BUILD ID = OS VERSION (Settings > About product): 4.2.0.21
HARDWARE (XA2, X10, X10 II, …): X10 II
UI LANGUAGE: German
During phone calls the phone ear speaker produces the hum/buzz sound (known from a cellphone being placed next to an external speaker) for the complete time of the phone call. This sound is also heard by the receiver of the call on his telephone. Changing the sim card to another provider did not solve this problem. Also setting the network from 4G to 2G did not solve the problem. Signal strength is above 50% or much higher. This sound is not heard when making a phone call e.g. via Whatsapp.
None
Make a phone call
Clear audio, similar to previous phones (e.g. Xperia X with Sailfish OS)
BUILD ID = OS VERSION (Settings > About product): 4.3.0.12
UI LANGUAGE: German
I have the exact same issue, does not look like anything has changed since the last updates.
UI LANGUAGE: English
I just bought a xperia 10 II and Im also having the exact same issue
If I use the speaker phone functionality, person on the other end hears the same distortion.
I use a 10ii too, but for me the call quality is great. However, the people on the other hand of the line are complaining pretty often, and handsfree/speaker mode seems to be completely broken.
I am using the dual-sim model (XQ-AU52). Unfortunately, the problem still persists and even if the phone is reverted back to the Android operating system. Therefore, it might be a hardware problem as the noise is not hearable, when
a headset is plugged in
the phone speaker for hands-free talking is used
a Bluetooth headset/ car audio is used
Sony and the seller refuses a warranty repair and they wanted to replace the mainboard first. However, I am not sure, if that is the problem or if only the speaker/ internal microphone has a defect. Any suggestions?
Any News here. My Xperia 10ii make also during phone calls hum/buzz sound for the other site. I mean its a problem with the sensitivity control. Whenever I make a noise, the hum better buzz goes away. I will try to set the micro on 90% with pactl set-source-volume 2 90% and systemctl --user restart pulseaudio.service…
The embarrassing thing is, you can’t hear it yourself.
pactl list sources gave follow information:
Quelle #2
Status: SUSPENDED
Beschreibung: Droid source droid
Treiber: module-droid-card.c
Abtastwert-Angabe: s16le 1ch 44100Hz
Kanalzuordnung: mono
Besitzer-Modul: 1
Stumm: nein
Lautstärke: mono: 58982 / 90% / -2,75 dB
Verteilung 0,00
Basis-Lautstärke: 65536 / 100% / 0,00 dB
Ziel-Monitor: k. A.
Latenz: 0 usec, eingestellt 0 usec
Flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME
Eigenschaften:
device.description = “Droid source droid”
device.class = “sound”
device.api = “droid-hal”
droid.input.external = “true”
droid.input.builtin = “true”
droid.hw_module = “primary”
device.icon_name = “audio-card”
I have solve this for me!
I changed the file “etc/pulse/xpolicy.conf”.
I add “, limit_volume” in line 131:
old:
129 [group]
130 name = call
131 flags = set_sink, set_source
Same humm/buzz sound here as well (Sony Xperia 10 II 2 simcard model).
I have tried to modify /etc/pulse/xpolicy.conf as suggested by @rdomschk (Thanks!) and did a restart, but this did not fully solve the problem for me. (Maybe it got improved, but if so, only a little bit.)
Does somebody know, what the limit_volume flag does? (Did not find it in the pulse documentation).
I think with “limit_volume” the phone use also in a call the microphone volume limit from this here “pactl set-source-volume 2 150%”. But I am not shure.
Still a problem here. With limit_volume in /etc/pulse/xpolicy.conf I did a test and found out that
pactl set-source-volume 2 30%
does not change the microphone level for me (during a call).
While pacmd list-sources did show different value, and pactl set-source-mute 2 1 and back worked, changing the volume did not.
However during a call all pulseaudio sources are suspended, as verified by pacmd list-sources | grep 'state:'
So for a regular run of the Jolla app “Audio recorder”, the sourcesource.droid is active and thus command like pacmd set-source-volume source.droid 50000 will work, and will reduce the microphone sensitivity.
The description of the used pulseaudio module from https://github.com/mer-hybris/pulseaudio-modules-droid-jb2q has a hint, it says that
When voicecall virtual profile is enabled, active droid-sink is internally switched to voicecall volume control mode. What this means is changing the sink volume or volume of normal streams connected to the sink do not change active voicecall volume.
Used version and arguments of the module can be seen by pacmd list-modules:
Using the hardware sound volume buttons, I can change the volume of this virtual sink-input, but I have yet to find a way to change the microphone sensitivity, it seems that this has to be done elsewhere and is not done in pulseaudio.
In a search for where pulseaudio might get its idea of microphone sensitivity, I found the configuration that are read by module-droid-card:
/vendor/etc/audio_policy_configuration.xml
In a neigbouring file /vendor/etc/audio_platform_info.xml there is data about microphone sensitivity, but it is unclear who interprets this file.
It may make a difference at which sensitivity levels the phone is set to before flashing.
It may make a difference when the phone is flashed because of the Android version on there. (I did flash the phone late and upgraded a lot of Android versions.)
Both could explain the difference some people are seeing with the same device.
