Hmm, dunno. People talk about cryptocurrencies… No experience with that but I could make an effort. Always curious.
On the other hand, I heard that mining was not so climate friendly, so…
Someone? About how to transfer some money for free?
I just had to do this today, but with a single sim GS5. After reboot, without PIN/SIM, I ONLY
- went to the settings for PIN code,
- noted it was off,
- turned it on,
- entered pin, nothing happened
- with it still open at the PIN prompt rebooted.
On reboot, it was there. I’m pretty sure it has something to do with the settings for PIN code not being read or being reset. Just to confirm, rebooted my Rephone just now. Came up without PIN/SIM. On the frist repeat of the above, it was not set on reboot. The second time, I closed the Preference app before reboot and got my PIN prompt. @piggz can you think of a reason why the PIN code requirement setting might be turned off on reboot?
Are you guys able to use a VPN on the Volla22/GS5?
Ok, it could of course be a completely different phenomena with 2 sims. I just, for the heck of it, went to the settings,
- UNchecked PIN code, authorized with PIN
- REchecked PINcode, authroized with PIN
- Close Preferences
- Rebooted
Phone came up with with both authorization screens and the SIM worked immediately. That was the GS5. Maybe, with SIM working normally, try that?
I tried. No way for me.
Even the trick that worked 3 times the other day isn’t working.
Deleted my post and ordered a talkie-walkie and some envelopes
Some time later…
It worked after multiple reboots and PIN fiddling. Puzzling!
VPN dont work!!!
on Gigaset
Ok ,thank you.
And wifi hotspot to share mobile data, is it also not working?
hello sir,
hotspot mobile data its ok
Did you remember to buy some stamps? I always forget those.
I’ve repeated the procedure just to test and it works consistently on two devices. I think it’s probably different with two pins? did you get prompted for two PIN codes or just one?
What VPN provider? Settings?
Yes, exchanged my GS5 for 15kg stamps😁
Generally, both SIMS are working, hence two PINs asked, or none.
Perhaps yes, procedure is different for double SIM models…
As Vpn, I tried ProtonVPN with router configuration and some per-server configuration files. At least some of them were working on my XA2.
Here, when I chose the file, press accept and click on the VPN line to connect, complain toggles between ‘idle’ and ‘Problem with connection’
Mullvad VPN with Openvpn file…
Network provider? ipv6/ipv4? There’s still a lot of acivity in the ProtonVPN thread …https://forum.sailfishos.org/t/revisiting-protonvpn-can-it-be-made-to-work which you’ve probably seen?
can i update my GS5 to 4.5.0.21 via ssu ur…
in time … but after my family holiday, so, sometime after 22nd July!
Have a happy holiday … !
Connecting through wifi and Swisscom gprs.
From my PC connected to th wifi, vpn is working with my ProtonVPN account.
On the GS5, same wifi, complain toggles between ‘idle’ and ‘Problem with connection’.
I tried to leave default or disable IPV6 but have the same result.
`journalctl -f` output while trying to connect to the VPN
Jul 13 17:25:16 Phone22 kernel: .(0)[231:pbm][GPU/DVFS][INFO]@__mt_gpufreq_update_max_limited_idx: g_max_limited_idx = 10, g_limiter = 4
Jul 13 17:25:16 Phone22 estart[3598]: [D] unknown:0 - VPN autoconnect changed: “ch-pays.protonvpn.net.udp” true
Jul 13 17:25:16 Phone22 lipstick[3396]: [D] unknown:0 - VPN service property changed: “AutoConnect” QVariant(bool, true) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:16 Phone22 estart[3598]: [D] unknown:0 - VPN service property changed: “AutoConnect” QVariant(bool, true) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:16 Phone22 estart[3598]: [D] unknown:0 - VPN service property changed: “Timeservers” QVariant(QStringList, (“0.sailfishos.pool.ntp.org”, “1.sailfishos.pool.ntp.org”, “2.sailfishos.pool.ntp.org”, “3.sailfishos.pool.ntp.org”)) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:16 Phone22 lipstick[3396]: [D] unknown:0 - VPN service property changed: “Timeservers” QVariant(QStringList, (“0.sailfishos.pool.ntp.org”, “1.sailfishos.pool.ntp.org”, “2.sailfishos.pool.ntp.org”, “3.sailfishos.pool.ntp.org”)) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:16 Phone22 lipstick[3396]: [D] unknown:0 - VPN service property changed: “State” QVariant(QString, “association”) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:16 Phone22 estart[3598]: [D] unknown:0 - VPN service property changed: “State” QVariant(QString, “association”) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:16 Phone22 systemd-udevd[4587]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Jul 13 17:25:16 Phone22 lipstick[3396]: [D] unknown:0 - VPN connection property changed: “PreventIPv6DataLeak” QVariant(bool, false) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:16 Phone22 connman-vpnd[4588]: error setting gid -1 Invalid argument
Jul 13 17:25:16 Phone22 connman-vpnd[4588]: error setting gid list Invalid argument
Jul 13 17:25:16 Phone22 lipstick[3396]: [D] unknown:0 - VPN connection property changed: “State” QVariant(QString, “association”) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:16 Phone22 kernel: .(0)[231:pbm][GPU/DVFS][INFO]@__mt_gpufreq_update_max_limited_idx: g_max_limited_idx = 12, g_limiter = 4
Jul 13 17:25:16 Phone22 estart[3598]: [D] unknown:0 - VPN connection property changed: “PreventIPv6DataLeak” QVariant(bool, false) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:16 Phone22 estart[3598]: [D] unknown:0 - VPN connection property changed: “State” QVariant(QString, “association”) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:16 Phone22 lipstick[3396]: [D] unknown:0 - VPN connection property changed: “State” QVariant(QString, “failure”) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:16 Phone22 kernel: .(1)[231:pbm][GPU/DVFS][INFO]@__mt_gpufreq_update_max_limited_idx: g_max_limited_idx = 10, g_limiter = 4
Jul 13 17:25:16 Phone22 estart[3598]: [D] unknown:0 - VPN connection property changed: “State” QVariant(QString, “failure”) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:16 Phone22 lipstick[3396]: [D] unknown:0 - VPN service property changed: “State” QVariant(QString, “failure”) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:16 Phone22 connmand[3083]: Connect reply: Input/output error (net.connman.Error.Failed)
Jul 13 17:25:16 Phone22 estart[3598]: [D] unknown:0 - VPN service property changed: “State” QVariant(QString, “failure”) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:16 Phone22 kernel: .(1)[231:pbm][GPU/DVFS][INFO]@__mt_gpufreq_update_max_limited_idx: g_max_limited_idx = 11, g_limiter = 4
Jul 13 17:25:16 Phone22 kernel: .(4)[231:pbm][GPU/DVFS][INFO]@__mt_gpufreq_update_max_limited_idx: g_max_limited_idx = 11, g_limiter = 4
Jul 13 17:25:16 Phone22 kernel: .(1)[4593:pool-ofonod]binder: 2694 has pending async transaction, but still adding a new transaction to todo list (gbinder bug workaround)
Jul 13 17:25:16 Phone22 kernel: .(1)[231:pbm][GPU/DVFS][INFO]@__mt_gpufreq_update_max_limited_idx: g_max_limited_idx = 12, g_limiter = 4
Jul 13 17:25:16 Phone22 kernel: .(2)[231:pbm][GPU/DVFS][INFO]@__mt_gpufreq_update_max_limited_idx: g_max_limited_idx = 10, g_limiter = 4
Jul 13 17:25:17 Phone22 kernel: .(2)[231:pbm][GPU/DVFS][INFO]@__mt_gpufreq_update_max_limited_idx: g_max_limited_idx = 12, g_limiter = 4
Jul 13 17:25:17 Phone22 lipstick[3396]: [D] unknown:0 - VPN service property changed: “Timeservers” QVariant(QStringList, (“0.sailfishos.pool.ntp.org”, “1.sailfishos.pool.ntp.org”, “2.sailfishos.pool.ntp.org”, “3.sailfishos.pool.ntp.org”)) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:17 Phone22 estart[3598]: [D] unknown:0 - VPN service property changed: “Timeservers” QVariant(QStringList, (“0.sailfishos.pool.ntp.org”, “1.sailfishos.pool.ntp.org”, “2.sailfishos.pool.ntp.org”, “3.sailfishos.pool.ntp.org”)) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:17 Phone22 lipstick[3396]: [D] unknown:0 - VPN service property changed: “State” QVariant(QString, “idle”) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:17 Phone22 kernel: -(3)[4437:sshd]eth_start_xmit: 35 callbacks suppressed
Jul 13 17:25:17 Phone22 estart[3598]: [D] unknown:0 - VPN service property changed: “State” QVariant(QString, “idle”) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:17 Phone22 estart[3598]: [D] unknown:0 - VPN service property changed: “IPv4” QVariant(QDBusArgument, ) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:17 Phone22 lipstick[3396]: [D] unknown:0 - VPN service property changed: “IPv4” QVariant(QDBusArgument, ) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:17 Phone22 lipstick[3396]: [D] unknown:0 - VPN service property changed: “IPv6” QVariant(QDBusArgument, ) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:17 Phone22 lipstick[3396]: [D] unknown:0 - VPN service property changed: “State” QVariant(QString, “association”) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:17 Phone22 lipstick[3396]: [D] unknown:0 - VPN connection property changed: “State” QVariant(QString, “disconnect”) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:17 Phone22 lipstick[3396]: [D] unknown:0 - VPN connection property changed: “State” QVariant(QString, “idle”) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:17 Phone22 estart[3598]: [D] unknown:0 - VPN service property changed: “IPv6” QVariant(QDBusArgument, ) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:17 Phone22 estart[3598]: [D] unknown:0 - VPN service property changed: “State” QVariant(QString, “association”) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:17 Phone22 estart[3598]: [D] unknown:0 - VPN connection property changed: “State” QVariant(QString, “disconnect”) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:17 Phone22 estart[3598]: [D] unknown:0 - VPN connection property changed: “State” QVariant(QString, “idle”) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:17 Phone22 lipstick[3396]: [D] unknown:0 - VPN service property changed: “State” QVariant(QString, “disconnect”) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:17 Phone22 lipstick[3396]: [D] unknown:0 - VPN service property changed: “Domains” QVariant(QStringList, ()) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:17 Phone22 lipstick[3396]: [D] unknown:0 - VPN service property changed: “Proxy” QVariant(QDBusArgument, ) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Jul 13 17:25:17 Phone22 lipstick[3396]: [D] unknown:0 - VPN service property changed: “State” QVariant(QString, “failure”) “/net/connman/vpn/connection/138_199_6_178_sailfishos_org” “ch-pays.protonvpn.net.udp”
Is the only thing that caught my attention. But I really don’t know. I haven’t tested a VPN for ages.
Stupid question, did you try any other vpn?
Thanks for looking at the log.
I didn’t try, as I have a plan at Proton and as it was working well on the XA2.
