I would chime in that definitely the UI should have the tabs up and swipe navigation.
It’s not like Sailfish would use complicated ios gestures, it’s just simple swipes.
Maybe one “it’s AI” argument here is that converting an official Android app to QML etc would look like it does now - like translating text from a language to another, but retaining the original grammar and syntax.
I’d also expect Lock to be the lowest pulldown item so it’s the quickest to reach without accidentally logging out, though maybe that’s just me.
Settings > Vault > Folders going to rename with pulldown delete makes little sense. Android calls it “edit” and has that stupid burger menu for deleting.
Someone who’s real up to speed on the guidelines can chime in, but I’d longtap the folder name to reveal rename and delete. Or even buttons ffs.
Makes sort of sense as an argument to keep it like what people have seen (coming off Android), but it also looks like laziness with the Claude-or-whatever. Don’t need to maintain the UI if the agent can be converting from Android and using expectability as an excuse! No accusation or shaming, that’s just the looks.
People also expect Sailfishiness in their Sailfish and Android is absolutely no paragon of usability.
Is AI bad in the sense that is AI being incapable the reson to not opensource this? Dealing with PRs and issues is too much for it to handle?
I always like sticking to the general user experience of the environment. While basing the app UI on the Android version may make it more easy for people who make the switch, it most certainly makes it much harder for anyone used to SailfishOS.
Maybe it’s just me, but I like apps the most, if they are just “unapologetic SailfishOS”. If I’d want an Android/iOS like interface, I’d purchase an iPhone/Android Device. “Our” UI/UX has it’s own strengths, and they shine the most, if you follow it’s specific design patterns. That’s what makes an app intuitive (for the platform) and feel like it is “fitting in” with everything else.
On iOS you’d most likely cause a witch-hunt if you’d use Google Material You design and patterns thru and thru because it’s what people that may come from Android are used to. Even the native Google apps are customised for the iOS way of handling the user interface.
Your 3rd item from the pros list is not really a pro, because you can also access sailfishy tabs with one finger. It just takes a few swipes to get there instead of one tap.
But, realistically speaking, how often do you need to switch between those tabs anyway?
Adding an option in settings would be my preferred way of handling different preferences, like in this situation, but if the option is to just move the current tabs as they are to the top, that solves nothing.
I see no reason to waste energy on it.
If you really want a useful option, add one that allows the user to switch from the current tabs to standard sailfish tabs.
There is no problem if the tabs move down while dragging the pulley menu. It is the expected UX behavior after all.
I see no issue with it in the phone app.
It would also be useful to have an option to move the search function to the pulley menu if you are not willing to move it there by default.
Just put it as far away as possible from the lock and log out items. Those things are dangerous.
Especially dangerous is the log out one, which also removes your unlock pin, so you have to set the pin again once you log back in.
Is that a bug?
Thanks to a kind user on here I should have a sailfish phone on the way to me as well. That should make this much easier going forward.
On your screenshot, no, not a bug. Bitwarden has a list of specific devices it accepts. I tried to send a custom sailfish identifier but it broke so I felt like android was the next closest thing over say, iOS. Same with the logout, I wouldn’t really expect it to remember your PIN after logging out.
I pushed a couple more updates before this
0.6 - Fixes some reported bugs with 2FA and fixes (hopefully) biometric detection. One user already reported it fixed it for him.
0.7 - Should hopefully prevent UI locks by doing the decryption in a background thread, fix a bug with the cover status not matching locked/unlocked status, and an issue decrypting older organizations.
I’m headed out of town for several days but if there are any more bugs I’ll address them when I get back.
in case someone out there is still not picking up what fixflare is putting down, this app is:
vibe-coded
closed source
for literally the most sensitive and secure data
from a super-defensive ‘private’ person that just joined the community and wants you to ‘trust’ them so bad they made an FAQ about why you should trust them
but is already complaining of persecution and using that to dodge simple questions of provenance
and who thinks that developing for sailfish is important…but also does not own a phone running sailfish? and seems to think the only phone that runs sailfish is JP2?
and who wants you to think that they are rich and smart and don’t want fame, as opposed to a non-developer who doesn’t seem to know the difference between vibe-coding and senior developers using AI tools
on a side note, rikudou is rewriting bitsailor, to remove the nodejs dependency on bitwarden-cli right now.
TLDR don’t use this app. don’t trust this dude. even if it’s not a scam, it would be foolish for literally anyone to use this with their real vaults, even the author.
If you’re gonna make a client for a password manager, you need to open-source all the code. If it cannot be audited, it cannot and shouldn’t be trusted by anyone.
If you are serious about this endeavour, I expect you to publish the code and allow us to build the binary from source ourselves very soon, or otherwise get a proper third-party audit.
The difference is that when something is open-source, it’s possible for anyone to audit the code. With closed-source code that is not possible. Which is why any serious password manager that is closed source has third-party audits of their software.
I checked out the thread. He asked if you’d used AI, you didn’t answer the question, but rather started on some rant. Lying about the events doesn’t really make you more trustworthy.
Naturally I can’t be and maybe I changed the password(s) already. It’s also nice most services have warnings against strange logins as well as other safeguards.
The pulley menu indicator is below the tabs. That is not how Jolla does it. It should be above. The pulley menu should be the topmost (and/or bottommost) item on the screen.
The tab titles are not equally spaced and the font is too small
The order of the items in the pulley menu is unnatural. Usually apps have the “search” and “new item” first (i.e. the ones you encounter first when pulling on the menu).
