Web Browser performance
I’ve got myself a Jolla Phone, and I’ve noticed that the native browsers (and maybe generally any native app that uses any form of webview) seem to have very low performance, while using an Android browser through AppSupport works pretty much as expected.
Is it simply that the QtWebView, which I assume is what is used by the Sailfish browsers and the Mail app and similar, is just a bad implementation performance-wise? Or is there any native browser that actually performs as well as the Android browsers?
On Openrepos there is a vibe coded browser rootitanium. Its the browser with the best performance. But the implementaion is strange. I dont know if i can trust this browser.
Actually, the native SFOS browser and webview are a complex custom embedded Gecko (Firefox) Qt framework. Since Jolla is the only company doing this (the rest all submit to the Chromium/Webkit monopoly when it comes to embedded/custom browsers), some implementation details may be a bit suboptimal.
But it’s an area of ongoing development, primarily by @abranson I think, and it keeps improving!
The latest Jolla blog post hints at updates to that underlying engine coming in the next OS update, with more to come after by the sounds of it. I guess that will mean performance improvements and better compatibility.
I don’t think the problem is Gecko. I use Firefox on AppSupport and it is very fast. The problem is that the native browser uses a very old version of Gecko. That’s why I hope a future upgrade.
I never said that Gecko was a problem, read my response again. You’re comparing apple’s to oranges. While the underlying engine is the same, Jolla’s implementation is completely different.
For example, I think (please correct me if I’m wrong) that the native browser is single threaded or single process (no electrolysis perhaps?).
If you check in something like top or Crest, you’ll notice that AAS Firefox will spawn separate processes for different tabs whereas the native Jolla browser is just one. This all boils down to implementation details, as I said.
Try this, makes it a lot better:
I use gecko-next153 from Openrepos myself, it has better performance on many sites (but different problems on others and needed some config flags to work properly).
And yeah, I think I heard somewhere that Jolla were going to update the browser to 140 but then decided to go staight to 153 instead which I guess delayed the release. A recent OS update did update the browser which made it a little smoother, but it’s still using an ancient gecko version.
I guess it would be great if you shared those fixes in separate dedicated to ESR 153 topic.
They can be found in its’ comments section on Openrepos
Here might be useful for more people.
Well, here’s my config if someone wants it. Feel free to put it in whatever thread you want. I don’t personally want to start a new thread since I don’t have anything more to add at this point.
cat ~/.local/share/org.sailfishos/browser-next153/.mozilla/user.js
user_pref("gfx.webrender.compositor", false);
user_pref("gfx.webrender.compositor.force-enabled", false);
user_pref("layers.acceleration.disabled", false);
user_pref("browser.disable_pickers_background_tabs", false);
The first 3 are all related to turning hardware rendering on (having it disabled makes the browser blink, it should be on by default but for me and some others, it’s not), not sure all of them are required… And the last one makes image pickers work.
ESR 115 is not ancient, it’s still supposed and receiving updates. In fact I believe this might be the first time that the SFOS browser is running a supported Gecko version.
