Shouldn’t sfos-upgrade (plus later post_sfos-upgrade) exactly do this, but in an automatic way?
Once upon a time I ran into problems skipping versions and directly jump to the latest, other times only a reflash with the latest version helped me out.
I think that’s the idea and am sure it’s a reasonable way to go. I just prefer to do it directly without any filters. I have no experience using sfos-upgrade but a lot of experience with zypper
One does not need to walk through each point release (as @poetaster already assumed) and hence sfos-upgrade does not do that. As denoted in its description, it does automatically upgrade to the next stop release (hence preventing to omit installing a stop release), regardless which release you specify as parameter. Note that all SailfishOS releases since 3.4.0 have been stop releases: 3.4.0, 4.0.1, 4.1.0, 4.2.0, 4.3.0, 4.4.0 and 4.5.0.
Nahhh, I didn’t. On my first try I flashed directly on Android, without flashing Volla OS before. But my device was delivered with version 11 and I flashed over the delivered version, without making any updates before.
I’m sure, that I read somewhere that flashing SF over Android 12 lead to problems. Don’t ask me in which thread, but I’m quite sure, I read something like that.
Actually, is there a way to check which android version was in the phone before flashing?
@piggs maybe you know how?
And also, other subject, is there a way to access the phone partitions like we do with the recovery image on Xperias?
That would be handy to make backups.
Hm. For both the GS5 and the rephone, I flashed the Volla22 VollaOS image using ubports. No issues. The issues that there are, ie. borked firewall, somewhat flaky SIM handling are not related to android? What am I missing. With ubports it’s volla-11.1-20221017-stable-SPFLASH-mimameid.zip so, looks like an 11. Flash that and you’ve downgraded.
Well, I flashed it with Installer to vollaOS. Flash successfully finished, BUT now it doesn’t power on anymore. No matter which buttons I press and how long. I tried all combinations even 2 minutes
