I’m impressed that nobody commented nothing about this bug, I need to have call recording enabled on my phone ( I use it since jolla phone) and it’s very annoying to record a familiar video and notice there is no sound on it.
An important step for improving the speed of getting a GPS fix is to install one of the MLS Positioning packages from the Jolla store (search for “Positioning” or “MLS”). @wayn3, it’s possible this will help if you’re having trouble getting a satellite fix. See the 4.2.0 release notes for more info.
But MLS packages from Jolla Store are not updated, right? From my experience, this doesn’t improve gps positioning on my phone. I’ve tested that on my xa2 phone without finding an improvement, and as I said before, positioning gps works fine on my xperia 10 ii: I get position on <2 minutes
I got GPS working quite good now with some hints from the forum. I always keep the “GPSInfo” app open and some custom configuration in the gps.conf file. I use the nokia provider instead of the sony one now.
But still thanks, i installed the MLS packages and will see if it even improves everything.
I guess keeping GPS running (via leaving tbe GPSinfo app open) will always get you a quick fix because you’ll be tracking the satellites all the time, but at the expense of a bigger battery drain.
It’s true that the packages don’t use the most recent data, which differs from if the online MLS database was being used. But it is basically a list of cell tower IDs and locations. If a physical cell tower is removed/added and the database isn’t updated, it won’t trigger a hit in the database. So installing the packages shouldn’t make getting a GPS fix any slower, but may (should) improve things.
If I understand correctly from reports made elsewhere, there is something else going on with the XA2, so as you point out, experiences with the Xperia 10 II are likely to be different compared to the XA2.
In general, GPS will only activate if there’s an app requesting location info. If you have GPSInfo closed, is there some other app that you’re expecting will get location info, but which isn’t?
@flypig: In the past when i opened apps like the escooter app “Lime” or maps without starting “GPSInfo” before, GPS did not activate and i had no GPS in those apps. Now i tried it again, but after changing a lot of settings (nokia instead of sony as provider in gps.info + installed MLS packages) it suddenly works. It activates when opening the apps and stops when closing. So good behavior now. I don’t know what changed it exactly.
Thanks for replying and I’m glad things are now working as expected. Just to check, were the apps that were failing to activate GPS all Android apps? As far as you can recall, did you have the same problem (GPS not starting) with any native (non-Android) apps?
I only ask in case it helps better understand what the problem may have been.
Of course this is the way it works. Everything that is not needed is turned off to preserve battery charge. The sore point is that once turned off for a while the XA2 GPS receiver will take a lot of time to get a fix.
Thats exactly the reason why i want to be able to start GPS manually BEFORE I really need it and/or keep in a working state by manually switch it on, so that it can provide GPS data immeadetely if required by some app.
It’s absolutely nonsense from Jo* to let the user manually switch on GPS and do nothing, and when the user wants to access GPS data, there are none… In this case the settings should be named something like ‘allow GPS’ . But on should be really on and not something like standby or permission to eventually start with minutes delay…
Yes, but if i want to prepare for use of GPS in e.g. 10 minutes with Pure Maps, i can foresighted switch GPS on and start GPSinfo and do other things in the mean time. Later, if i really want to use it, it is ready synced and working. To save power, i close GPSinfo + Pure Maps and switch GPS off. That’s the workaround . It would be much more senseful if I could simply switch on GPS and it will work . If I want to save power , i switch it off. if I want to have it running I switch it on. I don’t need Jollas cleverness to save some battery power if I set GPS to on. If set to on, I want it simply to run and nothing else.
