BUILD ID = OS VERSION (Settings > About product): 4.4.0.58
HARDWARE (XA2, X10, X10 II, …): X10 II
UI LANGUAGE: en
Mounting of sdcard with FAT filesystem via SETTINGS->System->Storage is not possible. It reads “Unsupported memory card” and attempt to mount ends up with pop up “The file system is incopatible. Formatting is needed”.
Sdcard is already formatted and used to work. The scard is not visible in UI i.e file browsers but is already mounted and visible via command line in /run/media.
FAT formatted sdcard, (encrypted ext4 sdcard is mounted properly)
- Have already working phone with 4.3.0.15 and sdcard with FAT filesystem
- Update to 4.4.0.58
- Reboot
Next reboot doesn’t change anything.
Sdcards properly handled .
as mentioned
I could have worded my reply better: it sounds like a system bug and I’m relieved File Browser isn’t affected and isn’t the culprit.
