:13 net: neighbours on p2p-p2p0-0: 2026-09-29 18:50:58 session attempt 1 ended after 61 s, 0 frames sent 2026-09-29 18:51:04 session attempt 2 18:51:04 phone Wi-Fi on 2412 MHz: asking the receiver for the same channel (one radio, no channel hopping) 18:51:04 attempt 1/4: searching for 36:a6:ef:xx:xx:01 18:51:08 attempt 1: sink 36:a6:ef:xx:xx:01 found after 4 s 18:51:08 peer: pri_dev_type=10-0050F204-5 device_name= manufacturer=hichip model_name= model_number= config_methods=0x188 dev_capab=0x21 group_capab=0x0 level=0 listen_freq=2437 interface_addr=00:00:00:00:00:00 member_in_go_dev=00:00:00:00:00:00 oper_freq=0 flags=[REPORTED] wfd_subelems=0000060151022a012c01000600000000000006000700000000000000 18:51:08 prov_disc 36:a6:ef:xx:xx:01 pbc: OK 18:51:10 connect 36:a6:ef:xx:xx:01 pbc go_intent=0 freq=2412: OK 18:51:16 attempt 1: group up after 6 s: p2p-p2p0-1 client ssid=“DIRECT-RG-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 18:51:16 radio: cast and phone Wi-Fi share 2412 MHz (good) 18:51:18 dhcp: lease 192.168.49.10 - 24 864000 18:51:18 address: 192.168.49.10/24, sink (source: dhcp) wpa: 1790700669.939441: P2P-PROV-DISC-PBC-RESP 36:a6:ef:xx:xx:01 wpa: 1790700670.718934: P2P-GO-NEG-SUCCESS role=client freq=2412 ht40=0 peer_dev=36:a6:ef:xx:xx:01 peer_iface=36:a6:ef:xx:xx:01 wps_method=PBC wpa: 1790700670.734535: p2p-p2p0-1: WPS-PBC-ACTIVE wpa: 1790700671.867572: p2p-p2p0-1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790700672.288356: p2p-p2p0-1: CTRL-EVENT-EAP-STARTED EAP authentication started wpa: 1790700672.291137: p2p-p2p0-1: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=1 wpa: 1790700672.291221: p2p-p2p0-1: CTRL-EVENT-EAP-METHOD EAP vendor 14122 method 1 (WSC) selected wpa: 1790700672.691646: p2p-p2p0-1: WPS-CRED-RECEIVED wpa: 1790700672.691713: p2p-p2p0-1: WPS-SUCCESS wpa: 1790700672.691765: P2P-GROUP-FORMATION-SUCCESS wpa: 1790700673.561512: p2p-p2p0-1: CTRL-EVENT-EAP-FAILURE EAP authentication failed wpa: 1790700673.564664: nl80211: send_event_marker failed: Source based routing not supported wpa: 1790700673.564773: p2p-p2p0-1: CTRL-EVENT-DISCONNECTED bssid=36:a6:ef:xx:xx:01 reason=3 locally_generated=1 wpa: 1790700673.567109: p2p-p2p0-1: CTRL-EVENT-DSCP-POLICY clear_all wpa: 1790700673.982590: p2p-p2p0-1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790700675.010143: p2p-p2p0-1: CTRL-EVENT-CONNECTED - Connection to 36:a6:ef:xx:xx:01 completed [id=0 id_str=] wpa: 1790700675.011576: P2P-GROUP-STARTED p2p-p2p0-1 client ssid=“DIRECT-RG-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 2026-09-29 18:51:18 net: p2p-p2p0-1 192.168.49.10/24 2026-09-29 18:51:18 net: route to sink: via 192.168.43.1 dev wlan0 src 192.168.43.178 uid 0 2026-09-29 18:51:20 net: sink does not answer ping (may just block ICMP) 2026-09-29 18:51:37 no RTSP connection from the sink after 15 s 2026-09-29 18:51:37 net: neighbours on p2p-p2p0-1: 2026-09-29 18:52:21 session attempt 2 ended after 61 s, 0 frames sent 2026-09-29 18:52:27 session attempt 3 18:52:27 phone Wi-Fi on 2412 MHz: asking the receiver for the same channel (one radio, no channel hopping) 18:52:27 attempt 1/4: searching for 36:a6:ef:xx:xx:01 18:52:33 attempt 1: sink 36:a6:ef:xx:xx:01 found after 6 s 18:52:33 peer: pri_dev_type=10-0050F204-5 device_name= manufacturer=hichip model_name= model_number= config_methods=0x188 dev_capab=0x21 group_capab=0x0 level=0 listen_freq=2437 interface_addr=00:00:00:00:00:00 member_in_go_dev=00:00:00:00:00:00 oper_freq=0 flags=[REPORTED] wfd_subelems=0000060151022a012c01000600000000000006000700000000000000 18:52:33 prov_disc 36:a6:ef:xx:xx:01 pbc: OK 18:52:35 connect 36:a6:ef:xx:xx:01 pbc go_intent=0 freq=2412: OK 18:52:42 attempt 1: group up after 6 s: p2p-p2p0-2 client ssid=“DIRECT-1P-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 18:52:42 radio: cast and phone Wi-Fi share 2412 MHz (good) 18:52:44 dhcp: lease 192.168.49.10 - 24 864000 18:52:44 address: 192.168.49.10/24, sink (source: dhcp) wpa: 1790700754.970309: P2P-PROV-DISC-PBC-RESP 36:a6:ef:xx:xx:01 wpa: 1790700756.288359: P2P-GO-NEG-SUCCESS role=client freq=2412 ht40=0 peer_dev=36:a6:ef:xx:xx:01 peer_iface=36:a6:ef:xx:xx:01 wps_method=PBC wpa: 1790700756.299731: p2p-p2p0-2: WPS-PBC-ACTIVE wpa: 1790700757.658430: p2p-p2p0-2: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790700758.021021: p2p-p2p0-2: CTRL-EVENT-EAP-STARTED EAP authentication started wpa: 1790700758.023961: p2p-p2p0-2: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=1 wpa: 1790700758.024133: p2p-p2p0-2: CTRL-EVENT-EAP-METHOD EAP vendor 14122 method 1 (WSC) selected wpa: 1790700758.418548: p2p-p2p0-2: WPS-CRED-RECEIVED wpa: 1790700758.418618: p2p-p2p0-2: WPS-SUCCESS wpa: 1790700758.418675: P2P-GROUP-FORMATION-SUCCESS wpa: 1790700759.074946: p2p-p2p0-2: CTRL-EVENT-EAP-FAILURE EAP authentication failed wpa: 1790700759.078690: nl80211: send_event_marker failed: Source based routing not supported wpa: 1790700759.078854: p2p-p2p0-2: CTRL-EVENT-DISCONNECTED bssid=36:a6:ef:xx:xx:01 reason=3 locally_generated=1 wpa: 1790700759.081382: p2p-p2p0-2: CTRL-EVENT-DSCP-POLICY clear_all wpa: 1790700759.748310: p2p-p2p0-2: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790700760.128205: