Sony Xperia 10 V brush sailfish os 5.0. 0.72, no real power display. The camera can’t take pictures or videos, Bluetooth is faulty, and the power display is faulty. After you use it for a period of time, the power display will not drop. Plug in the charger to charge, but it does not show how much power is charged. You must shut down and restart or restart before the real power will be displayed.
This is already covered in release notes, which mentions other bugs as well:
As an update to the release notes: One should use the v4b firmware so that the battery status is updated in real-time again. See also here: New binaries / blobs for Xperia V and IV : What is happening actually? - #20 by duvi
For Bluetooth: I just switch it on after boot (it takes a while) and never turn it off, then it works reliably.
