BUILD ID = OS VERSION (Settings > About product): 4.0.1.45 (Koli)
HARDWARE (Jolla1, Tablet, XA2,…): XA2 Plus Dual SIM
UI LANGUAGE:English
When there is a new voicemail, the notification appears as normal but tapping the notification does not do anything. If I open the phone app and press/hold the 1 key, which normally calls for the voicemail, there is a little popup that says the voicemail number is not configured. BUT if I go to Settings->Apps->Phone, I can see that SIM1 (I only have the one SIM card) shows a voicemail number that is correct.
Upgrade to 4.0.1 … this worked fine in the previous version(s).
Receive a voicemail
Try entering voicemail box by tapping notification
Try entering voicemail box by long-press 1 in the Phone app
Calls voice mailbox
Tapping voicemail notification: does nothing
Long-press 1 in Phone app: Get popup saying “No voicemail number is defined”
I’m not sure what else to put here? Calling voicemail by manually pecking in the number works fine. Happy to provide any additional info like logs if someone can point me to them.
I guess this is pretty old now, but I have this issue too on Kvarken (4.1.0.24). Long-pressing ‘1’ in the phone app say “No voicemail number is defined” even though it is actually defined in Settings → Apps → Phone.
Dialing the number manually by copy-pasting the number from the settings works fine. I’m using the Xperia XA2 single SIM.
There is a bug in version <= 4.3.0, the notification either do nothing or just bring up the phone application without dialing the voicemail centre. I’ve corrected this bug (there was actually two bugs), see :