p2p-p2p0-2: CTRL-EVENT-CONNECTED - Connection to 36:a6:ef:xx:xx:01 completed [id=0 id_str=] wpa: 1790700760.129938: P2P-GROUP-STARTED p2p-p2p0-2 client ssid=“DIRECT-1P-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 2026-09-29 18:52:44 net: p2p-p2p0-2 192.168.49.10/24 2026-09-29 18:52:44 net: route to sink: via 192.168.43.1 dev wlan0 src 192.168.43.178 uid 0 2026-09-29 18:52:46 net: sink does not answer ping (may just block ICMP) 2026-09-29 18:53:02 no RTSP connection from the sink after 15 s 2026-09-29 18:53:02 net: neighbours on p2p-p2p0-2: 2026-09-29 18:53:47 session attempt 3 ended after 61 s, 0 frames sent 2026-09-29 18:53:53 session attempt 4 18:53:53 phone Wi-Fi on 2412 MHz: asking the receiver for the same channel (one radio, no channel hopping) 18:53:53 attempt 1/4: searching for 36:a6:ef:xx:xx:01 18:53:57 attempt 1: sink 36:a6:ef:xx:xx:01 found after 4 s 18:53:57 peer: pri_dev_type=10-0050F204-5 device_name= manufacturer=hichip model_name= model_number= config_methods=0x188 dev_capab=0x21 group_capab=0x0 level=0 listen_freq=2437 interface_addr=00:00:00:00:00:00 member_in_go_dev=00:00:00:00:00:00 oper_freq=0 flags=[REPORTED] wfd_subelems=0000060151022a012c01000600000000000006000700000000000000 18:53:57 prov_disc 36:a6:ef:xx:xx:01 pbc: OK 18:53:59 connect 36:a6:ef:xx:xx:01 pbc go_intent=0 freq=2412: OK 18:54:03 attempt 1: group up after 4 s: p2p-p2p0-3 client ssid=“DIRECT-W6-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 18:54:03 radio: cast and phone Wi-Fi share 2412 MHz (good) 18:54:05 dhcp: lease 192.168.49.10 - 24 864000 18:54:05 address: 192.168.49.10/24, sink (source: dhcp) wpa: 1790700838.105425: P2P-PROV-DISC-PBC-RESP 36:a6:ef:xx:xx:01 wpa: 1790700839.905469: P2P-GO-NEG-SUCCESS role=client freq=2412 ht40=0 peer_dev=36:a6:ef:xx:xx:01 peer_iface=36:a6:ef:xx:xx:01 wps_method=PBC wpa: 1790700839.921937: p2p-p2p0-3: WPS-PBC-ACTIVE wpa: 1790700841.032765: p2p-p2p0-3: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790700841.392415: p2p-p2p0-3: CTRL-EVENT-EAP-STARTED EAP authentication started wpa: 1790700841.395794: p2p-p2p0-3: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=1 wpa: 1790700841.395895: p2p-p2p0-3: CTRL-EVENT-EAP-METHOD EAP vendor 14122 method 1 (WSC) selected wpa: 1790700841.807878: p2p-p2p0-3: WPS-CRED-RECEIVED wpa: 1790700841.807985: p2p-p2p0-3: WPS-SUCCESS wpa: 1790700841.808303: P2P-GROUP-FORMATION-SUCCESS wpa: 1790700842.628356: p2p-p2p0-3: CTRL-EVENT-EAP-FAILURE EAP authentication failed wpa: 1790700842.634933: nl80211: send_event_marker failed: Source based routing not supported wpa: 1790700842.635126: p2p-p2p0-3: CTRL-EVENT-DISCONNECTED bssid=36:a6:ef:xx:xx:01 reason=3 locally_generated=1 wpa: 1790700842.639397: p2p-p2p0-3: CTRL-EVENT-DSCP-POLICY clear_all wpa: 1790700843.095428: p2p-p2p0-3: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790700843.466844: p2p-p2p0-3: CTRL-EVENT-CONNECTED - Connection to 36:a6:ef:xx:xx:01 completed [id=0 id_str=] wpa: 1790700843.467832: P2P-GROUP-STARTED p2p-p2p0-3 client ssid=“DIRECT-W6-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 2026-09-29 18:54:05 net: p2p-p2p0-3 192.168.49.10/24 2026-09-29 18:54:05 net: route to sink: via 192.168.43.1 dev wlan0 src 192.168.43.178 uid 0 2026-09-29 18:54:07 net: sink does not answer ping (may just block ICMP) 2026-09-29 18:54:11 session attempt 4 ended after 4 s, 0 frames sent 2026-09-29 18:54:18 === cast stopped 2026-09-29 18:54:50 === cast start: imira 0.10.8-1, iface p2p0, mode mirror, res 720, wpa log normal, peer 36:a6:ef:xx:xx:01 2026-09-29 18:54:58 session attempt 1 18:54:58 phone Wi-Fi on 2412 MHz: asking the receiver for the same channel (one radio, no channel hopping) 18:54:59 attempt 1/4: searching for 36:a6:ef:xx:xx:01 18:55:03 attempt 1: sink 36:a6:ef:xx:xx:01 found after 4 s 18:55:03 peer: pri_dev_type=10-0050F204-5 device_name= manufacturer=hichip model_name= model_number= config_methods=0x188 dev_capab=0x21 group_capab=0x0 level=0 listen_freq=2437 interface_addr=00:00:00:00:00:00 member_in_go_dev=00:00:00:00:00:00 oper_freq=0 flags=[REPORTED] wfd_subelems=0000060151022a012c01000600000000000006000700000000000000 18:55:03 prov_disc 36:a6:ef:xx:xx:01 pbc: OK 18:55:05 connect 36:a6:ef:xx:xx:01 pbc go_intent=0 freq=2412: OK 18:55:11 attempt 1: group up after 6 s: p2p-p2p0-0 client ssid=“DIRECT-Ms-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 18:55:11 radio: cast and phone Wi-Fi share 2412 MHz (good) 18:55:13 dhcp: lease 192.168.49.10 - 24 864000 18:55:13 address: 192.168.49.10/24, sink (source: dhcp) wpa: 1790700903.693654: P2P-PROV-DISC-PBC-RESP 36:a6:ef:xx:xx:01 wpa: 1790700906.052159: P2P-GO-NEG-SUCCESS role=client freq=2412 ht40=0 peer_dev=36:a6:ef:xx:xx:01 peer_iface=36:a6:ef:xx:xx:01 wps_method=PBC wpa: 1790700906.062042: p2p-p2p0-0: WPS-PBC-ACTIVE wpa: 1790700907.636853: p2p-p2p0-0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790700908.000127: p2p-p2p0-0: CTRL-EVENT-EAP-STARTED EAP authentication started wpa: 1790700908.003284: p2p-p2p0-0: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=1 wpa: 1790700908.003360: p2p-p2p0-0: CTRL-EVENT-EAP-METHOD EAP vendor 14122 method 1 (WSC) selected wpa: 1790700908.409756: p2p-p2p0-0: