BUILD ID = ANY
HARDWARE (XA2, X10, X10 II, …): All supported Xperia phones
UI LANGUAGE: All
REGRESSION: No
In it’s current state, Sailfish doesn’t allow to use the phone using one hand.
It’s even a bigger problem since, new “frying pans” are only getting bigger.
Install SFOS on any supported device.
- Take your phone with SFOS
- get out of the home
- go to the shopping center
- buy some water and take it into one hand, move one
- during walking have water in one hand, then with the other try to turn on music player with one hand and pick up random play.
- Then try to open browser and search for the nearest bus station, try to find the closes bus arrival hour.
- reply to some sms.
- put phone into the pocket
- come to the shop, stop music player, drop out empty water bottle into trash, take out the basket into one hand and a phone into another, open a shopping list and move on to pick up stuff.
Try to do all above with just one hand!
All the above functions should be possible to do with just one hand holding and operating the phone
It’s not possible to do the above using one hand, the phone is to big and the system is not designed to be easy to use in one hand mode.
people doesn’t have big hands, and the possible range of the thumb is very very limited. Consider fixing this as phone is a mobile device. Peoples are using it during walking, shopping, jogging etc etc and they often need to use one hand to open doors, take out groceries etc while do stuff on the phone with the other one.
