What do you mean I didn’t answer the question?!
He asked why I would ever want to minimize an app.
Who else better to answer such an excellent question than Jolla, who invented such a gesture in their user interface for sailfish os?
Now I will answer your question: swipe up from the home screen to access the app drawer, obviously.
Why are you telling me that old android and ios did not have gestures?
Let’s assume I didn’t already know that.
What is the purpose of telling me that?
This makes no sense, since you are the only person who can know, why you would minimize an app. I do believe there is at least one reason to minimize an app which is checking information or performing an operation on application cover.
That would increase the amount of swipes needed to open an app, when having one app on focus. I also think it is unnecessary to make all the current Sailfish users adapt to new ways of navigating the interface, unless it improves the workflow. After all, minimizing an app is only one gesture new users have to learn and for that reason, it doesn’t affect the learning curve more than slightly.
You are conflating “learning” with “training”.
So much confusion and conflating on these forums…
Learning a gesture is easy. It takes one second at most.
Training to actually use it instead of the one already in muscle memory from other operationg systems is the hard part.
But that is not what the discussion is about. Nobody said the old gesture should be taken away.
The discussion is about adding a new swipe up gesture to minimize apps.
But you want to add new functionality to pre-existing gesture that does completely different thing… Where does the existing functionality go in your dream setup?
What gesture and what functionality are you referring to exactly, so I know I am answering the right question?
In my scenario nothing is trully lost (especially if it is left as a user option).
Instead of opening the app drawer, while in an app, swipe up should minimize the current app.
The app drawer can still be accessed with the swipe up gesture from the home screen, as it is now.
For as much as i dislike the noise that @iolala brings, swipe-up conforming to a new de-facto standard is not the worst idea ever. I’d bet most [desktop] Linux users use Ctrl-X/C/V etc despite having some other command that predate them - and partial conflicts to boot.
I for one have never ever opened the “app drawer” on top of an app, and probably never will. And for some context to this; i say this as someone who have never daily-driven any other smartphone OSes than Meego and Sailfish OS - and it is a good 15 years since i used Windows (at home, make that 10 for work).
But there is not practical difference between swiping up and swiping from the side to minimize.
And by opening the app drawer from the bottom you can get quick access to your apps (a bit like in ubuntu touch). Note that you can also only swipe up a bit to only see the first row of apps.
A useful feature that android has got now is that you can di switch between apps by swiping on the bottom. But i dont know either how this would fit into the sfos ui.
That was my point - despite being redundant, it can still be a good idea.
Again, i already stated this - after however many years since its introduction (i don’t believe it was there from the beginning) i still don’t care about it on top of another app.
This is in no way unique to opening the drawer on top of an app.
Yea but I and prolly many others use the swiping up feature.
And swiping from the side to minimize works perfectly fine. Changing this would remove a feature just to add a redundant gesture.
I know this had been off topic for quite a few messages already, but maybe one of the sailors can split this into new topic, if this doesn’t die soon on its own.
I think it’s good, that the gestures inside an OS are unified as much as possible, regardless of whether you’re in an app or in the home view. Even if not all users would use all of those gestures. Imagine being expected to use Ctrl+C/V in some parts of an OS and Ctrl/Shift+Ins in other parts of same OS?
I think in SFOS 1.x the bottom swipe (while in app) brought up the events view, but it was changed in SFOS 2.0 to the current functionality.
You have to summon a sailor to this thread by using @ for that to happen.
It is helpful if you clearly denote how you imagine this thread to be spilt:
I assume to sort out all postings primarily addressing “swiping on the UI” (originally only “to minimise apps”), “automatic tile placement” and “app drawer”, starting with message #305 (i.e. #305 should be the starting point / initial posting of the new thread).
Yes and we argue that it should stay for pulling up the app drawer and not be replaced by minimizing an app. We have even two gestures for minimizing left and right swipe, if you haven’t set quick access of notifications