WPS-CRED-RECEIVED wpa: 1790700908.409819: p2p-p2p0-0: WPS-SUCCESS wpa: 1790700908.409871: P2P-GROUP-FORMATION-SUCCESS wpa: 1790700909.060764: p2p-p2p0-0: CTRL-EVENT-EAP-FAILURE EAP authentication failed wpa: 1790700909.065716: nl80211: send_event_marker failed: Source based routing not supported wpa: 1790700909.065841: p2p-p2p0-0: CTRL-EVENT-DISCONNECTED bssid=36:a6:ef:xx:xx:01 reason=3 locally_generated=1 wpa: 1790700909.068348: p2p-p2p0-0: CTRL-EVENT-DSCP-POLICY clear_all wpa: 1790700909.654065: p2p-p2p0-0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790700910.677644: p2p-p2p0-0: CTRL-EVENT-CONNECTED - Connection to 36:a6:ef:xx:xx:01 completed [id=0 id_str=] wpa: 1790700910.678203: P2P-GROUP-STARTED p2p-p2p0-0 client ssid=“DIRECT-Ms-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 2026-09-29 18:55:13 net: p2p-p2p0-0 192.168.49.10/24 2026-09-29 18:55:13 net: route to sink: via 192.168.43.1 dev wlan0 src 192.168.43.178 uid 0 2026-09-29 18:55:15 net: sink does not answer ping (may just block ICMP) 2026-09-29 18:55:31 no RTSP connection from the sink after 15 s 2026-09-29 18:55:31 net: neighbours on p2p-p2p0-0: 2026-09-29 18:56:16 session attempt 1 ended after 61 s, 0 frames sent 2026-09-29 18:56:22 session attempt 2 18:56:22 phone Wi-Fi on 2412 MHz: asking the receiver for the same channel (one radio, no channel hopping) 18:56:22 attempt 1/4: searching for 36:a6:ef:xx:xx:01 18:56:28 attempt 1: sink 36:a6:ef:xx:xx:01 found after 6 s 18:56:28 peer: pri_dev_type=10-0050F204-5 device_name= manufacturer=hichip model_name= model_number= config_methods=0x188 dev_capab=0x21 group_capab=0x0 level=0 listen_freq=2437 interface_addr=00:00:00:00:00:00 member_in_go_dev=00:00:00:00:00:00 oper_freq=0 flags=[REPORTED] wfd_subelems=0000060151022a012c01000600000000000006000700000000000000 18:56:28 prov_disc 36:a6:ef:xx:xx:01 pbc: OK 18:56:30 connect 36:a6:ef:xx:xx:01 pbc go_intent=0 freq=2412: OK 18:56:39 attempt 1: group up after 8 s: p2p-p2p0-1 client ssid=“DIRECT-kx-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 18:56:39 radio: cast and phone Wi-Fi share 2412 MHz (good) 18:56:41 dhcp: lease 192.168.49.10 - 24 864000 18:56:41 address: 192.168.49.10/24, sink (source: dhcp) wpa: 1790700989.735473: P2P-PROV-DISC-PBC-RESP 36:a6:ef:xx:xx:01 wpa: 1790700995.244707: P2P-GO-NEG-SUCCESS role=client freq=2412 ht40=0 peer_dev=36:a6:ef:xx:xx:01 peer_iface=36:a6:ef:xx:xx:01 wps_method=PBC wpa: 1790700995.258180: p2p-p2p0-1: WPS-PBC-ACTIVE wpa: 1790700996.617197: p2p-p2p0-1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790700997.037330: p2p-p2p0-1: CTRL-EVENT-EAP-STARTED EAP authentication started wpa: 1790700997.040544: p2p-p2p0-1: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=1 wpa: 1790700997.040653: p2p-p2p0-1: CTRL-EVENT-EAP-METHOD EAP vendor 14122 method 1 (WSC) selected wpa: 1790700997.443830: p2p-p2p0-1: WPS-CRED-RECEIVED wpa: 1790700997.443897: p2p-p2p0-1: WPS-SUCCESS wpa: 1790700997.443951: P2P-GROUP-FORMATION-SUCCESS wpa: 1790700998.126148: p2p-p2p0-1: CTRL-EVENT-EAP-FAILURE EAP authentication failed wpa: 1790700998.130356: nl80211: send_event_marker failed: Source based routing not supported wpa: 1790700998.130463: p2p-p2p0-1: CTRL-EVENT-DISCONNECTED bssid=36:a6:ef:xx:xx:01 reason=3 locally_generated=1 wpa: 1790700998.133203: p2p-p2p0-1: CTRL-EVENT-DSCP-POLICY clear_all wpa: 1790700998.561393: p2p-p2p0-1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790700998.914572: p2p-p2p0-1: CTRL-EVENT-CONNECTED - Connection to 36:a6:ef:xx:xx:01 completed [id=0 id_str=] wpa: 1790700998.915630: P2P-GROUP-STARTED p2p-p2p0-1 client ssid=“DIRECT-kx-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 2026-09-29 18:56:41 net: p2p-p2p0-1 192.168.49.10/24 2026-09-29 18:56:41 net: route to sink: via 192.168.43.1 dev wlan0 src 192.168.43.178 uid 0 2026-09-29 18:56:43 net: sink does not answer ping (may just block ICMP) 2026-09-29 18:57:17 session attempt 2 ended after 34 s, 653 frames sent 2026-09-29 18:57:23 silence sink left behind by castd, streams moved home 2026-09-29 18:57:23 === cast stopped 2026-09-29 19:35:09 === cast start: imira 0.10.8-1, iface p2p0, mode mirror, res 720, wpa log normal, peer 36:a6:ef:xx:xx:01 2026-09-29 19:35:16 session attempt 1 19:35:16 phone Wi-Fi on 2412 MHz: asking the receiver for the same channel (one radio, no channel hopping) 19:35:16 attempt 1/4: searching for 36:a6:ef:xx:xx:01 19:35:20 attempt 1: sink 36:a6:ef:xx:xx:01 found after 4 s 19:35:20 peer: pri_dev_type=10-0050F204-5 device_name= manufacturer=hichip model_name= model_number= config_methods=0x188 dev_capab=0x21 group_capab=0x0 level=0 listen_freq=2437 interface_addr=00:00:00:00:00:00 member_in_go_dev=00:00:00:00:00:00 oper_freq=0 flags=[REPORTED] wfd_subelems=0000060151022a012c01000600000000000006000700000000000000 19:35:21 prov_disc 36:a6:ef:xx:xx:01 pbc: OK 19:35:23 connect 36:a6:ef:xx:xx:01 pbc go_intent=0 freq=2412: OK 19:35:29 attempt 1: group up after 6 s: p2p-p2p0-0 client ssid=“DIRECT-UM-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 19:35:29 radio: cast and phone Wi-Fi share 2412 MHz (good) 19:35:31 dhcp: lease 192.168.49.10 - 24 864000 19:35:31 address: 192.168.49.10/24, sink (source: dhcp) wpa: 