Some TOHKBD2 functions no longer work
In particular, when using Alt-Tab to switch between running applications, or when using the function keys to open/switch to a specific application, the application’s .desktop file is opened in the web browser. I’ve already deleted my mimeinfo.cache file, but that doesn’t seem to have had any effect.
Edit: also, was TOHKBD2 removed from the Jolla store? It doesn’t seem to show up in my applications anymore.
Hi,
Have you tried sourcing from here? https://github.com/kimmoli/tohkbd2#installing-through-mer-obs-repo
It installs upon my Jolla 1 but whilst TOHKBD ambience installs upon fitting my FunkyOH don’t think “daemon” starts as keyboard does not light up.
You can find a workaround to that problem here:
