Just wanted to make sure you weren’t experiencing anything else!
That’s exactly it! Matti and I are working on it. We’re very close to having it fixed now.
In my experience, chatting a bit around with a linked app (your Android app) should somehow trigger the session to reestablish. But the real fix will be the PNI implementation (which also fixes registration). Working on it, should be there soon!
We are close indeed! I (barely) managed to register my burner account Whisperfish as primary device yesterday, and (after a long, winding battle) even send and receive messages with my daily driver Whisperfish and Signal Desktop! There are still a lot of kinks to iron out - a few nasty ones too.
But, there’s still the linking another device to Whisperfish, and linking Whisperfish as a secondary device, so don’t hold your breath just yet! They should^tm follow a lot easier though.
Sorry for the wait, but it’s finally here. There is one important caveat: if you currently have a working, linked (secondary) Whisperfish installation, it will currently not be able to correctly handle PNI, as we missed the migration messages. A work-around is to relink your Whisperfish by resetting it, removing the linked device in Signal Android (or Molly, or Signal-iOS; you primary device), and adding it again.
In principle, we should implement the relinking with retention of your messages, but that is still a lot of work.
There are some reports of Whisperfish not connecting the first time you start it after the upgrade. A restart of the app should fix it, but I’m interested in the logs of installations where this happens!
Whisperfish 0.6.0-beta.25
PNI support, fixes registration and linking
Changes
Support PNI (except for pre-beta-25 linked devices)
Nicely display service messages (joined group, changed group, …)
Fix an edge case crash in message mark up rendering
Fix a crash on PNI-only contacts
Fix audio message playback with a headset connected
Yes, both linking and registration should work again!
However: if you currently have a working linked Whisperfish, it does not automatically get updated to be PNI-compatible, and you will not see any new conversations on that device.
So:
Pre-beta.25 existing registration + Whisperfish is primary: OK
Post-beta.25 new registration + Whisperfish is primary: OK
Post-beta.25 new registration + Whisperfish is secondary/linked: OK
A workaround for (2) is to unlink the device, remove the data directory (perform a reset) and link Whisperfish cleanly: that brings you into situation (4), but erases all your conversations from your device.
The PNI work in beta.25 was a massive effort from @rubdos, and it was a complex thing to pull off. All the kudos for that! Now we can start implementing even more missing features.
Displaying service messages (group gets a new member, disappearing messages adjusted etc.) was more than halfway done by @ichthyosaurus, so I picked it up and made those happen! Suddenly Whisperfish looks a lot more polished! There’s a lot of new strings to translate in that front, so please check out the translations in Weblate:
I am in your category 1. However, I am unable to link an ipad as a secondary device. It fails with a generic error message on the tablet. Is it your thoughts that linking/adding secondary devices to a primary whisperfish account should now be working?
Thanks for all the work and the continuing updates,
I have just linked Signal Desktop with my old Whisperfish install so at least that works still. There is a delay when SD waits for some reply from WF which we don’t yet provide. Signal for Ipad can be more sensitive to those, perhaps that’s the cause…?
We don’t have any iPads to test with. Could you retry the registration with Whisperfish verbose logs enabled and send them to us (censored)? (Wiki link in the fiest post.)
Hi, today, I updated Whisperfish to the new version. Since I previously had it linked as a secondary device, I performed a reset an linked it agein. This worked perfectly fine, so thank you!
But since everything is working again with the new version now, I noticed that in groups, the Signal profile names are shown instead of the ones from my contacts. I did select the option to prioritise device contacts, and for direct messages it works, but in groups for some reason the profile names are shown.
Signal (Whisperfish) profiles and Sailfish OS contacts are linked together by using phone numbers. As Signal does not deliver phone numbers any more by default, they can’t be matched. This is actually a very good point, thanks for bringing it up!
There actually is a way to still link users in Whisperfish with contacts in Sailfish OS, but I can’t recall how I did it… It had to be done manually for every contact though. Anyway, stay tuned!
When reacting to messages, WF used to display the reacted smiley underneath the message instantly. Nowadays I need to swipe to main screen and back to message screen for it to update.
If I remember right … this started to occur when updating to Beta.24…(maybe Beta.23?)…but anyhow Beta.24 and Beta.25 are atleast affected…