Other unrelated issues I have found:
The search button/pulley menu item does not show the keyboard automatically. I have to tap the search field again to show the keyboard. That is not cool.
What is the “allow sync on refresh” setting supposed to do? Is that a relevant setting anymore? There is no refresh gesture, and it isn’t needed because there is a “sync vault” item in the pulley menu.
While viewing a vault item, the order of the menu items is unnatural. Why is “move to trash” first? That’s not what I need to do with a vault item most of the times when opening the pulley menu. I need to edit it.
Similar issue for when viewing a vault item that is already in the trash. I would expect the “restore item” option to be the first in the menu.
i’m actually growing more nervous about this app and this author. i think i’m going to paste my comment to openrepos, because i’m not sure if folks there realize its closed-source and vibe-coded, or that the author doesn’t use sailfish and cries persecution when asked questions about a security app coded in the dark of night under strict secrecy.
I’m back from vacation sorry for the delayed reply.
Wasn’t sure about this myself - should be up top now.
Looked perfect on my end but I’m guessing was scaled wrong for your device with a different resolution. Hoping it looks good now, let me know. Screenshot would help if it still looks off.
Fixed
Other items
Fixed
That was just to match that option from the android bitwarden client. It originally toggled the “Sync” appearing in the pulley menu on the vault tab but it became redundant when I added the option to select what appears in the pulley from the appearance tab so I removed it in the latest version.
Stop ignoring the feedback, please. Make your app open source. We have zero reason to trust any of the binaries you’ve been dropping on OpenRepos so far.
Vibe-coding is fine, but you can’t justify hiding the source of a critical app when the official software is open source.
I just want to say I love the option to hide the profile avatar.
Before noticing that option, I changed the color of the avatar to something that matched my ambience, and was about to ask for this feature.
Regarding the text on the tabs being too small, and unevenly spaced, nothing changed in the new version.
Here is the screenshot:
When compared to the text size in the screenshots of the dialer and the settings apps from my previous messages, the size of the tabs text in SailWarden is significantly smaller.
I don’t know if there is an official font size for the tabs text, but the official apps seem to use the same size.
I couldn’t find any information about this in the official documentation ( UI | Sailfish OS Documentation ), but that doesn’t mean much, given how goddamn maze-like the documentation website is.
Also, the spacing between the tabs is uneven. The space between “Send” and “Generator” is visibly larger than the other spaces.
This “introduction” got larger than I had anticipated, so I will end this post here, and make a separate post for the rest of the issues and suggestions I wanted to share.
I am back with the promised list of issues and suggestions.
I have two categories:
general
specific to the sailfish layout theme
I. General
Regarding the identifier of the currently used app (in Settings → Account security → Devices ), maybe “SDK” would be a better choice than “Android”.
[Display(Name = “SDK”)]
SDK = 21,
The ideal solution would be a pull request to add a value for Sailfish in the DeviceType enum from bitwarden/server/src/Core/Enums/DeviceType.cs
In the password generator, when the “include numeric digits” is unchecked, the generated password still contains one numeric digit (or whatever the “minimum numbers” value is set to, unless it is explicitly set to zero by the user).
When the checkbox is unchecked, there should be no digits added to the password.
Same issue as above, but for the special symbols
The icon for the “Card” items is wrong. It should be an icon of a bank card. It currently looks like an ID card of some sort.
The icon for the “Identity” items (the standing human) should be replaced with the icon currently used for “Card”, after issue #4 mentioned above is solved.
After entering my PIN/password to enter the vault, I should be allowed to tap enter on the keyboard and proceed. Currently, tapping enter does nothing, so I have to press the Unlock/Log in button. It would be more convenient to tap enter on the keyboard to proceed.
II. Specific to the sailfish layout theme
The arrows (‘>’) shown for each type of item right after the number of items are useless noise and should be removed (I think they look good in the default layout, but not in the sailfishy layout)
Same issue for the items in Settings. The arrows should not be used.
The icons should not be colored; they should be white, like the icons in the settings app (again, I think they look good as they are, colored, in the default layout, but not in the sailfishy layout).
This applies to both the icons in the Vaults tab and the ones in the Settings tab.
The categories should not be all-uppercase, except “TOTP”, which is an acronym.
Use the settings app as a reference for how they should look.
This applies to both the items categories in the Vaults tab and throughout the various pages of settings.
Good news, thanks to that kind user on here I now have a Sailfish phone for testing which has made my life a whole lot easier.
I made some adjustments to the header tabs and at least on my new phone, they seem to match 1 to 1 with Jolla’s from system settings. (same size, margin).
I also added an option in appearance to change them from small/normal/large where normal should match Jolla. That way, if a user wants their tabs a little bigger or smaller they can do that.
On your other items:
six one way/half a dozen another really. Getting bitwarden to add Sailfish would be ideal yes, but I think it is a bit of a stretch until it has a much larger user base.
Fixed
Fixed
Yea, I’m using stock icons in places since I’m a programmer not a graphic designer. I made a couple but it is a pain to get them to match with the existing icons. Have to get scale/line width, and padding all just right or it looks weird when paired with other stock icons. It is on my list of things to do but stability/functionality is more my priority right now
same as #4
Fixed
Sailfish theme:
removed on sailfish theme
fixed on sailfish theme
All of the above plus some performance optimizations should be in the 1.0 version I just pushed.
To others, your questions have already been answered. Try ctrl + f for “spot on” or “as far as open source” and read back from there.
If you ask a question that has already been answered I’m not going to keep repeating myself. If you have a legitimate question that hasn’t been asked before or a feature request, just ask nicely and 'I’ll be happy to consider it.
