Hi to all,
quite often I need to separate numeric keyboard. Only one I found is numeric keyboard from tmi on openrepos, but on 3.4.0.24 on xperia x is shifted down too much and last line is not visible.
I need:
numbers
Space
Backspace
Could someone be so kind and adapt it or fork it? Tmi seems to be not active anymore.
Yeah, I was.thinking about making one, but I realised that is no necessary because tmi has already made one. But I dont know how to fix it.
And on the other hand, why should I make some and spend my time on it, when it is present on sfos already - when you have some field to fill numbers, that numeric keyboard appears automatically. So I would like to find a way how to make this built-in numeric keyboard appear in the list of keyboards and made it active everywhere
So i decided to try to edit tmi’s numeric keyboard. Solution was easy - only edited height and I was so happy that i made oldschool nokia 3310 keyboard too so if there is someone who is capable to publish it on storeman, i can provide qml and conf files
I tried this but no luck. Sailfish OS 4.5, Xperia 10 lll. I made .qml and .conf files and copied them to /usr/share/maliit/plugins/com/jolla/layouts/. I have rebooted and cannot see number row. Should I config something else also?
If i remember corewctly, i didnt see one row.i solved it by editing conf on some line where was some size or resolution.after restarting maliit it worked.
