When will the OnePlus 13 phone be adapted to Sailfish OS?
When will the OnePlus 13 phone adapt to sailfish os? One-plus mobile phone currently supports official unlocking and is also the fastest adaptation upgrade of Google’s new Android system. Because the sailfishos system supports Android applications, it should be adapted to mobile phones with high CPU configuration, so that running Android applications will not get stuck or slow
As Jolla officially doesn’t support OnePlus devices, this will only happen if some porter from the community decides to port SailfishOS to the OnePlus 13.
This can happen in days, week, months, years or also never if noone is interested and willing to do the work and port SailfishOS.
Is there an individual or community that has transplanted the sailfish os operating system to one plus 13 phones?
Nobody has released a Sailfish OS port for the OnePlus 13
op13t/s was topic of consideration for Next gen VerdandiTeam phone
It is better to transplant one plus 13 directly, because 13 has a full-featured USB 3.0 interface, supports dp video output protocol, and can be externally connected with large-screen devices such as monitors, televisions or projectors. It will be more comfortable to output mobile phone pictures to these large-screen devices for use and viewing. USB 3.0 video output is important. Also, the configuration of Snapdragon 8 Extreme Edition chip is high, and it can be used for several more years on such equipment as sailfish os transplantation
why do you want to connect your phone with an external monitor or televison ?
Hey @yuanxinfang are you willing to just buy and ship a One Plus 13 as a present to a developper?
Then someone may eventually consider a port :blush:.
Cause its also not like porting people have the budget to play with such expensive toys on their own, be realistic you are talking about a device costing 1000$.
First make the offer to send this phone as present to a developper, then hope for someone to raise the hand :wink:
It would be great to add a device such as OnePlus 13 and FairPhone 6 with powerful hardware to the list of supported devices. Sony Xperia phones do not meet user’s needs as everything is out-to-date.
Well, It meets my needs…?
Look here and here
