Unable to enter pin code when connecting to car stereo via bluetooth
REPRODUCIBILITY:
OS VERSION: 4.4 (4.4.0.72)
HARDWARE: X10 III
UI LANGUAGE: English
REGRESSION: Yes
When trying to pair my mobile to a ford car stereo via Bluetooth i need to enter a 4 digit random code but as the keyboard isn’t displayed i cannot enter to pair with the car system.
Mobile Bluetooth on
Ford Mondeo car stereo
  1. Turn on Bluetooth
  2. Search for devices
  3. Select the Ford Car stereo displayed
Keyboard popups or numeric pad so that you can enter the code displayed on the car stereo to complete the pairing process.
Unable and fails to pair.
I only installed Sailfish OS yesterday so its pretty standard.
I have had similar problems with my previous Sony Xperia 10 Plus, usually after an upgrade, i finally found a workaround which was to reset the mobile and it worked but that is a drastic test as i have set lots of things up so far and it wasn’t an upgrade this time.
Duplicate of [4.3.0] [4.2.0] Can't pair Bluetooth to device asking PIN code
Managed to resolve via the terminal using the instructions via other issues raised.
