REPRODUCIBILITY: Always
OS VERSION: 4.5.0.18
HARDWARE: Platform SDK
UI LANGUAGE: NA
REGRESSION: Not known
As a part of QT WebEngine compilation, one executable (mksnapshot) is started to generate code. This executable fails and it can be isolated to larger mmap allocation. The problem can be reproduced with the following code:
#include <iostream>
#include <sys/mman.h>
int main()
std::cout << "MMap test\n";
void *hint = 0;
size_t size = 8*1024UL*1024UL*1024UL; //8589934592UL;
int prot = 0;
int flags = 16418;
int kMmapFd = -1;
int kMmapFdOffset = 0;
void* result = mmap(hint, size, prot, flags, kMmapFd, kMmapFdOffset);
std::cout << "Result: " << result << " - size: " << size << "\n";
std::cout << ((result == MAP_FAILED) ? "Failed" : "Success") << "\n";
return 0;
On Platform SDK, using AARCH64 target, I get:
MMap test
Result: 0xffffffffffffffff - size: 8589934592
Failed
On PC:
MMap test
Result: 0x7f502f94d000 - size: 8589934592
Success
When running on the original application (mksnapshot) on device, all works as expected. This is even with the device (XZ2) having 4GB RAM. Haven’t tested the test code on device, though.
None
- Save C++ test example into test.cpp
- Enter Platform SDK SB2 environment:
sb2 -t devel-aarch64 bash - Compile and run the code:
g++ test.cpp && ./a.out
Code prints “Success”
Code prints “Failed”
None
ADDITIONAL INFORMATION
Original issue reported as a part of the request: Using SDK via qemu emulation
Note that the problems start from allocating 3GB.