1790703321.286974: P2P-PROV-DISC-PBC-RESP 36:a6:ef:xx:xx:01 wpa: 1790703323.974980: P2P-GO-NEG-SUCCESS role=client freq=2412 ht40=0 peer_dev=36:a6:ef:xx:xx:01 peer_iface=36:a6:ef:xx:xx:01 wps_method=PBC wpa: 1790703323.984768: p2p-p2p0-0: WPS-PBC-ACTIVE wpa: 1790703325.537254: p2p-p2p0-0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790703325.899081: p2p-p2p0-0: CTRL-EVENT-EAP-STARTED EAP authentication started wpa: 1790703325.903453: p2p-p2p0-0: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=1 wpa: 1790703325.903536: p2p-p2p0-0: CTRL-EVENT-EAP-METHOD EAP vendor 14122 method 1 (WSC) selected wpa: 1790703326.379684: p2p-p2p0-0: WPS-CRED-RECEIVED wpa: 1790703326.379779: p2p-p2p0-0: WPS-SUCCESS wpa: 1790703326.379832: P2P-GROUP-FORMATION-SUCCESS wpa: 1790703327.072398: p2p-p2p0-0: CTRL-EVENT-EAP-FAILURE EAP authentication failed wpa: 1790703327.075040: nl80211: send_event_marker failed: Source based routing not supported wpa: 1790703327.075142: p2p-p2p0-0: CTRL-EVENT-DISCONNECTED bssid=36:a6:ef:xx:xx:01 reason=3 locally_generated=1 wpa: 1790703327.077517: p2p-p2p0-0: CTRL-EVENT-DSCP-POLICY clear_all wpa: 1790703327.484938: p2p-p2p0-0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790703327.817788: p2p-p2p0-0: CTRL-EVENT-CONNECTED - Connection to 36:a6:ef:xx:xx:01 completed [id=0 id_str=] wpa: 1790703327.819886: P2P-GROUP-STARTED p2p-p2p0-0 client ssid=“DIRECT-UM-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 2026-09-29 19:35:31 net: p2p-p2p0-0 192.168.49.10/24 2026-09-29 19:35:31 net: route to sink: via 192.168.43.1 dev wlan0 src 192.168.43.178 uid 0 2026-09-29 19:35:33 net: sink does not answer ping (may just block ICMP) 2026-09-29 19:35:49 no RTSP connection from the sink after 15 s 2026-09-29 19:35:49 net: neighbours on p2p-p2p0-0: 2026-09-29 19:36:34 session attempt 1 ended after 61 s, 0 frames sent 2026-09-29 19:36:40 session attempt 2 19:36:40 phone Wi-Fi on 2412 MHz: asking the receiver for the same channel (one radio, no channel hopping) 19:36:40 attempt 1/4: searching for 36:a6:ef:xx:xx:01 19:36:46 attempt 1: sink 36:a6:ef:xx:xx:01 found after 6 s 19:36:46 peer: pri_dev_type=10-0050F204-5 device_name= manufacturer=hichip model_name= model_number= config_methods=0x188 dev_capab=0x21 group_capab=0x0 level=0 listen_freq=2437 interface_addr=00:00:00:00:00:00 member_in_go_dev=00:00:00:00:00:00 oper_freq=0 flags=[REPORTED] wfd_subelems=0000060151022a012c01000600000000000006000700000000000000 19:36:46 prov_disc 36:a6:ef:xx:xx:01 pbc: OK 19:36:48 connect 36:a6:ef:xx:xx:01 pbc go_intent=0 freq=2412: OK 19:36:54 attempt 1: group up after 6 s: p2p-p2p0-1 client ssid=“DIRECT-G8-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 19:36:54 radio: cast and phone Wi-Fi share 2412 MHz (good) 19:36:56 dhcp: lease 192.168.49.10 - 24 864000 19:36:56 address: 192.168.49.10/24, sink (source: dhcp) wpa: 1790703407.781785: P2P-PROV-DISC-PBC-RESP 36:a6:ef:xx:xx:01 wpa: 1790703409.704932: P2P-GO-NEG-SUCCESS role=client freq=2412 ht40=0 peer_dev=36:a6:ef:xx:xx:01 peer_iface=36:a6:ef:xx:xx:01 wps_method=PBC wpa: 1790703409.717142: p2p-p2p0-1: WPS-PBC-ACTIVE wpa: 1790703411.078226: p2p-p2p0-1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790703411.572032: p2p-p2p0-1: CTRL-EVENT-EAP-STARTED EAP authentication started wpa: 1790703411.575059: p2p-p2p0-1: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=1 wpa: 1790703411.575180: p2p-p2p0-1: CTRL-EVENT-EAP-METHOD EAP vendor 14122 method 1 (WSC) selected wpa: 1790703411.981601: p2p-p2p0-1: WPS-CRED-RECEIVED wpa: 1790703411.981664: p2p-p2p0-1: WPS-SUCCESS wpa: 1790703411.981713: P2P-GROUP-FORMATION-SUCCESS wpa: 1790703412.632493: p2p-p2p0-1: CTRL-EVENT-EAP-FAILURE EAP authentication failed wpa: 1790703412.635447: nl80211: send_event_marker failed: Source based routing not supported wpa: 1790703412.635572: p2p-p2p0-1: CTRL-EVENT-DISCONNECTED bssid=36:a6:ef:xx:xx:01 reason=3 locally_generated=1 wpa: 1790703412.637293: p2p-p2p0-1: CTRL-EVENT-DSCP-POLICY clear_all wpa: 1790703413.055971: p2p-p2p0-1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790703413.407866: p2p-p2p0-1: CTRL-EVENT-CONNECTED - Connection to 36:a6:ef:xx:xx:01 completed [id=0 id_str=] wpa: 1790703413.410947: P2P-GROUP-STARTED p2p-p2p0-1 client ssid=“DIRECT-G8-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 2026-09-29 19:36:57 net: p2p-p2p0-1 192.168.49.10/24 2026-09-29 19:36:57 net: route to sink: via 192.168.43.1 dev wlan0 src 192.168.43.178 uid 0 2026-09-29 19:36:59 net: sink does not answer ping (may just block ICMP) 2026-09-29 19:37:15 no RTSP connection from the sink after 15 s 2026-09-29 19:37:15 net: neighbours on p2p-p2p0-1: 192.168.49.1 FAILED ; 2026-09-29 19:37:59 session attempt 2 ended after 60 s, 0 frames sent 2026-09-29 19:38:06 session attempt 3 19:38:06 phone Wi-Fi on 2412 MHz: asking the receiver for the same channel (one radio, no channel hopping) 19:38:06 attempt 1/4: searching for 36:a6:ef:xx:xx:01 19:38:08 attempt 1: sink 36:a6:ef:xx:xx:01 found after 2 s 19:38:08 peer: pri_dev_type=10-0050F204-5 device_name= manufacturer=hichip model_name= model_number= config_methods=0x188 dev_capab=0x21 group_capab=0x0 level=0 listen_freq=2437 interface_addr=00:00:00:00:00:00 