I bought the 8gb XQ-DC72 device off the following ebay listing:
Before I pulled the trigger I checked the sellers feedback, where there was nothing to give me any doubt.
Although the item is listed as being located in Switzerland, the address given in the ebay confirmation email is in Hong Kong. I suspected that might have been the case from the delivery schedule given in the listing.
Happily the phone arrived 8 days after purchase, with no customs fee, well wrapped and in good condition.
Sony’s packaging is as pictured earlier in this thread, and I’d like confirmation from @eson or @demislition that there was no plastic used at all.
It was very eco-friendly, to the point that there are no accessories (no cable, charger, etc), and the screen was protected by a lightly sticky paper covering.
I don’t think the device has been tampered with by the seller, and the reason is thus:
As @eson says, Android sucks! The device had a 54% charge when I turned it on, and was at the usual fresh startup screen where you have to choose the language. I went through a very basic setup, didn’t create or sign in on any accounts, and decided to shut it down and put the thing away, only I couldn’t! Holding the power button didn’t bring me the option, instead Google wanted me to sign in/up for some application.
Absolutely disgusting
I tried holding down the power and vol up/down button, but that only seemed to restart.
I ended up just putting it back in the box, and if the power runs out so be it, I’ll recharge the device and run the preflash tests towards the end of the month just in case the Sauna release brings support for it.
Anyway, that was the reason I don’t think the seller had tampered with it, as I think you’d have to go to the lengths of doing a factory reset to get to the state it was in when i first powered it up.
