What would be required for a port to Fairphone 5?
Very interesting project! Hopefully the SFOS would work smoothly on FP5.
OTA updates would not work with this build or…? (since it’s not officially supported by Jolla)
In my “pink pony wonderland” Jolla would have chosen Fairphone as their next officially supported device :grinning:
When my X10III some day breaks, would be awesome to replace it with FP5!
The C2 is not my “cup of tea” and I don’t really thrust Sony to get their sh…blobs… together (X10IV and X10V).
It looks like there will be no release today. Thanks anyway
Hello Mr. Mal… What is the current status of the Sailfish Port.? Can we hope for a release this weekend? Today is Friday the 13th :slight_smile:
Hello sir, do you have any new’s for the SFOS for the Fairphone 5? I’am so exited about SFOS for the FP5, and hope that Jolla one day would officialy support the FP5 with SFOS.
I encountered some unexpected issues when testing last weekend and have been too busy during the week to investigate why those happened. Hopefully this weekend I will figure out what went wrong.
Give up hope I think Sailfish Port (FP5) will never exist… The topic has been discussed since February debated… Neither beta version nor a screenshot… :sweat_smile:
If mal says there is a port, than it exists. He has a track record as developer and porter.
I know that I also sometimes express myself badly (especially in writing) and people think I’m trying to attack or insult them. In such cases, it is appropriate to apologize and, if necessary, clarify the actual intention.
Perhaps you should check your post to see if there is a similar situation here and rephrase it if necessary.
Mal is not working on it because he owes you or me or anybody else something.
I (and I’m sure some others as well) are grateful and happy when/if something comes out of mal’s work, but nobody can derive a right to the port.
If someone really wants proof that the port exists then here it a screenshot of it.
A small comment of the unexpected issue mentioned in my earlier comment, when doing some final testing I noticed that USB connection to my laptop only worked for certain type of USB port while the other didn’t work as expected so I tried to figure out why that happens.
Maybe a problem of USB2 vs USB3 which exists for the Jolla official release on Sony?
USB3 seems to autosuspend.
Awesome! I guess now it’s really time to look for some good offers for FP5! :slight_smile:
you are from russia… :woozy_face:
Well he went around the world. Does it matter to the discussion?
Sailfish OS ports for Fairphone 4 and 5 (and of course older Fairphone 2 port) are available at Sailfish OS for Fairphones devices
What a great christmas present! Thank you so much!
Did you make Waydroid wirk?
Mal thank you for the awesome port. Great work! Is it possible to get Android apps? I’ve tried Waydroid but it doesn’t works.
All primary functions works that i always used. And the installation is very easy. No issue’s.
All in all, thank you for your great work.
Thumbs up :slight_smile: You’re a genius :+1:
Did you configure the binder paths in waydroid if that is needed ? I think the earlier post in this thread linked to this GitHub - sailfishos-open/waydroid: Waydroid packaging for Sailfish OS, this port uses "puddlejumper,vndpuddlejumper,hwpuddlejumper”. Edit: I did some testing with waydroid but couldn’t yet get it working, need to debug more later.
I set it all up on waydroid, i succesfully downloaded lineage os. but if i want to start a android session goes to infinity loop. no chance to start it. i think when you have had time to look for it please? That would be would be great.
Mal: thank you very much for your port
Thank’s
There was a similar problem with Tama port
removing or commenting
lxc.apparmor.profile = unconfined
in /var/lib/waydroid/lxc/waydroid/config
I already tried that apparmor change earlier and it got starting waydroid a bit further but some services inside the container were failing.
