You can’t migrate from Android yet. Or are you talking about keeping the history from Whisperfish before Signal Android? Neither are possible, currently.
Signal Android allows for making backups of your message database, and that’s the most probable way that we would ever support migration from Android. It’s currently unimplemented though, and I don’t expect a “soon” on that.
Ah! Do you have a link to work being done for Ubuntu Touch? I’d like to start making stuff I’m doing available there… And have some fragments of stuff from here and there.
Thank you very much for this very nice update. The UI improvement is indeed impressive, really well done.
This is the kind of app that allows me to keep Android support closed and I really appreciate.
We figured that issue of @pawel.spoon out on Gitlab; he was running an old -dev version where there was indeed an infinite loop.
Why in the world is the binary so HUGE:
18.4M /usr/bin/harbour-whisperfish
Yes. I know. Partially debugging symbols (apparently I don’t strip them?!), partially Rust binary size, partially the fact that it’s packed with features !
Thanks for the heads up. Debug symbols sounds not ‘quite’ as likely as the Rust binary. I should have guessed that it’s lack of standard libraries in distros. It’s similar for Go in my experience (running stuff like hugo for fun, pydio/cells, mattermost at work).
It is PACKED with features! Thanks for the client!
It’s late, but I figured it would benefit more people, if I posted this sooner than later. Please read carefully before proceeding - I might have typo’d something!
Kind of a PSA here: I started the update to SFOS 4.1.0.23 without downgrading sailfish-components-webview-qt5 packages first, which lead me into a nice situation: The repositories were already at 4.1.0.23 but I would have needed to remove (well, downgrade) the packages to the 4.0.1.48 version. After a brief panic, I got it working and all is good now. These are the steps, roughly, but you should get the idea:
The upgrade GUI tells you to remove three sailfish-components-webview-qt5 packages
Hey @direc85, thanks! Why is it that you had to downgrade the webview-qt5 packages? I would’ve expected it to get overwritten by the Jolla update.
I would also expect that if you get the warning in Settings, zypper install --oldpackage --force sailfish-components-webview-qt5-1.2.14-1.15.6.jolla sailfish-components-webview-qt5-pickers-1.2.14-1.15.6.jolla sailfish-components-webview-qt5-popups-1.2.14-1.15.6.jolla should be enough to clear that out.
Thanks for the heads-up on OpenRepos; I thought I had already fixed that. Should be okay now
I first tried to downgrade them without ssu re 4.0.1.48 but as the system pointed to the 4.1.0.23 repos, the versions simply didn’t exist. The message is shown after the repos are updated. It makes sense to me.
I’m not sure if this has been asked before; what do I need to do in order to move all config data from the old phone (XA2) to new phone (10II)? I tried to copy ~/.local/share/harbour-whisperfish directory and it almost seems to work; however Whisperfish on 10II does not seem to connect, I’ve tried Settings/Reconnect.
Almost there. You also need ~/.config/harbour-whisperfish. Make sure never to start Whisperfish on the old phone again though; ascertain yourself by removing both directories, or at least renaming them on the old phone.
EDIT: also, you should edit ~/.config/harbour-whisperfish/harbour-whisperfish.conf and change nemo to defaultuser for the attachment directory. Otherwise, receiving attachments will fail.
The next version of Whisperfish (coming soon™) will be compatible with My Backup, which lets you add any application you want to your system backup, so you won’t need to manually back up those directories anymore.
Is it just for me, or cant we see our available contacts in Signal? Not that i know any of my contacts using Signal. But with 200 contacts, its a bit unrealistic that none uses Signal. Am i doing something wrong? The network is connected but can only write a message or create a group, but not one contact is shown. Thanks!
