And, caught an error in the no transaltion, so we advance to version 1.2.4. Sorry @molan … it’s building now. I tested the translations this time ![]()
Where would i see this icon usually if i want to check if it is entirely missing in my Installation?
Jolla camera app. Turn on the flash.
Ah, could have guessed that, sorry. In that context the icon is available
I’ll go pull a local version or the like. There are a couple of others that, I suppose, could fail. Odd, though.
May I suggest a different icon: icon-l-diagnostic?
I think the flash looks a bit clunky next to the others…
Though diagnostic has a border while the others do not, maybe it’ll look out of place…
Yes, right you are. I think I’ll try to find something more apt. .-.-*-*
@nephros, I’m not sure about stylistic congruity but I think the icon I use now is more apt. I had to update the Norwegian translation whereupon … announcing version 1.2.5
@molan sorry for the frequency ![]()
I still don’t see the icon for the trending tab, but i found out that i do see it when i switch to landscape mode, so the icon exists.
Must be a spacing issue
No worries
Thx @poetaster ![]()
Ah, ok. Do you know the dimensions of your phone’s display?
It has a resolution of 1080*1920, does this suffice or do you need measures?
Thanks! That helps! I just need to see if there is some odd boundary condition.
On my smaller XA2 screen, you can actually scroll the icon bar at the bottom, pulley-style, to reveal the new icon.
Indeed, i can also scroll to reveal the new icon. Didn’t find that, sorry
Yeah, but that sucks. It should not be necessary
It’s got a github ticket ![]()
Ok, here’s a big one: announcing version 1.3.0 of tooter! Lots of fixes, mosly NOT mine….
- edit toot
- slideshow of more than one image in a toot
- mini previews of links where possible
- quote toots
- proper multi-person response
- alt text for media uploads
- polls are visible
- a new finish translation
- fix for deduplicatoin
- fix for minor profile bug
- a number of potential race conditions
- other !
Up at: Release 1.3.0 · poetaster/harbour-tooter · GitHub built on chum and coming soon, coming soon to harbour … @molan You’ll like this release.
99% of the heavy lifting is from GitHub - laril/harbour-tooter: Tooter is Mastodon client for Sailfish OS. @lari@suomi.social
You may notice that a lot of the code was generated by claude code. I reviewed every line. The reader feature, which you can enable’ is one I may rip out again. But not because of claude. Just a question of managing deps. In the main, claude code did a nice job.
Fantastic - With great new features!
A huge leap for Tooter, thanks to everyone involved!
I think we can soon change the ‘beta’ to ‘omega’.
Amazing, thank you! Also at laril
. Openrepos is up to date and I look forward to check out the new code.
