Hi, sailfish os 4.5 running on sony xperia xa2 plus. For a while Ive been having a few minor and irregular bugs that I was able to ignore until now. Im trying to work out whether they are the caused by the sailfish system or the older phone and if buying a newer sailfish compatible phone could solve the issues or not?
The issues:
- Camera frequently get stuck on a black screen and will not load to allow me to take photos. Mostly solved after restarting although on a few occasions it has now solved it.
- Frequently when calling someone when they pick up all audio is gone, I cannot hear them and they cannot hear me. Usually solved by restarting the phone.
- Occasionally data service will not turn on, it sometimes searches for service but will not connect. This has happened in both remote and cbd locations. Restarting does not solve it. Reinserting sd card will not solve it. It just eventually work again. I know this could be a service issue from my provider but it didnt seem like it was bugging just by turning it on and wasnt actually even able to search.
- Maps rarely work (using pure maps and have tried a few different map providers). Basically 9/10 times it just cannot create a route from the start location and finish location I input. Is there better map apps that dont rely on google services? Would love to find one.
Appreciate any input or thoughts, theres definitely a few more bugs that happen and I will update as I remember them. I am going on an international trip soon and some of these bugs concern me for that and would like to work out if purchasing a newer model phone could solve them for me!
Thanks.