member_in_go_dev=00:00:00:00:00:00 oper_freq=2412 flags=[FORCE_FREQ] wfd_subelems=0000060151022a012c01000600000000000006000700000000000000 19:38:08 prov_disc 36:a6:ef:xx:xx:01 pbc: OK 19:38:10 connect 36:a6:ef:xx:xx:01 pbc go_intent=0 freq=2412: OK 19:38:18 attempt 1: group up after 8 s: p2p-p2p0-2 client ssid=“DIRECT-hx-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 19:38:18 radio: cast and phone Wi-Fi share 2412 MHz (good) 19:38:20 dhcp: lease 192.168.49.10 - 24 864000 19:38:20 address: 192.168.49.10/24, sink (source: dhcp) wpa: 1790703493.328469: P2P-GO-NEG-SUCCESS role=client freq=2412 ht40=0 peer_dev=36:a6:ef:xx:xx:01 peer_iface=36:a6:ef:xx:xx:01 wps_method=PBC wpa: 1790703493.342087: p2p-p2p0-2: WPS-PBC-ACTIVE wpa: 1790703494.576622: p2p-p2p0-2: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790703495.057639: p2p-p2p0-2: CTRL-EVENT-EAP-STARTED EAP authentication started wpa: 1790703495.060507: p2p-p2p0-2: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=1 wpa: 1790703495.060592: p2p-p2p0-2: CTRL-EVENT-EAP-METHOD EAP vendor 14122 method 1 (WSC) selected wpa: 1790703495.488243: p2p-p2p0-2: WPS-CRED-RECEIVED wpa: 1790703495.488342: p2p-p2p0-2: WPS-SUCCESS wpa: 1790703495.488406: P2P-GROUP-FORMATION-SUCCESS wpa: 1790703496.218406: p2p-p2p0-2: CTRL-EVENT-EAP-FAILURE EAP authentication failed wpa: 1790703496.222061: nl80211: send_event_marker failed: Source based routing not supported wpa: 1790703496.222228: p2p-p2p0-2: CTRL-EVENT-DISCONNECTED bssid=36:a6:ef:xx:xx:01 reason=3 locally_generated=1 wpa: 1790703496.224800: p2p-p2p0-2: CTRL-EVENT-DSCP-POLICY clear_all wpa: 1790703496.646461: p2p-p2p0-2: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790703497.031197: p2p-p2p0-2: CTRL-EVENT-CONNECTED - Connection to 36:a6:ef:xx:xx:01 completed [id=0 id_str=] wpa: 1790703497.034221: P2P-GROUP-STARTED p2p-p2p0-2 client ssid=“DIRECT-hx-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 2026-09-29 19:38:20 net: p2p-p2p0-2 192.168.49.10/24 2026-09-29 19:38:20 net: route to sink: via 192.168.43.1 dev wlan0 src 192.168.43.178 uid 0 2026-09-29 19:38:22 net: sink does not answer ping (may just block ICMP) 2026-09-29 19:38:38 no RTSP connection from the sink after 15 s 2026-09-29 19:38:38 net: neighbours on p2p-p2p0-2: 2026-09-29 19:39:23 session attempt 3 ended after 61 s, 0 frames sent 2026-09-29 19:39:29 session attempt 4 19:39:29 phone Wi-Fi on 2412 MHz: asking the receiver for the same channel (one radio, no channel hopping) 19:39:29 attempt 1/4: searching for 36:a6:ef:xx:xx:01 19:39:35 attempt 1: sink 36:a6:ef:xx:xx:01 found after 6 s 19:39:35 peer: pri_dev_type=10-0050F204-5 device_name= manufacturer=hichip model_name= model_number= config_methods=0x188 dev_capab=0x21 group_capab=0x0 level=0 listen_freq=2437 interface_addr=00:00:00:00:00:00 member_in_go_dev=00:00:00:00:00:00 oper_freq=0 flags=[REPORTED] wfd_subelems=0000060151022a012c01000600000000000006000700000000000000 19:39:35 prov_disc 36:a6:ef:xx:xx:01 pbc: OK 19:39:37 connect 36:a6:ef:xx:xx:01 pbc go_intent=0 freq=2412: OK 19:39:44 attempt 1: group up after 6 s: p2p-p2p0-3 client ssid=“DIRECT-XL-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 19:39:44 radio: cast and phone Wi-Fi share 2412 MHz (good) 19:39:46 dhcp: lease 192.168.49.10 - 24 864000 19:39:46 address: 192.168.49.10/24, sink (source: dhcp) wpa: 1790703576.410301: P2P-PROV-DISC-PBC-RESP 36:a6:ef:xx:xx:01 wpa: 1790703579.403793: P2P-GO-NEG-SUCCESS role=client freq=2412 ht40=0 peer_dev=36:a6:ef:xx:xx:01 peer_iface=36:a6:ef:xx:xx:01 wps_method=PBC wpa: 1790703579.417075: p2p-p2p0-3: WPS-PBC-ACTIVE wpa: 1790703580.785937: p2p-p2p0-3: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790703581.105043: p2p-p2p0-3: CTRL-EVENT-EAP-STARTED EAP authentication started wpa: 1790703581.109883: p2p-p2p0-3: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=1 wpa: 1790703581.109969: p2p-p2p0-3: CTRL-EVENT-EAP-METHOD EAP vendor 14122 method 1 (WSC) selected wpa: 1790703581.704357: p2p-p2p0-3: WPS-CRED-RECEIVED wpa: 1790703581.704385: p2p-p2p0-3: WPS-SUCCESS wpa: 1790703581.704403: P2P-GROUP-FORMATION-SUCCESS wpa: 1790703582.360209: p2p-p2p0-3: CTRL-EVENT-EAP-FAILURE EAP authentication failed wpa: 1790703582.363090: nl80211: send_event_marker failed: Source based routing not supported wpa: 1790703582.363207: p2p-p2p0-3: CTRL-EVENT-DISCONNECTED bssid=36:a6:ef:xx:xx:01 reason=3 locally_generated=1 wpa: 1790703582.365163: p2p-p2p0-3: CTRL-EVENT-DSCP-POLICY clear_all wpa: 1790703582.770852: p2p-p2p0-3: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790703583.128847: p2p-p2p0-3: CTRL-EVENT-CONNECTED - Connection to 36:a6:ef:xx:xx:01 completed [id=0 id_str=] wpa: 1790703583.129936: P2P-GROUP-STARTED p2p-p2p0-3 client ssid=“DIRECT-XL-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 2026-09-29 19:39:46 net: p2p-p2p0-3 192.168.49.10/24 2026-09-29 19:39:46 net: route to sink: via 192.168.43.1 dev wlan0 src 192.168.43.178 uid 0 2026-09-29 19:39:48 net: sink does not answer ping (may just block ICMP) 2026-09-29 19:40:04 no RTSP connection from the sink after 15 s 2026-09-29 19:40:04 net: neighbours on p2p-p2p0-3: 2026-09-29 19:40:49 session attempt 4 ended after 61 s, 0 frames sent 