REPRODUCIBILITY: 100%
OS VERSION: 4.4.0.64
HARDWARE: Xperia 10 III
UI LANGUAGE: English
REGRESSION: Not relevant for Xperia 10 III as first release; Previous releases and previous phones (e.g. XA2) did not have this problem.
The weather display at the top of the Events screen stops updating with either ‘No Network’ where the ‘Foreca’ label is, or a constantly rotating circle when you click on the weather display to toggle it from the week view to day view.
When this occurs, no other Sailfish app is affected by a loss of network connectivity - you can continue to browse the web on the stock browser, receive emails, send Fernschreiber telegram messages, etc.
Re-booting the phone or restarting the network subsystem using Settings/Utilities restores the connection to the weather display until the next time it fails.
This situation occurs on both wifi and mobile data and it seems to make no difference whether Mobile settings are set to ipv4 or dual.
It is not known when the connection actually fails - it could fail much earlier than when you try to toggle the display as it is not easy to determine whether the weather display has automatically updated or not just by looking at it.
Weather display on the events screen
- Tap on the Events Screen weather display to toggle it from week view to day view or vice versa
- See ‘No Network’ or continuously rotating circle indicating it is trying to update
Weather display sucessfully toggles and/or shows updated current weather position
Weather display not updated due to loss of network connectivity
None - Newly flashed Xperia X10 III - stock setup with no patches or modifications. Sailfish X Android support installed and operational. VoLTE not enabled.
