Can somebody else confirm/deny they have both sim cards working at 4G simultaneously?
PS Single 4G icon in status-bar means only 1 sim-card is on 4G.
So, nobody can confirm?
Also, disconnecting usb OTG adapter still (on 4.0) reboots X10.
I had successfully in use 2 SIM cards on 4G at the same time for many months. No problems visible. Sony Xperia 10 Dual SIM.
How did you check that both cards are really on 4G at the same time?
Both sigmal indicators full signal and 4G indicated on display. No more precise information, I must confess…
this single 4G icon only means the signal for the “internet” sim. I have it too, displayed.
nonetheless, only this designated “internet” sim is on 4G, the other one is on 2G.
You can check current signal like this:
$ dbus-send --system --print-reply=literal --type=method_call --dest=org.ofono /ril_0 org.ofono.NetworkRegistration.GetProperties | grep Technology
$ dbus-send --system --print-reply=literal --type=method_call --dest=org.ofono /ril_1 org.ofono.NetworkRegistration.GetProperties | grep Technology
So in my case it shows this (4g for sim1 and 2g for sim2):
Technology variant lte )
Technology variant gsm )
Maybe one of your cards needs an update from your provider. Put it in an android phone for a day, that did it for me.
You probably missed my post higher - sim card selected as “default for internet” gets 4G, the other one gets 2G. They both can work as 4G (not simultaneously!) if I designate them as “Internet” one.