2026-09-29 19:40:55 session attempt 5 19:40:55 phone Wi-Fi on 2412 MHz: asking the receiver for the same channel (one radio, no channel hopping) 19:40:55 attempt 1/4: searching for 36:a6:ef:xx:xx:01 19:41:01 attempt 1: sink 36:a6:ef:xx:xx:01 found after 6 s 19:41:01 peer: pri_dev_type=10-0050F204-5 device_name= manufacturer=hichip model_name= model_number= config_methods=0x188 dev_capab=0x21 group_capab=0x0 level=0 listen_freq=2437 interface_addr=00:00:00:00:00:00 member_in_go_dev=00:00:00:00:00:00 oper_freq=0 flags=[REPORTED] wfd_subelems=0000060151022a012c01000600000000000006000700000000000000 19:41:01 prov_disc 36:a6:ef:xx:xx:01 pbc: OK 19:41:03 connect 36:a6:ef:xx:xx:01 pbc go_intent=0 freq=2412: OK 19:41:09 attempt 1: group up after 6 s: p2p-p2p0-4 client ssid=“DIRECT-JJ-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 19:41:09 radio: cast and phone Wi-Fi share 2412 MHz (good) 19:41:11 dhcp: lease 192.168.49.10 - 24 864000 19:41:11 address: 192.168.49.10/24, sink (source: dhcp) wpa: 1790703662.112648: P2P-PROV-DISC-PBC-RESP 36:a6:ef:xx:xx:01 wpa: 1790703664.455129: P2P-GO-NEG-SUCCESS role=client freq=2412 ht40=0 peer_dev=36:a6:ef:xx:xx:01 peer_iface=36:a6:ef:xx:xx:01 wps_method=PBC wpa: 1790703664.467454: p2p-p2p0-4: WPS-PBC-ACTIVE wpa: 1790703665.592703: p2p-p2p0-4: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790703665.926091: p2p-p2p0-4: CTRL-EVENT-EAP-STARTED EAP authentication started wpa: 1790703665.929831: p2p-p2p0-4: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=1 wpa: 1790703665.929937: p2p-p2p0-4: CTRL-EVENT-EAP-METHOD EAP vendor 14122 method 1 (WSC) selected wpa: 1790703666.325035: p2p-p2p0-4: WPS-CRED-RECEIVED wpa: 1790703666.325135: p2p-p2p0-4: WPS-SUCCESS wpa: 1790703666.325200: P2P-GROUP-FORMATION-SUCCESS wpa: 1790703667.010400: p2p-p2p0-4: CTRL-EVENT-EAP-FAILURE EAP authentication failed wpa: 1790703667.013990: nl80211: send_event_marker failed: Source based routing not supported wpa: 1790703667.014160: p2p-p2p0-4: CTRL-EVENT-DISCONNECTED bssid=36:a6:ef:xx:xx:01 reason=3 locally_generated=1 wpa: 1790703667.017180: p2p-p2p0-4: CTRL-EVENT-DSCP-POLICY clear_all wpa: 1790703667.432685: p2p-p2p0-4: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790703667.765143: p2p-p2p0-4: CTRL-EVENT-CONNECTED - Connection to 36:a6:ef:xx:xx:01 completed [id=0 id_str=] wpa: 1790703667.767309: P2P-GROUP-STARTED p2p-p2p0-4 client ssid=“DIRECT-JJ-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 2026-09-29 19:41:11 net: p2p-p2p0-4 192.168.49.10/24 2026-09-29 19:41:11 net: route to sink: via 192.168.43.1 dev wlan0 src 192.168.43.178 uid 0 2026-09-29 19:41:13 net: sink does not answer ping (may just block ICMP) 2026-09-29 19:41:28 no RTSP connection from the sink after 15 s 2026-09-29 19:41:28 net: neighbours on p2p-p2p0-4: 2026-09-29 19:42:14 session attempt 5 ended after 61 s, 0 frames sent 2026-09-29 19:42:21 session attempt 6 19:42:21 phone Wi-Fi on 2412 MHz: asking the receiver for the same channel (one radio, no channel hopping) 19:42:21 attempt 1/4: searching for 36:a6:ef:xx:xx:01 19:42:25 attempt 1: sink 36:a6:ef:xx:xx:01 found after 4 s 19:42:25 peer: pri_dev_type=10-0050F204-5 device_name= manufacturer=hichip model_name= model_number= config_methods=0x188 dev_capab=0x21 group_capab=0x0 level=0 listen_freq=2437 interface_addr=00:00:00:00:00:00 member_in_go_dev=00:00:00:00:00:00 oper_freq=0 flags=[REPORTED] wfd_subelems=0000060151022a012c01000600000000000006000700000000000000 19:42:25 prov_disc 36:a6:ef:xx:xx:01 pbc: OK 19:42:27 connect 36:a6:ef:xx:xx:01 pbc go_intent=0 freq=2412: OK 19:42:39 attempt 1: group up after 12 s: p2p-p2p0-5 client ssid=“DIRECT-5e-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 19:42:39 radio: cast and phone Wi-Fi share 2412 MHz (good) 19:42:41 dhcp: lease 192.168.49.10 - 24 864000 19:42:41 address: 192.168.49.10/24, sink (source: dhcp) wpa: 1790703745.927502: P2P-PROV-DISC-PBC-RESP 36:a6:ef:xx:xx:01 wpa: 1790703754.699680: P2P-GO-NEG-SUCCESS role=client freq=2412 ht40=0 peer_dev=36:a6:ef:xx:xx:01 peer_iface=36:a6:ef:xx:xx:01 wps_method=PBC wpa: 1790703754.713906: p2p-p2p0-5: WPS-PBC-ACTIVE wpa: 1790703756.072999: p2p-p2p0-5: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790703756.406431: p2p-p2p0-5: CTRL-EVENT-EAP-STARTED EAP authentication started wpa: 1790703756.409756: p2p-p2p0-5: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=1 wpa: 1790703756.409851: p2p-p2p0-5: CTRL-EVENT-EAP-METHOD EAP vendor 14122 method 1 (WSC) selected wpa: 1790703756.817929: p2p-p2p0-5: WPS-CRED-RECEIVED wpa: 1790703756.818030: p2p-p2p0-5: WPS-SUCCESS wpa: 1790703756.818087: P2P-GROUP-FORMATION-SUCCESS wpa: 1790703757.492446: p2p-p2p0-5: CTRL-EVENT-EAP-FAILURE EAP authentication failed wpa: 1790703757.496558: nl80211: send_event_marker failed: Source based routing not supported wpa: 1790703757.496686: p2p-p2p0-5: CTRL-EVENT-DISCONNECTED bssid=36:a6:ef:xx:xx:01 reason=3 locally_generated=1 wpa: 1790703757.500503: p2p-p2p0-5: CTRL-EVENT-DSCP-POLICY clear_all wpa: 1790703757.804815: p2p-p2p0-5: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 wpa: 1790703758.404565: p2p-p2p0-5: CTRL-EVENT-CONNECTED - Connection to 36:a6:ef:xx:xx:01 completed [id=0 