Hi Everybody,
I am trying to get some system informations in my app (e.g. Device UID, Device Model, etc.)
During my search I found the SailfishOS MDM API and it seems to provide all information I need.
My problem is I don’t know how to use it at all.
I tried to add as described in the documentation:
CONFIG += link_pkgconfig
PKGCONFIG += sailfishmdm
When I try to access this in my C++ code I get an error during compile:
Error: undefined reference to `SailfishApp::main(int&, char**)’
Is it possible to access this in a SailfishApp instance directly at all?
Or is there an other possibility to get this information in C++?
well, post your code and we can point to your mistake then
Hi,
here is my sample code.
MDM_Example.pro
TARGET = MDM_Example
CONFIG += sailfishapp
SOURCES += src/MDM_Example.cpp \
src/baseobject.cpp
DISTFILES += qml/MDM_Example.qml \
qml/cover/CoverPage.qml \
qml/pages/FirstPage.qml \
qml/pages/SecondPage.qml \
rpm/MDM_Example.changes.in \
rpm/MDM_Example.changes.run.in \
rpm/MDM_Example.spec \
rpm/MDM_Example.yaml \
translations/*.ts \
MDM_Example.desktop
SAILFISHAPP_ICONS = 86x86 108x108 128x128 172x172
CONFIG += sailfishapp_i18n
TRANSLATIONS += translations/MDM_Example-de.ts
HEADERS += \
src/baseobject.h
BaseObject.h
#ifndef BASEOBJECT_H
#define BASEOBJECT_H
#include <QObject>
class BaseObject : public QObject
Q_OBJECT
public:
explicit BaseObject(QObject *parent = nullptr);
Q_INVOKABLE QString deviceUid() const;
#endif // BASEOBJECT_H
BaseObject.cpp
#include "baseobject.h"
#include <mdm-sysinfo.h>
BaseObject::BaseObject(QObject *parent) : QObject(parent)
QString BaseObject::deviceUid() const
return Sailfish::Mdm::SysInfo::deviceUid();
MDM_Example.cpp
#ifdef QT_QML_DEBUG
#include <QtQuick>
#endif
#include <sailfishapp.h>
int main(int argc, char *argv[])
qmlRegisterSingletonType<BaseObject>("org.example",
1,
0,
"BaseObject",
[](QQmlEngine *engine, QJSEngine *scriptEngine) -> QObject * {
Q_UNUSED(engine)
Q_UNUSED(scriptEngine)
BaseObject *obj = new BaseObject;
return obj;
return SailfishApp::main(argc, argv);
Thank you for your help!
Try to omit
in your .pro file. Keep just
link_pkgconfig is already added as an effect of adding sailfishapp and there is a nasty bug in qmake that adding link_pkgconfig multiple times makes later changes to PKGCONFIG ineffective or so (IIRC).
