REPRODUCIBILITY: 100%
OS VERSION: a) arch linux 6.7.9 b) ubuntu 20 (5.15)
HARDWARE: Epyc Server 7402 with OS in VM
UI LANGUAGE: en_US
REGRESSION:
Sailfish SDK 3.10.4 installation does not succeed on virtualized OS (a) arch 6.7.9, b) ubuntu 20 ).
Both approaches virtualbox and docker fail each the same way:
- installation with virtualbox:
- installer runs untill end, no problem in both a) and b) when virtualbox dependencies are installed correctly
- both virtualbox-VM stuck during their bootup with the following error
Spectre V2 : Spectre mitigation: kernel not compiled with retpoline; no mitigation available!
measure - unreliable DMA position
Failed to determine block device of root file system: no such file or directory
- as a comparison:
the nearly same OS arch 6.7.6 running natively on a Thinkpad x260 (i5-6200U) has no problem at all with SDK/virtualbox
- installation with docker:
- fails the same way with GUI installation and “headless” installation (which is not headless at all - you need libxcb, x11, …)
[36513] Created critical message box "archiveDownloadError": "Download Error", "Cannot download archive https://releases.sailfishos.org/sdk/repository-3.10.4/common/org.merproject.mersdkdocker/2023.02.17-1buildengine-docker.7z: Error while reading: error:1408F119:SSL
routines:ssl3_get_record:decryption failed or bad record mac"
- looks like openssl-1.1 issue, but:
a) in arch 6.7.9: manually changing /usr/bin/openssl to openssl-1.1 did not change anything
b) in ubuntu 20: openssl-1.1 is default → error occurs nonetheless - a quick solution with manual download of 2023.02.17-1buildengine-docker.7z and specification of the file location in installer would be sufficient…
Both OS (a) arch 6.7.9, b) ubuntu 20 ) where SDK 3.10.4 shall be installed are virtual machines on an Epyc Server.
- Install SDK with virtualbox and start “Sailfish SDK Build Engine” in virtualbox manually to see error in VM console
- installation of SDK with docker fails during download of 2023.02.17-1buildengine-docker.7z
- running virtualbox “Sailfish SDK Build Engine”
- successful installation of SDK 3.10. with docker
- virtualbox “Sailfish SDK Build Engine” stucks with
- installation of SDK 3.10. with docker fails with "Cannot download archive https://releases.sailfishos.org/sdk/repository-3.10.4/common/org.merproject.mersdkdocker/2023.02.17-1buildengine-docker.7z: Error while reading: error:1408F119:SSL routines:ssl3_get_record:decryption failed or bad record mac
Nothing beside necessary steps as described in Installation | Sailfish OS Documentation (virtualbox, docker, user rights).
a) fresh installed arch 6.7.9
b) ubuntu 20 not changed
