Sony Xperia 10 III audio sources swapped
REPRODUCIBILITY: 100%
OS VERSION: 4.6.0.15
HARDWARE: Sony Xperia 10 III
UI LANGUAGE: Finnish
REGRESSION:
Other end can’t hear me during call because during call phone is using top microphone insted microphone below.
  1. start csd tool.
  2. select Individual tests.
  3. run Audio below microphone test. Put earpiece on your ear just like making a real call.
  4. listen test recording
  5. run Audio above microphone test. Put earpiece on your ear just like making a real call.
  6. listen test recording
Audio from below microhpone should be louder than from above microphone.
Audio from below microphone is barely audible. Audio from above micrphone is significantly louder.
None.
Seconded!
Xperia 10 III with SFOS 4.5.0.24 here.
If I do the top mic test it’ll be the other way round. Means then the bottom mic seems to do the recording.
Bug still exists in version 5.0.0.62
