BUILD ID = OS VERSION (Settings > About product): 4.0.1
HARDWARE (XA2, Xperia 10…): SDK
UI LANGUAGE: -
When using sfdk command in form
sfdk build -j4 /.../tbuilder/project/src/systemdatascope -- --define="sailfishos 4.0"
I get
error: failed to stat .../project/build/SailfishOS-4.0.1.48-i486/systemdatascope.spec/--define=sailfishos 4.0: No such file or directory
after the package is compiled. In this example, .../project/build/SailfishOS-4.0.1.48-i486/systemdatascope.spec is a directory from which the build was run (I had my reasons to set this unusual name for a directory).
- See description above
Compile and package RPM
Failed at the final stages of packaging