id_str=] wpa: 1790703758.406837: P2P-GROUP-STARTED p2p-p2p0-5 client ssid=“DIRECT-5e-” freq=2412 go_dev_addr=36:a6:ef:xx:xx:01 [PERSISTENT] 2026-09-29 19:42:41 net: p2p-p2p0-5 192.168.49.10/24 2026-09-29 19:42:41 net: route to sink: via 192.168.43.1 dev wlan0 src 192.168.43.178 uid 0 2026-09-29 19:42:43 net: sink does not answer ping (may just block ICMP) 2026-09-29 19:42:58 no RTSP connection from the sink after 15 s 2026-09-29 19:42:58 net: neighbours on p2p-p2p0-5: 2026-09-29 19:43:02 session attempt 6 ended after 19 s, 0 frames sent 2026-09-29 19:43:08 === cast stopped ===== RTSP handshake, current attempt ===== 19:42:43 == waiting for the sink’s RTSP connection on port 7236 (local 192.168.49.10, sink ) ===== RTSP handshake, earlier attempts ===== 18:30:04 == waiting for the sink’s RTSP connection on port 7236 (local 192.168.49.10, sink ) 18:31:09 == waiting for the sink’s RTSP connection on port 7236 (local 192.168.49.10, sink ) 18:47:31 == waiting for the sink’s RTSP connection on port 7236 (local 192.168.49.10, sink ) 18:48:31 !! the sink did not open an RTSP connection within 60 s 18:48:53 == waiting for the sink’s RTSP connection on port 7236 (local 192.168.49.10, sink ) 18:48:53 == sink connected from 192.168.49.1:34406 after 0.2 s 18:48:53 == using connection addresses: local 192.168.49.10 (expected 192.168.49.10), sink 192.168.49.1 (expected ) 18:48:53 >>> OPTIONS * RTSP/1.0 | CSeq: 1 | Require: org.wfa.wfd1.0 | | 18:48:53 <<< RTSP/1.0 200 OK | CSeq: 1 | Date: Thu, Jan 1 1970 08:03:00 GMT | Public: org.wfa.wfd1.0, GET_PARAMETER, SET_PARAMETER |BODY| 18:48:53 <<< OPTIONS * RTSP/1.0 | CSeq: 1 | Require: org.wfa.wfd1.0 |BODY| 18:48:53 >>> RTSP/1.0 200 OK | CSeq: 1 | Public: org.wfa.wfd1.0, GET_PARAMETER, SET_PARAMETER, SETUP, PLAY, PAUSE, TEARDOWN | | 18:48:53 >>> GET_PARAMETER rtsp://localhost/wfd1.0 RTSP/1.0 | CSeq: 2 | Content-Type: text/parameters | Content-Length: 83 | | wfd_video_formats | wfd_audio_codecs | wfd_client_rtp_ports | wfd_content_protection | 18:48:53 <<< RTSP/1.0 200 OK | CSeq: 2 | Content-Type: text/parameters | Content-Length: 243 |BODY| wfd_video_formats: 00 01 02 08 00019cff 1fffffff 00000fff 02 0000 00ff 11 0780 0438 | wfd_audio_codecs: LPCM 00000002 00, AAC 00000001 00 | wfd_client_rtp_ports: RTP/AVP/UDP;unicast 42030 0 mode=play | wfd_content_protection: HDCP2.0 port=25030 | 18:48:53 == sink RTP port: 42030 18:48:53 >>> SET_PARAMETER rtsp://localhost/wfd1.0 RTSP/1.0 | CSeq: 3 | Content-Type: text/parameters | Content-Length: 249 | | wfd_video_formats: 00 00 02 02 00000020 00000000 00000000 00 0000 0000 11 none none | wfd_audio_codecs: LPCM 00000002 00 | wfd_presentation_URL: rtsp://192.168.49.10/wfd1.0/streamid=0 none | wfd_client_rtp_ports: RTP/AVP/UDP;unicast 42030 0 mode=play | 18:48:53 <<< RTSP/1.0 200 OK | CSeq: 3 |BODY| 18:48:53 >>> SET_PARAMETER rtsp://localhost/wfd1.0 RTSP/1.0 | CSeq: 4 | Content-Type: text/parameters | Content-Length: 27 | | wfd_trigger_method: SETUP | 18:48:53 <<< RTSP/1.0 200 OK | CSeq: 4 |BODY| 18:48:53 == M5 acknowledged, waiting for SETUP from the sink 18:48:53 <<< SETUP rtsp://192.168.49.10/wfd1.0/streamid=0 RTSP/1.0 | CSeq: 2 | Transport: RTP/AVP/UDP;unicast;client_port=42030 |BODY| 18:48:53 == SETUP, client_port = 42030 18:48:53 >>> RTSP/1.0 200 OK | CSeq: 2 | Session: 1804289383;timeout=60 | Transport: RTP/AVP/UDP;unicast;client_port=42030;server_port=19000-19001 | | 18:48:53 <<< PLAY rtsp://192.168.49.10/wfd1.0/streamid=0 RTSP/1.0 | CSeq: 3 | Session: 1804289383 |BODY| 18:48:53 >>> RTSP/1.0 200 OK | CSeq: 3 | Session: 1804289383 | | 18:48:53 == starting RTP stream → 192.168.49.1:42030 imira-castd: presentation delay 150 ms library “libandroidicu.so” needed or dlopened by “/usr/libexec/droid-hybris/system/lib64/libmedia.so” is not accessible for the namespace “(default)” 18:48:54 <<< SET_PARAMETER rtsp://localhost/wfd1.0 RTSP/1.0 | CSeq: 4 | Content-Type: text/parameters | Content-Length: 17 | Session: 1804289383 |BODY| wfd_idr_request | 18:48:54 >>> RTSP/1.0 200 OK | CSeq: 4 | Session: 1804289383 | | library “libcom.android.media.swcodec.apexcodecs.so” not found library “libmediandk.so” not found library “/vendor/lib64/hw/mt6858/mapper.mediatek.so” needed or dlopened by “(unknown)” is not accessible for the namespace “(default)” library “/vendor/lib64/hw/mt6858/mapper.mediatek.so” (“/vendor/lib64/hw/mt6858/mapper.mediatek.so”) needed or dlopened by “(unknown)” is not accessible for the namespace: [name=“(default)”, ld_library_paths=“/usr/libexec/droid-hybris/system/lib64:/system/lib64:/vendor/lib64”, default_library_paths=“/system/lib64:/system_ext/lib64”, permitted_paths=“/system/lib64/drm:/system/lib64/extractors:/system/lib64/hw:/system_ext/lib64:/usr/libexec/droid-hybris/system/lib64:/system/framework:/system/app:/system/priv-app:/system_ext/framework:/system_ext/app:/system_ext/priv-app:/vendor/framework:/vendor/app:/vendor/priv-app:/system/vendor/framework:/system/vendor/app:/system/vendor/priv-app:/odm/framework:/odm/app:/odm/priv-app:/oem/app:/product/framework:/product/app:/product/priv-app:/data:/mnt/expand:/apex/com.android.runtime/lib64/bionic:/system/lib64/bootstrap”] imira-castd: audio route auto: media on the phone’s outputs goes to the TV, the phone stays silent imira-castd: audio output sink.primary_output (phone) imira-castd: audio output sink.deep_buffer (phone) imira-castd: audio output sink.fast (phone) imira-castd: audio output sink.null (module-null-sink.c) imira-castd: audio capture from imira_cast.monitor imira-castd: streaming 1280x720@30 → 192.168.49.1:42030 imira-castd: [18:48:54.542] IDR requested, restarting encoder invalid handle: (nil) library
