Screenshots not shared via Whatsapp or Signal (Molly)
REPRODUCIBILITY: 100%
OS VERSION: 5.2
HARDWARE: Jolla 2026
UI LANGUAGE: French
REGRESSION: First experience with Jolla and Sailfish
Sharing screenshot via Whatsapp or Signal (Molly) fails.
None, I think.
  1. take a screenshot by pressing both volume buttons
  2. see the picture in the gallery
  3. Share it via Whatsapp or Signal (Molly)
That the media would actually be shared
The media tries to load, but failed. A message informs the user taht the media does not exist in the phone memory.
This solution worked :
This bug has been reported in the past and marked as solved, but I just experinced it all afternoon.
Crucial information if you allowed Andy to access SFOS files is missing.
I am willing to help :slight_smile:, but :
  1. I don’t know what S.F.O.S. files are,
  2. how do I get Andy to access them.
I might be in over my head here…
If you open Settings → Apps → Signal (Molly) → Open Android settings → Permissions. Is the permission Photos and videos allowed?
Not really. I’m often very technical.
SFOS = Sailfish Operating System
Andy is data greedy so the default is to not allow access.
Go to end of the Settings in Information part and tap Andy or AAS support. It should be self explanatory.
Try this before solution from @pherjung. And if it doesn’t help then his.
Hey filip.k,
I must be quite thick because I can’t find it…
I’ll change the language to English to see if I can find Andy :slight_smile:
Just go to the very bottom of the Settings. Just one before the last line
Found it, and it was on.
I then tried @pherjung solution and it worked. My apologies for the unnecessary trouble.
I have to remember to check the permission in the Android settings before posting here, when I run into trouble with an app.
Enjoy your evening, and thanks a million for the help :smile:
