BUILD ID = OS VERSION (Settings > About product): 4.1.0.24
HARDWARE (XA2, X10, X10 II, …): Xperia 10 II dual SIM
UI LANGUAGE: English
The sound quality when calling or receiving calls on roaming is very, very poor. Sometimes so weak that you cannot hear the other person. Sometimes with so much noise that you can not hear for that reason.
(And sometimes the sound quality is good for half a minute to 1 minute, but never for longer then that.)
This is when not using a headset, but using either the loudspeaker, or using it without the loud speaker.
The sound quality with a wired headset is quite OK - but has a noise to it.
The sound quality using Bluetooth is absolutely superb. Best of all phones I have used.
When not on roaming the sound quality is excellent.
I have tested this on 2 x Xperia 10 II dual sim white, european version and 1 x Xperia 10 II dual sim blue, Hong Kong version.
After testing for over an hour I can add the following:
It is when it is a phone call between 2 phones from the same mobile operator that it does not work.
Calling from my wife’s Telenor to my Telenor - does not work. (Both on phones on roaming.)
Same if calling from my son’s Telenor to another Telenor. (On roaming.)
In spite of having used a long time to try to help Jolla sorting a basic error that does not affect any other phone, the response, except for a short question, has been silence.
One would expect updates that either you could not resolve it, or you needed more information.
Not silence.
I hereby leave this forum and cancel my registration for it.
