Secondhand Jolla Phone with a pin
Hi everyone!
I’ve got my hands on a secondhand Jolla Phone in a really nice condition from kleinanzeigen with the only problem being that it’s pin locked. The seller says that it shouldn’t have a pin since he apparently factory reseted it, but I dunno.
The phone runs 1.1.7.28 and is apparently set up in a way that it never asks for the pin to unlock it. Problem is that I can’t enable developer mode, untrusted software and also disable the pin obv.
Recovery mode seems to be on v0.3.1 and the passcode prompt in the running system doesn’t seem to have a limit in tries.
The question now is, is there anything I could try, except for bruteforcing it (by sw or hw)?
There are already threads on this. Please use those.
Thanks, already done, that’s why I am asking :))
You are clearly not using those threads - you have created a new one.
Fine, as you wish.
(btw, the OP can’t even lock their own threads on discourse?)
You should probbly also search together.jolla.com.
A Quick Search™️ found this:
