Does someone have such headset with SFOS in use?
In particular does the USB-C connection gets correctly recognized? Thanks for feedback …
Generic USB audio devices have been supported as long as there has been USB OTG support, so unless they are doing something strange, they should work. (I have just tested a couple of DACs/adapters, but should be the same thing)
Ok, thanks. I will give it a try …
have you tried a headset already? i think of buying one, because wired headsets tend to get their cable broken, my symphonized bluetooth earphones just turn off after a few seconds and have distorted sound and my klim fusion bluetooth earphones don’t turn on anymore…