@Alesy2a Thanks, that’s the one I needed. Two things show up:
- Your projector hands out an odd server address via DHCP, which made the “route via wlan0” line misleading – that part is harmless.
- When the connection works, the projector connects within 0.2 s after Imira starts listening. When it fails, it apparently knocked once a moment too early and never tried again. The next version will listen before the address is even set.
The forum cut your post at 50,000 characters, so the audio part at the end is missing. Please post only the section starting at “===== audio log”, between two lines of ```.
===== audio log (outputs, streams, route switches, level every 5 s) =====
18:56:43 audio route auto: media on the phone’s outputs goes to the TV, the phone stays silent
18:56:43 audio output sink.primary_output (phone)
18:56:43 audio output sink.deep_buffer (phone)
18:56:43 audio output sink.fast (phone)
18:56:43 audio output sink.null (module-null-sink.c)
18:56:43 audio capture from imira_cast.monitor
18:56:45 audio flowing (pts=1784497980)
18:56:50 level: silence (digital zero)
18:56:55 level: silence (digital zero)
18:57:00 level: silence (digital zero)
18:57:05 level: silence (digital zero)
18:57:10 level: silence (digital zero)
18:57:15 level: silence (digital zero)
===== wpa_supplicant log (latest run) =====
(5 of 8 lines kept)
1790703819.202620: P2P-FIND-STOPPED
1790703819.209484: p2p0: Do not deauthenticate as part of interface deinit since WoWLAN is enabled
1790703819.211158: p2p0: CTRL-EVENT-DSCP-POLICY clear_all
1790703819.211246: nl80211: deinit ifname=p2p0 disabled_11b_rates=0
1790703819.213325: p2p0: CTRL-EVENT-TERMINATING
@Alesy2a Thanks. The audio log explains the silence: no app was playing anything during that session, so there was nothing to send.
0.10.9 is out and should fix the connection problem. Please start some music on the phone first, then start casting. After 30s create the report.
I tried streaming a video from internet
22:03:57 audio route auto: media on the phone’s outputs goes to the TV, the phone stays silent
22:03:57 audio output sink.primary_output (phone)
22:03:57 audio output sink.deep_buffer (phone)
22:03:57 audio output sink.fast (phone)
22:03:57 audio output sink.null (module-null-sink.c)
22:03:57 audio capture from imira_cast.monitor
22:03:59 audio flowing (pts=7277320417)
22:04:04 level: silence (digital zero)
22:04:09 level: silence (digital zero)
22:04:14 level: silence (digital zero)
22:04:19 level: silence (digital zero)
22:04:24 level: silence (digital zero)
22:04:25 stream #1 “org.mozilla.fennec_fdroid” (appsupportaudio, group player, role x-maemo) on sink.deep_buffer: moved to the cast
22:04:29 level: sound, peak -14 dBFS
22:04:34 level: sound, peak -12 dBFS
22:04:39 level: sound, peak -15 dBFS
22:04:44 level: sound, peak -16 dBFS
22:04:49 level: sound, peak -17 dBFS
22:04:54 level: sound, peak -14 dBFS
22:04:54 audio route auto stopped
22:04:55 audio route all: every playback stream goes to the TV
22:04:55 audio output sink.primary_output (phone)
22:04:55 audio output sink.deep_buffer (phone)
22:04:55 audio output sink.fast (phone)
22:04:55 audio output sink.null (module-null-sink.c)
22:04:55 stream #1 “org.mozilla.fennec_fdroid” (appsupportaudio, group player, role x-maemo) on sink.deep_buffer: moved to the cast
22:04:55 audio capture from imira_cast.monitor
22:04:55 audio flowing (pts=7333651837)
22:05:00 level: sound, peak -14 dBFS
22:05:05 level: sound, peak -14 dBFS
22:05:10 level: sound, peak -14 dBFS
22:05:15 level: sound, peak -12 dBFS
22:05:20 level: sound, peak -13 dBFS
22:05:25 level: sound, peak -21 dBFS
22:05:30 level: sound, peak -22 dBFS
@Alesy2a The log looks right on the phone side: the browser’s audio is moved to the cast and sent with a proper level (−12 to −22 dBFS).
Two questions:
- Did you hear the sound from the projector this time?
- Was this 0.10.9, and did it connect on the first try? If you create a report, the lines at the top (version) and the “===== RTSP” section answer this. Please post it between two lines of ```.
Hi @JimKnopfIoT , please can you give me a Github, matrix or another link so I can upload the whole txt file? I think that will be more useful for you ![]()
Looks like it’s fixed for now. Also audio works. The next version will have a smoother connection handling.
I would like to thank you @JimKnopfIoT for the excellent work done; now Miracast with the projector on my Sailfish device works flawlessly. This is the true Linux spirit that makes me love these operating systems. For someone like me who isn’t a developer, it can seem intimidating, but using it allows to innovate and understand the nature of the technology we use everyday!
I want to thank you @JimKnopfloT also for great work!!!
