thank you ![]()
I didnât know that the Jolla Store did offer it as I once installed it via OpenRepos and it worked ever since.
kicking the previous one again and re-installing it via the Store worked.
thanks again.
thank you ![]()
thanks again.
Then I must have been using the Store version ![]()
There is a HARBOUR on/off parameter during compiling, so the resulting software can differ, which can explain the crash of the OpenRepos version.
I just compiled ver. 2.1.2-2.armv7hl.rpm with the git-repo from kan_ibal with HARBOUR OFF and using 5.1.0.11 as environment. That version works fine, so it looks just a matter of recompiling I would say.
Reinstalled Openstore version of original Unplayer works as well. My version must be recompiled due to taglib change in SFOS.
thank you, too.
I might need to re-install the Openrepos/Openstore thingy, that might also help in my case.
Iâll give it a try.
also thanks for maintaining unplayer.
Was just mucking around and managed to get equeimâs unplayer to build on OBS, and now I noticed kan_ibalâs package with even better updates (upstream taglib and qtmpris).
Rings a bell that store apps canât pack their own mpris to handle media keys and indeed the CMake switch changes the media keys.
The Bus error crash that required a recompile for openrepos probably happened in the media key handling path that calls into mpris.
@kan_ibal see this PR, with that your fork becomes compilable on the OBS instance at build.sailfishos.org and should be then add-able to SailfishOS::Chum.
When selecting music by folder, the âSD Cardâ (3) option in the top menu doesnât work for me. Selecting it takes me back to the âBase Folderâ (4).
However, you can navigate to the SD card on your own and âSet as Default Directoryâ (1). Selecting âDefault Directoryâ (2) from the top menu afterward works.
Iâve attached a screenshot because Iâm not sure what the correct translation of the top menu entries is.
It uses /media/sdcard symlink. Looks like a SFOS does utilize it no more.
Itâs /run/media/defaultuser/<uuid>
No, it is not. You barely understand what you are talking about.
Hi, could you please also add support for wma files? Or is it not possible?
It is not trivial. wma codec is not included in SFOS by Jolla because is proprietary and must be paid for commercial uses.
Use DeadBeef for wma files.
Right. Thatâs what I was using but I was hoping to find something with a prettier interface
thank you!
