And finally the remaining multiple account integrations from @roundedrectangle Thank you very much! Version 1.2.1 Release 1.2.1 · poetaster/harbour-tooter · GitHub
In this run I’ve updated to the latest github actions from @coderus which I find really easy to use, in this case for multi-arch builds. have a look at the .github/workflows/main.yml file.
The builds are in the queue at harbour and chum…
Thank you for a wonderful application. Its only problem it does not appear Notification
What do you get if you open your terminal and exec harbour-tooterb? Because it’s working on my side.
navigate to :207- notifications
onStatusChanged:40 - PageStatus.Activating
onStatusChanged:45 - PageStatus.Inactive
mmh, doesn’t help. And does it work if you visit Mastodon on your browser?
Yes, it works and shows the publications
What do I do and do this bug
Are you on a mastodon server or pixelfed? Do the other pages show proper content?
Sometimes that’s just a network error and goes away on it’s own if you reload. Also, try restarting.
I use the Mastodan.social Server and all the other pages offer everything in the exception of Notification and i Try restarting and nothing changes
I added a Pixelfed account and shows Notification Well, can it be from Server Mastodon
That is why I asked
I’ll investigate what kind of output is coming from mastodon.social … I may need your help. I’m a bit ill so it may take a few days….
Ok thanks for the response, be fine
Announcing version 1.2.2 Release 1.2.2 · poetaster/harbour-tooter · GitHub
This release is a maintenance release with updates to translations and an error handling routine from @roundedrectangle and a new submission of a Norwegian translation from @frankps THANKS!
EDIT: rpms up on github, in the queue at harbour and chum … @molan can you kick the queue on openrepos, please
Thank you for maintaining!
I’m also wondering whether you have looked into the possibility of adding alt text? I often post pictures and would use Tooter so much more often if I could describe them.
yes, alt-text and editing are two priority tickets in the repo. I’ll try to get to them in January. I have not had much time; doing product development.
Great news that it’s on the roadmap! January or later, that is entirely up to you. I’m just happy to hear that it seems doable for you.
Thank you!
Ah, announcing version 1.2.3 of tooter. The last update was incomplete where the Norwegian translation is concerned. Hopefully it’s now correct. To make a release more rewarding, I added a trending view (last icon after search) as suggested by aevare (aevare) · GitHub
Up on github and coming to chum and harbour.
Forgot to ping @molan
Thanks!
I also noticed that harbour still has 1.2.2 in the queue. So, it looks like a jump release ….
I installed the latest update and the icons at the bottom are shifted to make space for an additional one, but the space is empty and nothing happens if i tap there. However, i can access the new trending tab by swiping to the side through the caroussel
Hmmm. That’s a system icon. The camera app flash on icon. So it’s surprising it’s not there?
