My only problem with Unplayer is the lack of gapless playback, but I use it basically daily ![]()
Should you are not sure why do you are wasting my time? I do not waste my time on nonames from internet that are to lazy to do their homework.
I guess ganya the dev stikes again. x)))
Glad there is Sailjail for your kind.
Great to have this great app revived!
Are also sources available?
Thanks
Is this your repo?
Yes. 20 characters and few more
I wondered if I should:
- look at a number of your forks and add .github action builds
- implement a tag/release schema to obs
- add spec details for chum
- push to chum (ie. if you canāt be bothered).
since you listen to math metal, I guess that might lead to madness ![]()
Some of them are definitely worth it. Audio players are certainly among them.
Thereās also Muuzik!, which Iām trying to revive.
name them in order of importance and Iāll get on it.
Interesting I did not know that bazillion of metal genre, it sounds like a mix of Satriani, Korn and Violent Work Of Art ;).
Can confirm, some CDs start sounding even more off beat than they are!
unplayer is quite alright already, but Muuzik! could definitely do with some love. there is a lot of features that donāt work. Even if music playback does. ![]()
can anyone confirm that unplayer is not working anymore after upgrading to 5.0.1.11?
it was prior to updating. de-install and re-install from openrepos doesnāt seem to do the trickā¦
Yes, the current version of Unplayer is not working.
are there any possible workarounds?
would a rollback to a version prior to 5.1.0.11 work or is that more or less unfeasible?
Unplayer has no issues on my Xperia-XA2 Plus running SFOS 5.1.0.11. Could be a 64-bits issue then.
strange.
I use a XA2 Plus. I updated about two hours ago and it worked prior to that today.
currently it starts up (read: the tile comes up, the circle runs as it tries to open) and then the tile closes without the app even being openend.
edit:
I get this when using the shell to start it:
[nemo@Sailfish ~]$ harbour-unplayer
[D] unplayer::LibraryUtils::initDatabase:479 - Initializing database
[I] unplayer::LibraryUtils::initDatabase:520 - Database initialized, file path: ā/home/nemo/.local/share/harbour-unplayer/harbour-unplayer/library.sqliteā
Segmentation fault (core dumped)
I installed Unplayer from Store, and that worked just fine. From OpenRepos⦠not so much.
