That’s something that’s indeed dependent on network connection, packet loss and timeouts. I don’t think there’s an awful lot we can do for that specific case (it should already be fine) but we’ll check it out.
Edit: To clarify: The indicator can stay green a little while when network connection goes bad, but it should eventually (quite quickly) turn red. This seems to not always be the case.
Installed whisperfish but it wont open. I have the signal app installed but figured i’d try out the whisperfish app also. This is on an xa2 which was just updated to 4.6.
Slightly off-topic: I’ll soon have my PhD defense. You are all invited, especially because Whisperfish had quite some impact on my work as a researcher. If you’re around Brussels that morning, feel free to join in person. If not, feel free to ask me the meeting link!
From time to time, for one contact (one that I use more frequently, about once in a month), I have to reset secure session for every message to get it delivered (two check marks).
It has been like that for several versions.
Is this known? (searched forum and gitlab)
dont want to start a new topic, only in case more people do experience that.
i did start whisperfish: red symbol, could not connect even after app restart.
try to check settings to see if background is enabled or not: crash
repeatedly.
after phone restart all fine.
so my statement: settings page might cause app to crash when not connected ?
That sounds like someone sent you a message using phone number discovery. Does Signal Desktop show a new contact with a message not synced to Whisperfish? If you can’t repeat that any more, that would fit the bill too. Do you happen to have logs and do doea it look something like this?
We are working on eliminating related crashes (pretty much done) and implenting all-around PNI support (good progress). See the merge request for details.
Is message deletion working? Since i deleted a message whishperfish did not sync. And was showing red instead of green color. On primary android device i could see new messages in conversations.
Another question would be: does the list of linked devices gets lost when transferring the account to another android device?
