Copied via ssh a Video to /home/defaultuser/Videos and downloaded a large file from internet (ubuntu server) to /home/defaultuser/Downloads
checked partiton information in system settings (while copying). Obervation here: space on home partition is descreasing, just like one would expect. BUT space on root is decreasing as well and in same dimension . Result is this:
I have deleted /etc/sailfish-device-encryption-community/config.ini and started with a new home partition. I start with more space on home. Onle 2.9 GB are used. But the symptoms stay the same.
Shall I try to flash Volla Os again in between? And shall I update this to the newest version? I haven’t done this the last time. I flashed Volla OS once and imediately afterwards I flashed SF.
I used the image from here: Jobs · sailfishos-porters-ci / Halium Mimameid Ci · GitLab (The two month old testing image).
Yipiieeeh This indeed fixed the problem!
Thanx a lot. One question. When I search for Wlan all access points show up three times. Is this normal? Just a minor issue.
@piggz As soon as my rephone is set up completey. A crate of beer will be donated
One further minor thing: Whenever I work with Terminal, the hole gui gets after a while unresponsive and laggy.
Closing it, all is fine again. I use original fingerterm at the moment. Not busybox. Anyone else recognized that?
I wanted to try Arch Linux on Gigaset GS5 but it seems too much work and lack of knowledge.
But, looking for an alternative. Postmarket is broken and also android-based os won’t help me.
I haven’t try UT because I heard it’s somehow closed for volla and also I want to be respectful to hardwork of Volla community but if UT is possible to be installed on GS5 i’m willing to donate for volla or UT
Followed the instructions,
It got stuck at the point of setting slots(Installer) and on phone showed fastboot mode.
No change in a long time.
reboot and android is up again
Is presage possible? Has somebody it running?
I haven’t found a way to install. On Storeman there is no installable package.
When I try to install from Chum i need to install maliit-presage-plugin. But this is complaining, that presage-data is not available. Even so presage-data is already installed.
Thanks for your reply. That was my fault. I have forgotten to deinstall a wrongly (outdated) installed package . After unsinstalling it, installation went flawless.
Is here anybody using Sailfish connect? I’m using it quite often and with the rephone I have massive problems, because it acts quite random. Sometimes it connects sometimes not. Most times it doesn’t see other devices (and isn’t seen as well). That is the first really annoying thing so far (besides the notch, which is simply a horrible thing - but I’ ll get hopefully used to )
